    Bush Lodge - Vray - updated
    60 Posts 39 Posters 18.1k Views 39 Watching
    • free agentF
      free agent
      yes i generally use the same settings, and the raw and finals are back to front, the top final image is the bottom raw image, sorry about that initially i had liked the back view more so i arranged them like i did with the raw images, but then after updating the front view i placed it on top and didnt do so with the raw renders... still the same renders none the less πŸ˜„
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • soloS
        Sean
        Any chance of sharing your Vray settings?
          DzineTech
          @thomthom said:
          @dzinetech said:
          I may be wrong but there seems to be some geometry differences between the 2 raw images; in the bottom there is a white cylinder at the rear end of the ridge and a concrete chimney at the front end, yet they dont appear in the top image, or have I misread the building?
          The final images have been updated once since the original post.
          I think you both misunderstand me...
          I'm refering to what I see on the roof in one image and not in the other whether it be RAW renders or the photoshopped images on the front page.
          • RichardR
            Richard
            I think they are obviously two different buidlings - as mentioned he has a few to do!
            BUILTBRAND.COM.AU
              steelers05
              wonderful images...id like to see more
              • free agentF
                free agent
                DzineTech
                i think your gonna need to draw us a diagram or something cos i didnt alter any structure via photoshop and those are the raw renders for the ones on the first post (plaster wall inset on the back stone wall is the only difference).
                Richard
                these are the only bushveld type renders for the series, the rest are generally tuscan 🀒 and contemporary, i'll do a mega post once their done, there are 25 houses of them with 2 renders each (but i dont like a lot of em so it might not be that much)
                  DzineTech
                  I was assuming it was a front and rear shot of the same building. If its 2 different ones then that explains why I was seeing something different as they are so similar in style.
                  • free agentF
                    free agent
                    those are the same renders, same front and rear, same angles, same building
                    i think i understand ur problem, the Lodge has 2 roofs in an L shape, the views dont show both, the client specified view angles
                    • troyhomeT
                      troyhome
                      This is absolutely amazing stuff! I love that it's not all done in SU, but that Photoshop was used. This is a great time saver as far as rendering times go. But i always wonder how much time goes into the post-renders in ps- that must be very time consuming. I'd be interested in how long that takes you.
                      IOviz.com
                      SU Pro 2024 PC
                      • free agentF
                        free agent
                        the model took 3 days cos i was faffing with textures, and the Photoshopping for both took another day, maybe less coss i finished the first one the same evening i finished rendering, then finished the second render the following morning, it really is quick.
                        • holmes1977H
                          holmes1977
                          Insane, Pure Perfection......Such a fan
                          Exaggeration makes a dull story better.
                          • olisheaO
                            olishea
                            amazed. If I wasn't told that it was a render I'd probably think it was a photo. transition between photo and render is seamless.....really well done, inspiring stuff, hopefully my renders will be like that one day!!
                            oli
                              rcossoli
                              I like your work because it is a super combination of a 3D model rendering (and rendering it necessary) and work in photoshop, it's more than just a render, is a work of composition, congratulations!!!
                              sorry my inglishhhhh
                              THREEDIMENSIONSWEB dot COM
                              • troyhomeT
                                troyhome
                                I aspire to be this good.
                                IOviz.com
                                SU Pro 2024 PC
                                • marked001M
                                  marked001
                                  i really hope you have a chance to share your methods....would be great. like rcossoli said, this is that digital art is all about... mixing methods and media to create a beautiful cohesive image. its even greater when you see the state of the raw render.
                                  great stuff... def some of the best we've seen on here..
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • free agentF
                                    free agent
                                    wow thanks, i also see it as a painting/rendering mix type thing, Mike Lucey has contacted me about a tutorial which i hope to have time for, so i do intend on sharing my methods. thanks again for the kind words
                                      πŸ‘ πŸŽ‰ πŸ‘
                                        9fly
                                        Can not believe. Is it the grass are render?
                                        • cucsat2003C
                                          cucsat2003
                                          The perfect combination of renderings and images in photoshop.You're master,Free Agent!
                                          • olisheaO
                                            olishea
                                            Free Agent: Please could you post the gabion wall texture you used in this scene? it looks amazing...i'd be really grateful. πŸ˜„
                                            oli
                                            • 3 / 3
