    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 481.9k Views 114 Watching
      dirtsailor2003
      Well I am almost ready to dive into the next round of layout with these plans. When I did the first elevations of this set the model was not 100% accurate or complete, but it was good enough for design review with the homeowners association. Since the model still needed to be creamed up a bit, we decided that the best way to handle this would be to create a component out of the model and open the component in a whole new drawing so that we could remove the color and such. Theory being that we could reload the model as it was updated and then not have to make many changes, and then the model would stay the same in layout. Good in theory, but with some quirks. In my new Sketchup drawing I had removed all the colors, set up all the shadowing, scenes, styles, and section cuts, etc... When I reloaded the the component of our model, all the stuff that I had done in my new model was wiped and the scenes, shadowing, and section cuts from the original model came in instead. Materials that had not been edited in the original model remained without color, those that had been edited or re-applied once again had color (this I had suspected would happen). I was surprised that my shadow settings and section cuts had changed. The shadow thing isn't all that bad, but putting the section cuts back in so that they line up perfect again to match my masking in layout may prove to be a pain. So I guess lesson learned set up sections and shadowing in original model if going this route. Today will be an all out push on getting these done so I will post something later this week showing the results.
        redinhawaii
        I resorted to 10pt, and that worked fine.
        I too, did the dimensioning in SU, the text in LO...
        got my first set to the building department today..
        I have lots of questions still though.
        I will keep you posted as to progress.
        aloha
        red
          baseLINE
          Keep your eyes peeled to this discussion - I'm working right now on a paired SketchUp / Layout template (whenever I get a spare minute) that I plan to post. This would have sections, styles, layers, etc all set up beforehand - simply build your model on the template and CDs would be easy to export.
          As for dimensions, I put my dimensions on a separate layer within my SU model and then link them in layout as an overlay.
          Template should be up by appx. May 1.
          kyle
          • SERGIOS Offline
            SERGIO
            Great!!
            I'm very impatient to see your paired template!!!
            (In metrics or inches and feet?)
            Serge from Paris!!
              linea
              I have been keeping an eye on this thread. Good topic.
              I agree with the view that layout and sketchup seem so near to being a BIM solution but I also think the potential for SU and Doublecad needs some serious consideration too. I have been using Doublecad every day for about 3 weeks now. To me, (general cad aside - which it is great for too) Doublecad is where Layout should be, it's SU friendliness sits it in an interesting middle-ground between SU and cad and it's made me realise just how wide this gap was.
                Robert
                This is a very interesting thread and it encouraged me to open Layout for the first time and give it a try. I really like some of the features although I'm not ready to give up Datacad quite yet for my construction drawings 😄 I think it will work great for presentation drawings.
                I'm really impressed with the quality of the line work of the images included in the scrapbook and need to investigate how to duplicate, edit and ad my own images of equal quality...equal to the quality I can achieve drawing in Adobe Illustrator. Anyone been down that road before and care to share any tips or techniques or should that be on a new thread?
                Here's a few shots of my first attempt using Layout...WIP of a little pool house.
                Enjoying this forum very much,
                • SERGIOS Offline
                  SERGIO
                  kyle[/quote]
                  No news about it???
                  regards , Serge
                    Gjenio
                    kyle
                    I´m waiting too for this promising template!
                    Any news?
                      sintra
                      kyle
                      Any news?
                      Sounds good this really looking forward to seeing it and giving it a go 😎
                      • troyhomeT Offline
                        troyhome
                        can't wait to see this template!
                        IOviz.com
                        SU Pro 2024 PC
                          Bert
                          @arail1 said:
                          Bert - I make stairs and I would consider your drawings to be as much information as anyone would need to build accurately. In fact more often than not we're working with much less information. A question - which was more satisfying to you - modeling the object in the computer or actually building it?
                          arail1 sorry for beeing away so long
                          In fact, before I got acquainted with Sketchup, all my furnitures drawings were only pencil sketchs with all the unexpected errors!!
                          Now that I am getting used to Sketchup I realy appreciate creating the furnitures on screen and building them after. And as you probably have seen, Layout allows me to have a very decent document to take to the shop. I wish that there was more tutorials on how to make good print presentation for furniture. Beeing close to the seventies, it is no easy for me to master new techniques
                          Salutations (Best regards) Bert
                            redinhawaii
                            Bert,
                            I think you are right.
                            There needs to be more discussion about how to get the 3d models into working drawings within the SU/LO platform.
                            I know that is possible, and know that there are some folks out there doing various parts of "construction documents".
                            But the "work flow model" has yet to be discussed.
                            Specifically how go from creating to documenting utilizing layers, outliner, scenes, styles and text (how and where to put it in a model so that it translates into LO documents easily)
                            If anyone has any experience and or insights on this I welcome your feedback.
                            aloha
                            red
                              I've been doing a fair number of furniture lately using SU and LO. I'm starting to get to grips with LO although I'm also finding some things I'd like to see made better. One of those is text handling (esp. tables) and rendering speed. Still, LO beats alternatives where one would export images from SU and put those images into the document. Very frequently changes are being made to the SU model up to near the end. It's valuable to have those changes get transferred to the plan document.
                              As an example, here are some thumbnails of a recent one. It's pretty simple as they go.
