    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
      Ok, now I understand. I'll have to think a little on that one though. Will make quad-faces work first.
        davide.skp
        👍 good wrk and tnks
          Updated to 0.3.0b. Fixed a couple of bugs and added methods to rotate the orientation of the textures and transfer UV mapping to/from either side.
            davide.skp
            excellent! I tested and it works very well
              Has anyone experienced oddities when using this plugin? UI stops responding, or Bugsplats upon SU close?
              • free agentF
                free agent
                thomthom im sooo glad some ones finally working on mapping, found something yesterday in max that i thought was a cool feature, spline mapping - when u have a curved geometry, draw a slpine along a edge and use the spline to define the UV of the curb, so ur texture runs along the face would be awesome to see that in the future for Sketchup (regardless of how distant) good work so far 👍
                http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  Yea, that's one of the things I'd like to do. I was thinking of extending my selection toy plugin to select connected planar lines that comes within a certain angle difference. That could allow you to select all the edges along one side of the curb. Then, I wanted to write a plugin that aligns the texture in the direction of each edge segment.
                  I assume it's be released in two parts, the first simply aligns the texture to the edge direction. (which is where I find most time is spent.) Then I'll see if I in the second round make it position the texture seamless in relationship to the previous face; but this is more difficult.
                    MrWip
                    Thank you so much! this plugin is really great and make things soo easy (aahh, curve walkways with precise repetition all along the track of the same stone tile...)
                    By the way,I just have two questions:
                    • Is it possible to add a shortcut to your UV tools in the right click menu ? that will improve greatly the workflow.
                    • Is there a way to add an option 'automatic' to your 'front face to back face'. It could be really good to have such a switch, so all the texture add when it's 'on' will automatically cover both sides, and with the same UV (it should work in the same time from front to back and back to front with the option on).
                    http://www.wip-archi.com
                      Already on my to-do list. 😉
                      Good idea! An 'Backface' checkbox option that will set the plugin to use or ignore backfaces during its operations.
                        MrWip
                        I don't know if my last request was clear, in fact... What I'm trying to say (but maybe you get it) is modify your tool to make it able to be active all the time (or not), so the simple fact of applying a texture on a face (back, front, whatever...) will automaticly apply it on the other side (something that sketchup does not do by itself...)
                          Ah! Gotcha. That might be doable. It depends if the materials observers works as they should though. I've run into allot of bugs lately in terms of monitoring the model for changes. I'll put it on the list of things to check out.
                          • I
                            ideas_arte
                            muchas, muchas gracias...!
                            Thank You very much...!
                            • MALAISEM
                              MALAISE
                              Never be to far from the Forum then you miss so useful Rubies.....
                              Thanks Thom Thom 👍 👍 👍
                              MALAISE
                              • troyhomeT
                                troyhome
                                Thom Thom,
                                Thank you so much for this ruby- it MUST appear in the next release of SU!!!
                                IOviz.com
                                SU Pro 2024 PC
                                • N
                                  notareal
                                  Nice one, thanks. Wish there was a way to "force" SU to use only quad-faces when using "auto-fold" or other tools.
                                    Aerilius
                                    It's really good that someone makes texture tools that are not in this interlaced context menu.
                                    For future tools: It would be useful to transform a projected texture in a normal one (= to get the texture coordinates). So we could edit projected textures. I have often deleted the original face, so when another face with projected texture is not coplanar, there's now way to move edit the texture.
                                    • GaieusG
                                      Dandyman's OT posts split off and moved here:
                                      http://forums.sketchucation.com/viewtopic.php?f=80&t=19497&p=160663#p160663
                                      • free agentF
                                        free agent
                                        thom is ther any way of making mirror textures global? max retains the mapping better if the textures are on both faces and its a schlep to go through each group
                                          A function that will mirror the material of all faces in a selection, drilling down into nested groups/components?
                                          • free agentF
                                            free agent
                                            yup...can i get fries with that?
                                            • 18
                                            • 19
                                            • 2 / 19
