    NprTools
    extensions
    83 Posts 9 Posters 21.3k Views 9 Watching
    • Al HartA
      Al Hart
      @sorgesu said:
      Al, Congratulations on the release of NPR Tools. This is a wonderful and useful addtion to the SketchUp Modeling arsenal. I can't wait to see all the great looking output that I am expecting, using this great tool.
      Thanks Susan,
      I will be very interested in your ideas when you get a chance to play with it.
      One thing I want to add is the ability to make shadows darker when they are further from the eye.
      Something like this: (Image NOT created with Sketchy Shadows)
      The shadows are not really darker further from the eye, but I could alter the cross hatch based on the distance from the eye.
      I am thinking that Piranesi EPX format saves the Z-depth of the pixels into the image. Are you aware of any software which would let me access or read the EPX file without using Piranesi itself?
      Al Hart
      IRender nXt from Render Plus
        sorgesu
        No Al, I can't think of anything like that. But there is a neat demonstration somewhere where you can use the "fog" setting within SketchUp to accomplish the same sort of thing. Something in "black" that conveys the depth by degrees of gray in the alpha channel
        That is essentially how it works in Piranesi. If you were to look at the "depth channel" ,which you can indeed do, for any image imported from SketchUp, it is displayed as degrees of Grey ( Gray?) and I believe that is how it is recognized in Piranesi as having differing depth.
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
          sorgesu
          Al, below are 2 images. the first is using a black "Fog" in SketchUp on a Hidden line drawing. I should probably have used Monochrome mode with no edges showing instead. But you get the idea. the next one is the same view within Piranesi's Depth Chanel. The background red is the "infinity" of the Sky.[attachment=1]gapFOG.jpg[/attachment
          Susan Sorger
          • Al HartA
            Al Hart
            @sorgesu said:
            No Al, I can't think of anything like that. But there is a neat demonstration somewhere where you can use the "fog" setting within SketchUp to accomplish the same sort of thing. Something in "black" that conveys the depth by degrees of gray in the alpha channel.
            Great idea - Fog - This is a shadow image with fog turned on:
            I can treat the "lighter" shadows as being further away and make them darker or use more hatching.
            Also, the fog makes the roof darker as it is further away.
            (This is difficult for me to see - but a paint program verifies it)
            I can do two things:
            1. Apply "fog" darkening to only a specific material (so you can apply a dummy material to the roof and darken only the roof)
            2. Use this "fog" darkening to apply cross hatch to the roof, going from single lines, to cross hatch lines as the roof gets further away.
            Stay tuned...
            Al Hart
              One more thing, in the thread where I posted the pictures; the view from the top - there's shadows missing on the ground.
              • Al HartA
                Al Hart
                (Excuse all these long answers - but I want to give complete answers to questions so I can use this as a basis for how to improve the documentation)
                For the Pattern Sketchy Shadows (as opposed to the watermark shadows which will come later), I cannot put them on the ground. I make the patters by applying the pattern material to the entire SketchUp model and then saving an image, and these is no easy way to place the materials on the ground.
                So you will have to draw a face on the ground large enough to hold all the shadows.
                (Also in this histogram filtered version of the shadow patterns you can see that the texture is not fully dark. So the shadows wil not be any darker than this pattern.)
                Al Hart
                  That's the thing; there is a ground plane face there. You can see in the other examples there's shadows there. Just not in the top view.
                  • Al HartA
                    Al Hart
                    I see some very slight things on ground on the right of the top view. (It is very difficult to look at images of other people models and know what is missing)
                    Reprocess the top view image, and look in the TemporaryImages folder.
                    Compare the shadow_histogram.png file and the histogram_pattern.png file (or upload them here) to see if there is a clue to what might be missing. (These are the images which are merged with the Base.ong image to get the final image.
                    Al Hart
                    • Al HartA
                      Al Hart
                      It turns out that Piranesi uses a TIFF format format with extra channels added for Z-depth and material ID. I may be able to use it directly, or I may be able to export the same information from SketchUp. I would be easier to have the actual Z-data, rather than having to reverse-engineer it from fog colors.
                      Al Hart
                        sorgesu
                        Yes, that's right. I didn't realize that that would have been helpful info, sorry.
                        Susan Sorger
                        • Al HartA
                          Al Hart
                          Not really very helpful, because I can't find any software anywhere that already reads it. Still, it would be nice to get the "exact" z-depths rather than having to guess them from fog.
                          Al Hart
                          • Chris FullmerC
                            What about the .eps format? I thought that Piranesi was using that format? But I know very little about it really.
                            EDIT Hmm, I see that have their own epx. I must have got the last letter confused in my head.
