    Hardware recommendations
    409 Posts 97 Posters 163.4k Views 97 Watching
    • brodieB Offline
      brodie
      Your specs look really good to me. In fact they're almost overkill for SU, which doesn't use hardware very well (eg, doesn't recognize dual processors).
      To elaborate on Thomthom's point. SU uses the processor to show the geometry and GPU for textures and shadows. Textures and shadows can be turned off while you're modeling and orbiting but you can't turn off the geometry, so the CPU is typically the more important.
      -Brodie
      • AnssiA Offline
        Anssi
        Hi Wazzer,
        IMO you could even go to the lower spec (Quadro FX 2500 512 Mb or what the number now was, I was looking at the specs a couple of days ago) card but consider a CPU with more than 3 GHZ clock speed.
        Anssi
        • W Offline
          Wazzer
          Thats interesting thanks
          So i would get as good or better performance with an X9100 processor and a Quadro FX5700 512Mb
          Combination plus 4GB system Ram?
          I appreciate your help guys
          Ben
          • Z Offline
            Zilonx
            Core i7 920 ou Q9650 ???? (Well, both without overclock). Does anyone have experiences, benchmarks, opinions?
              remus
              The i7 is the better choice for SU, as it has turbo boost and the ability to be overclocked lots, should the wish ever arise.
              • soloS Offline
                I did a quick test using a recent very high poly model (which taxes my old dual core @ 3.20ghz)
                Using an i7 940 (standard...not over clocked) with a geforce gtx280, 12GB Ram and Vista 64bit, I made a video of how it handles the model then I duplicated the model several times and you can see the poly's, edges, etc and also on the right is the CPU fluctuations as the load and work required to run smooth pushes the clock speed by means of the turbo function, you will also notice that when the load is low the clock speed drops way down to conserve energy.
                [flash=900,406:2949y7ky]http://vimeo.com/moogaloop.swf?clip_id=4516551&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:2949y7ky]
                • N Offline
                  numerobis
                  Geforce or Quadro? Radeon or FirePro?
                  i'm planning to buy a new card.
                  so the question is...
                  • is skp faster on workstation cards? or is it better to buy one of the cheaper workstation cards (200-300€) or a bigger gaming card?
                  • looking at the latest card series, which one works better with skp - ati or nvidia?
                  i consider to buy a Radeon HD 4890 and mayby turn it into a Fire Pro.
                  Or a GeForce GTX 285.
                    Was that a total of 11 million faces?
                    • soloS Offline
                      Thomthom, I believe that's 1.18 million faces.
                      As you can see the rig was still very smooth. I tried a model that absolutely crippled my high clock speed dual cores in the past I did not check the face count but the size was 156mb 😲 , and it opened fast and was very smooth, the only issue was bounding boxes when orbiting with shadows on, but OMG my other rigs struggle to even open it never mind navigate without shadows on.
                      So again I say the i7 IS the best solution for SU IMO, it handles more poly's and makes more things possible.
                      i7 940
                      Asus p6 deluxe
                      64 bit Vista Ultimate
                      12GB corsair dominator ram
                      geforce gtx 280
                      1TB HD
                        Pure geometry? Or did that include textures?
                        Btw, that model you tried in that video, any chance I can test it out on my rig so I can see the difference between our rigs?
                        • soloS Offline
                          All geometry (no textures) This is part of it that I posted a while back, the complete file has double the amount of buildings.
                          http://img150.imageshack.us/img150/5519/scene8noisy12jn1.jpg
                          I will be accessing my server as soon as my weekly maintenace is done and send you the candle model.
                          • soloS Offline
                            Numerobis,
                            I suggest the nvidia gtx 285, ATI still have stability issues with many 3D modeling apps.
                            I would not bother with a Quadro as it performance gain if any is not noticable for the difference in price and then it's also a very limited card and chocks with heavy video editing.
                              Impressive model. Is that each brick modelled?
                              I'm very interested in what you did with the brick wall on the left side of the model, where the bricks are visible only in spots. (Has this model been talked about in another thread?)
                              • soloS Offline
                                Thanks.
                                Yes the bricks are all modeled, on the left side I used a random push pulll to get varying depths so giving the appearance of inconsistant showing and on the other side of the road it's standard depth for clean brick appearance.
                                This model is being used for an in-game video, my part is done (the modeling) the complete model is being textured at moment by another contractor and will be finally compiled in Max or Maya (not sure as my part is only initial modeling)
                                I have not really discussed this model as it's part of a bigger city model that I cannot show due to a NDA.
                                  I'll have to try that technique on my Discworld model; I want worn cobble stones in the streets; http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=18393
                                  • soloS Offline
                                    Seen this?
                                    404 Not Found
                                    (www.sketchucation.com)
                                      (I'll continue in that thread. πŸ˜‰ )
                                      • soloS Offline
                                        I did a performance video of the partial model, it's 126MB, has 1.8 million faces and double edges.
                                        Even with shadows on it was smooth, this does not orbit well on any other machine I tried, and not at all with shadows on.
                                        [flash=600,355:2xd6zd10]http://www.youtube.com/watch/v/XlW0fYb7dZQ[/flash:2xd6zd10]
                                          That's impressive. Didn't see it degrade to wireframe at all.
                                          • soloS Offline
                                            I did a fast and dirty 8 second animation in Vue, just added two cars and an atmosphere, put extra motion blur for drunk effect. rendered in 26 minutes.
                                            [flash=640,400:2xa87muf]http://www.youtube.com/watch/v/Mng2dgFxzIs[/flash:2xa87muf]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 20
                                            • 21
                                            • 13 / 21
