    Hardware recommendations
    409 Posts 97 Posters 208.7k Views 97 Watching
    • AnssiA
      Anssi
      Hi Wazzer,
      IMO you could even go to the lower spec (Quadro FX 2500 512 Mb or what the number now was, I was looking at the specs a couple of days ago) card but consider a CPU with more than 3 GHZ clock speed.
      Anssi
      • W
        Wazzer
        Thats interesting thanks
        So i would get as good or better performance with an X9100 processor and a Quadro FX5700 512Mb
        Combination plus 4GB system Ram?
        I appreciate your help guys
        Ben
        • Z
          Zilonx
          Core i7 920 ou Q9650 ???? (Well, both without overclock). Does anyone have experiences, benchmarks, opinions?
            remus
            The i7 is the better choice for SU, as it has turbo boost and the ability to be overclocked lots, should the wish ever arise.
            • soloS
              I did a quick test using a recent very high poly model (which taxes my old dual core @ 3.20ghz)
              Using an i7 940 (standard...not over clocked) with a geforce gtx280, 12GB Ram and Vista 64bit, I made a video of how it handles the model then I duplicated the model several times and you can see the poly's, edges, etc and also on the right is the CPU fluctuations as the load and work required to run smooth pushes the clock speed by means of the turbo function, you will also notice that when the load is low the clock speed drops way down to conserve energy.
              [flash=900,406:2949y7ky]http://vimeo.com/moogaloop.swf?clip_id=4516551&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:2949y7ky]
              • N
                numerobis
                Geforce or Quadro? Radeon or FirePro?
                i'm planning to buy a new card.
                so the question is...
                • is skp faster on workstation cards? or is it better to buy one of the cheaper workstation cards (200-300€) or a bigger gaming card?
                • looking at the latest card series, which one works better with skp - ati or nvidia?
                i consider to buy a Radeon HD 4890 and mayby turn it into a Fire Pro.
                Or a GeForce GTX 285.
                  Was that a total of 11 million faces?
                  • soloS
                    Thomthom, I believe that's 1.18 million faces.
                    As you can see the rig was still very smooth. I tried a model that absolutely crippled my high clock speed dual cores in the past I did not check the face count but the size was 156mb 😲 , and it opened fast and was very smooth, the only issue was bounding boxes when orbiting with shadows on, but OMG my other rigs struggle to even open it never mind navigate without shadows on.
                    So again I say the i7 IS the best solution for SU IMO, it handles more poly's and makes more things possible.
                    i7 940
                    Asus p6 deluxe
                    64 bit Vista Ultimate
                    12GB corsair dominator ram
                    geforce gtx 280
                    1TB HD
                      Pure geometry? Or did that include textures?
                      Btw, that model you tried in that video, any chance I can test it out on my rig so I can see the difference between our rigs?
                      • soloS
                        All geometry (no textures) This is part of it that I posted a while back, the complete file has double the amount of buildings.
                        http://img150.imageshack.us/img150/5519/scene8noisy12jn1.jpg
                        I will be accessing my server as soon as my weekly maintenace is done and send you the candle model.
                        • soloS
                          Numerobis,
                          I suggest the nvidia gtx 285, ATI still have stability issues with many 3D modeling apps.
                          I would not bother with a Quadro as it performance gain if any is not noticable for the difference in price and then it's also a very limited card and chocks with heavy video editing.
                            Impressive model. Is that each brick modelled?
                            I'm very interested in what you did with the brick wall on the left side of the model, where the bricks are visible only in spots. (Has this model been talked about in another thread?)
                            • soloS
                              Thanks.
                              Yes the bricks are all modeled, on the left side I used a random push pulll to get varying depths so giving the appearance of inconsistant showing and on the other side of the road it's standard depth for clean brick appearance.
                              This model is being used for an in-game video, my part is done (the modeling) the complete model is being textured at moment by another contractor and will be finally compiled in Max or Maya (not sure as my part is only initial modeling)
                              I have not really discussed this model as it's part of a bigger city model that I cannot show due to a NDA.
                                I'll have to try that technique on my Discworld model; I want worn cobble stones in the streets; http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=18393
                                • soloS
                                  Seen this?
                                  404 Not Found
                                  (www.sketchucation.com)
                                    (I'll continue in that thread. πŸ˜‰ )
                                    • soloS
                                      I did a performance video of the partial model, it's 126MB, has 1.8 million faces and double edges.
                                      Even with shadows on it was smooth, this does not orbit well on any other machine I tried, and not at all with shadows on.
                                      [flash=600,355:2xd6zd10]http://www.youtube.com/watch/v/XlW0fYb7dZQ[/flash:2xd6zd10]
                                        That's impressive. Didn't see it degrade to wireframe at all.
                                        • soloS
                                          I did a fast and dirty 8 second animation in Vue, just added two cars and an atmosphere, put extra motion blur for drunk effect. rendered in 26 minutes.
                                          [flash=640,400:2xa87muf]http://www.youtube.com/watch/v/Mng2dgFxzIs[/flash:2xa87muf]
                                          • Chris FullmerC
                                            Thats really impressive Solo!
                                            I still feel like I'm missing something about Vue. Hopefully I'll figure it out in time, I'd really like to use that software.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 20
                                            • 21
                                            • 13 / 21