                              sorgesu
                              Ya did, Chris. It is epx which is just a Tiff with 2 extra channels. I can't think how to unravel that info because epix is proprietary and I somehow doubt they would want to share the data therein
                              Susan Sorger
                              • Al HartA
                                Al Hart
                                I added a couple of handy things today (But you won't get them until Monday)
                                Mask Soft Shadows
                                I added a "Mask soft shadows to the shape of the original shadow" option.
                                This lets you you very broad soft shadows, but not let them overwhelm the size if the shadow itself.
                                http://wiki.renderplus.com/images/thumb/a/a5/Tack_Full_Image.png/300px-Tack_Full_Image.png
                                Original shadows from ShetchUp
                                http://wiki.renderplus.com/images/thumb/7/74/Nail-SFSH-q.png/300px-Nail-SFSH-q.png
                                Soft Shadows over a wide area.
                                (I used just a few iterations so you could see the effect better.
                                http://wiki.renderplus.com/images/thumb/5/5e/Nail-SFSH-r.png/300px-Nail-SFSH-r.png
                                Soft Shadows masked to original shadow shape.
                                Image Resolution
                                http://wiki.renderplus.com/images/b/b9/Saved_Image_Size.jpg
                                This options lets you set the resolution to be larger than the SketchUp screen.
                                (We still are limited to 3,000 pixels or so whatever the SketchUp Wxport 2D limit is)
                                (Also, be aware, it can take a long time to save hundreds of shadows images for high resolution soft shadows)
                                Al Hart
                                • Al HartA
                                  Al Hart
                                  In playing around with NprTools, I ran into an interesting philosophical question.
                                  In this image, is the wall on the left in a shadow?
                                  One obvious answer is YES - since the sun is not shining on it.
                                  The other answer might me NO - since SketchUp does not show it in the same intensity as the shadows on the ground.
                                  If it is in shadow, then this Sketchy Shadow image (the way it works now), is correct:
                                  However, you might prefer to draw the Sketchy Shadows only where the shadows appear on the ground.
                                  One other complication is that if you turn shadows off in SketchUp, the wall on the left does not change.
                                  So you could argue that the shadows don't really effect it. (This might be the way for me to solve the problem - if we don't like the Sketchy Lines on the wall - by comparing the image with the sun on and with the sun off to find the shadows. Currently, I use a SketchUp hidden-line image to determine where the shadows are.
                                  Any thoughts?
                                  Al Hart
                                  • Chris FullmerC
                                    There have been places in some of the images that I've seen with the sketchy shadows on them and I've thought - that should not have a shadow like that on it. And then I realize it is lightly shaded in SU, so it gets the shadow effect. I think that often I would prefer that the wall, in this case, did not recieve such intense sketchy shadows.
                                    Thats my thoughts,
                                    • Al HartA
                                      Al Hart
                                      The trick is how to get the shadows.
                                      One way is to compare two images and process the differences.
                                      SketchUp gives 2 different results.
                                      Here are two hidden line images (with and without shadows)
                                      (I compare these two images to get the shadows)
                                      Here are two monochrome images (with and without shadows)
                                      I can compare these two images instead.
                                      I will probably make this an option. But what to call it? ("Use monochrome shadow effect" - I hate check boxes which even I don't understand, or "Use only full shadows")
                                      Al Hart
                                      • Al HartA
                                        Al Hart
                                        Comparing the two monochrome images worked pretty well.
                                        I wound up calling the new option: "Use only full shadows"
                                        Image with option checked
                                        Image with option unchecked
                                        There are times when you will want to pattern all "non sunny" areas - especially for interiors.
                                        Al Hart
                                        • Al HartA
                                          Al Hart
                                          Yes,
                                          I'll keep NprTools discussions to the the NprTools topic.
                                          But I felt that this was a more general question for any SketchUp users who were interested in what should be treated as a shadow. People might be interested in how Hidden line treats shadows one way, while colored and textured rendering treat them a different way.
                                          Al Hart
                                          • Al HartA
                                            Al Hart
                                            When I choose the Launch option, the default image viewer opens
                                            without any image. It's blank.
                                            Default image viewer associated with most images is Irfanview while
                                            default image editor for SU is PS. Irfranview loads quick. That's
                                            good to quickly view the plugin results.
                                            Some options would be to choose default program to view images and
                                            have a choice where to save final output.
                                            I like having only one TemporaryImage folder. I suppose the user will
                                            have the responsibility to clear it out. It is possible to direct
                                            CCleaner to include user defined folders to clean out under Options.
                                            I am copying this from another forum. I will respond to it later.
                                            Al Hart
                                            • 3 / 5
