    Bush Lodge - Vray - updated
    60 Posts 39 Posters 14.2k Views 39 Watching
      DzineTech
      I was assuming it was a front and rear shot of the same building. If its 2 different ones then that explains why I was seeing something different as they are so similar in style.
      • free agentF Offline
        free agent
        those are the same renders, same front and rear, same angles, same building
        i think i understand ur problem, the Lodge has 2 roofs in an L shape, the views dont show both, the client specified view angles
          troyhome
          This is absolutely amazing stuff! I love that it's not all done in SU, but that Photoshop was used. This is a great time saver as far as rendering times go. But i always wonder how much time goes into the post-renders in ps- that must be very time consuming. I'd be interested in how long that takes you.
          IOviz.com
          SU Pro 2024 PC
            free agent
            the model took 3 days cos i was faffing with textures, and the Photoshopping for both took another day, maybe less coss i finished the first one the same evening i finished rendering, then finished the second render the following morning, it really is quick.
            • holmes1977H Offline
              holmes1977
              Insane, Pure Perfection......Such a fan
              Exaggeration makes a dull story better.
              • olisheaO Offline
                olishea
                amazed. If I wasn't told that it was a render I'd probably think it was a photo. transition between photo and render is seamless.....really well done, inspiring stuff, hopefully my renders will be like that one day!!
                oli
                  rcossoli
                  I like your work because it is a super combination of a 3D model rendering (and rendering it necessary) and work in photoshop, it's more than just a render, is a work of composition, congratulations!!!
                  sorry my inglishhhhh
                  THREEDIMENSIONSWEB dot COM
                    troyhome
                    I aspire to be this good.
                    IOviz.com
                    SU Pro 2024 PC
                    • marked001M Offline
                      marked001
                      i really hope you have a chance to share your methods....would be great. like rcossoli said, this is that digital art is all about... mixing methods and media to create a beautiful cohesive image. its even greater when you see the state of the raw render.
                      great stuff... def some of the best we've seen on here..
                      http://www.revision21vis.com
                      instagram: revi21on
                        free agent
                        wow thanks, i also see it as a painting/rendering mix type thing, Mike Lucey has contacted me about a tutorial which i hope to have time for, so i do intend on sharing my methods. thanks again for the kind words
                          πŸ‘ πŸŽ‰ πŸ‘
                          • 9 Offline
                            9fly
                            Can not believe. Is it the grass are render?
                            • cucsat2003C Offline
                              cucsat2003
                              The perfect combination of renderings and images in photoshop.You're master,Free Agent!
                              • olisheaO Offline
                                olishea
                                Free Agent: Please could you post the gabion wall texture you used in this scene? it looks amazing...i'd be really grateful. πŸ˜„
                                oli
                                  rev3rse
                                  An incredible work..
                                  when you combine 3D + real photos + PP = matte painting, a new shape of art.. πŸ‘
                                    madhav
                                    beautiful results. πŸ‘
                                    • romboutR Offline
                                      rombout
                                      wanted to share my latest render, hot out the oven πŸ˜„
                                      http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-02-1.jpg
                                      http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-01.jpg
                                      wow wow wow
                                      great image, done with vray 4 su!!!
                                      love it, im learning thea at the moment.
                                      I need to model a palapa soon and i came across this image of yours. Where did you find the text of that thatced roof.
                                      And how did you do the grass at the fore ground, looks insane real! to me
                                      and huh where do you get your skies from, it look great
                                      where's your psd file with layers, you said you was planning to post it???
                                      πŸŽ‰
                                        skyscraper100
                                        great renders! youre a master πŸ‘
                                        The way you think Creates reality for yourself.
                                          troyhome
                                          more more more, please!
                                          IOviz.com
                                          SU Pro 2024 PC
                                            leminilab
                                            πŸŽ‰
                                            πŸŽ‰
                                            πŸŽ‰ πŸŽ‰
                                            Wow... I'm seasick...
                                            ... Last time I'm using this bouncin' emoticon... 🀒
                                            • "Live every day as if it were your last and then some day you'll be right."
                                            • "ThomThom rules!!!"
                                            • 2 / 3
