    Bush Lodge - Vray - updated
    60 Posts 39 Posters 16.7k Views 39 Watching
      steelers05
      wonderful images...id like to see more
      • free agentF Offline
        free agent
        DzineTech
        i think your gonna need to draw us a diagram or something cos i didnt alter any structure via photoshop and those are the raw renders for the ones on the first post (plaster wall inset on the back stone wall is the only difference).
        Richard
        these are the only bushveld type renders for the series, the rest are generally tuscan 🀒 and contemporary, i'll do a mega post once their done, there are 25 houses of them with 2 renders each (but i dont like a lot of em so it might not be that much)
          DzineTech
          I was assuming it was a front and rear shot of the same building. If its 2 different ones then that explains why I was seeing something different as they are so similar in style.
            free agent
            those are the same renders, same front and rear, same angles, same building
            i think i understand ur problem, the Lodge has 2 roofs in an L shape, the views dont show both, the client specified view angles
            • troyhomeT Offline
              troyhome
              This is absolutely amazing stuff! I love that it's not all done in SU, but that Photoshop was used. This is a great time saver as far as rendering times go. But i always wonder how much time goes into the post-renders in ps- that must be very time consuming. I'd be interested in how long that takes you.
              IOviz.com
              SU Pro 2024 PC
                free agent
                the model took 3 days cos i was faffing with textures, and the Photoshopping for both took another day, maybe less coss i finished the first one the same evening i finished rendering, then finished the second render the following morning, it really is quick.
                • holmes1977H Offline
                  holmes1977
                  Insane, Pure Perfection......Such a fan
                  Exaggeration makes a dull story better.
                  • olisheaO Offline
                    olishea
                    amazed. If I wasn't told that it was a render I'd probably think it was a photo. transition between photo and render is seamless.....really well done, inspiring stuff, hopefully my renders will be like that one day!!
                    oli
                      rcossoli
                      I like your work because it is a super combination of a 3D model rendering (and rendering it necessary) and work in photoshop, it's more than just a render, is a work of composition, congratulations!!!
                      sorry my inglishhhhh
                      THREEDIMENSIONSWEB dot COM
                      • troyhomeT Offline
                        troyhome
                        I aspire to be this good.
                        IOviz.com
                        SU Pro 2024 PC
                        • marked001M Offline
                          marked001
                          i really hope you have a chance to share your methods....would be great. like rcossoli said, this is that digital art is all about... mixing methods and media to create a beautiful cohesive image. its even greater when you see the state of the raw render.
                          great stuff... def some of the best we've seen on here..
                          http://www.revision21vis.com
                          instagram: revi21on
                            free agent
                            wow thanks, i also see it as a painting/rendering mix type thing, Mike Lucey has contacted me about a tutorial which i hope to have time for, so i do intend on sharing my methods. thanks again for the kind words
                              πŸ‘ πŸŽ‰ πŸ‘
                              • 9 Offline
                                9fly
                                Can not believe. Is it the grass are render?
                                • cucsat2003C Offline
                                  cucsat2003
                                  The perfect combination of renderings and images in photoshop.You're master,Free Agent!
                                  • olisheaO Offline
                                    olishea
                                    Free Agent: Please could you post the gabion wall texture you used in this scene? it looks amazing...i'd be really grateful. πŸ˜„
                                    oli
                                      rev3rse
                                      An incredible work..
                                      when you combine 3D + real photos + PP = matte painting, a new shape of art.. πŸ‘
                                        madhav
                                        beautiful results. πŸ‘
                                        • romboutR Offline
                                          rombout
                                          wanted to share my latest render, hot out the oven πŸ˜„
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-02-1.jpg
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-01.jpg
                                          wow wow wow
                                          great image, done with vray 4 su!!!
                                          love it, im learning thea at the moment.
                                          I need to model a palapa soon and i came across this image of yours. Where did you find the text of that thatced roof.
                                          And how did you do the grass at the fore ground, looks insane real! to me
                                          and huh where do you get your skies from, it look great
                                          where's your psd file with layers, you said you was planning to post it???
                                          πŸŽ‰
                                            skyscraper100
                                            great renders! youre a master πŸ‘
                                            The way you think Creates reality for yourself.
                                            • 3 / 3