                              http://img.photobucket.com/albums/v506/weekender410/Bench/WorkBench2a_1.jpg
                              http://img.photobucket.com/albums/v506/weekender410/Bench/WorkBench2a_2.jpg
                              http://img.photobucket.com/albums/v506/weekender410/Bench/WorkBench2a_3.jpg
                              http://img.photobucket.com/albums/v506/weekender410/Bench/WorkBench2a_4.jpg
                              The last page contains a cutlist and BOM which were generated directly from the SketchUp model.
                              • DavidBoulderD Offline
                                DavidBoulder
                                Dave, that looks really nice. Any chance of posting it as a higher res PDF. Would be interested to know the workflow for the table. I haven't done anything with tables yet, and pulling data from SketchUp.
                                David Goldwasser
                                OpenStudio Developer
                                National Renewable Energy Laboratory
                                  Thank you David,
                                  I shouldn't post higher res images due to copyright restrictions. I don't hold the copyright on it.
                                  The workflow basically consists of drawing the complete model, making a number of scenes showing the various parts, adding some dimensions where needed and then sending it off to Layout. The callouts are all added in Layout. Body text is imported from a saved RTF file. The table on the last sheet was created from a cutlist exported out of SketchUp. I massaged the table in Excel, copied it to Word and converted from table to text and then copied it to Layout. sounds bad but it goes very quickly.
                                    redinhawaii
                                    Is this concept DEAD?
                                    I really can see the value of designing, modeling and illustrating how things are to be built in 3d rather than 2d.
                                    I see the value in creating "live, linked" models that can be viewed, modified, "taken apart" and rendered via SketchUp / LayOut / Google Earth.
                                    And I see a lot of "missing links" to tie these concept to real world needs like working drawings, drawing documentation, building permit plans, details, door and window schedules, etc.
                                    I see the value in a "semi-open source" software app, like SU, where there are lots of independent developers working on unique, specific supportive plugins/applications that make the software, much more vibrant, and adaptive and alive.
                                    Initially I felt that SU could be / do that. Maybe now is just too early in the software application / development / intention.
                                    I tried to do working drawings, construction docs in SU/LO, lots of hours and ended up with a lot of frustrations and the realization that maybe I was trying to do something the hard way. Maybe I have a zebra at a horse race.
                                    I also don't see Google interested in supporting this concept/potential for SU/LO. In my searching I find only a few people actually doing working drawings/construction docs, and those that are doing them are only doing small scale projects, i.e. kitchen bath remodel in SU/LO.
                                    I am on a Mac, but it seems, that those I have talked to are doing what I need much more efficiently on software like Chief Architect.
                                    any insights or perspectives would be most appreciated.
                                    aloha
                                    red
                                    • troyhomeT Offline
                                      troyhome
                                      I would like to see more support for working drawings in LO. I am on a Mac, running XP in Bootcamp. I am about to begin a small renovation project and plan on using SU and LO exclusively. I will try and post my progress and maybe get some help/feedback that could be useful to others trying the same thing.
                                      IOviz.com
                                      SU Pro 2024 PC
                                        I don't think this concept is dead, Red.
                                        I'm still make construction and working drawings in Layout. I just finished one this morning in fact as well as another one yesterday. Here are some image exports from this morning's project. I realize this isn't the same as con docs for buildings.
                                        http://farm4.static.flickr.com/3557/3601296462_653323c3f5.jpg
                                        http://farm4.static.flickr.com/3373/3601296262_e81d6f1355.jpg
                                        And I made full size patterns for cutting out the hard parts.
                                        http://farm3.static.flickr.com/2472/3600484473_3e85650aa0.jpg
                                        • fionmacoolF Offline
                                          fionmacool
                                          Hello, Sorry I didn't check out this conversation earlier.
                                          I am a SketchUp fanatic, architect and registered Google SketchUp Trainer.
                                          I don't use CAD, but I use SketchUp to do all of my construction drawings. So far, I have carried out a commercial project worth roughly $1m, and a complicated house construction cost €0.5m without using CAD or any other type of software.
                                          Please check out this link to a video showing some of the work I have done http://www.youtube.com/watch?v=8jw-q409XZc
                                          Here is a link to some further images showing my working drawings along with random photos of the built projects: http://picasaweb.google.com/sketchupireland/ViewsionAspireArchitecturePortfolioDrawings02?feat=directlink
                                          We have a Google SketchUp ATC company called viewsion: http://www.viewsion.ie, and we have the world's first advanced training program for SketchUp users that shows how to create the type of drawings illustrated above. (I hope you don't mind the plug. It's the only one I'll submit here.)
                                          Please let us know what you think. We would love to get to the bottom of this debate about SketchUp because we think it is the ultimate future for this amazing software.
                                          Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                            tim
                                            I've also used SUPro & LO to prepare drawings for several projects including furniture, engineering parts and even my new house. I'm sure there are parts of the work that more expensive software can do better (sections and detail views come to mind) but having looked a few other packages I really can't say I like the UIs.
                                            It would be nice if SU did the equivalent of the 'Add Section-Cut Face' plugin automatically as cuts happened. It would be nice to be able to set a suitable pattern for the cut-face to show the materials. I guess it would be nice if SU actually behaved as a solid modeller when you have a solid item.
                                            It would be nice if LO could do the dimensioning and if the labels and texts in LO could attach to locations in the SU model so that altering the view didn't mess up the placement of said labels and texts.
                                            But despite the above I managed to produce a precisely drawn model of a house, make dimensioned views of it, provide a variety of sectional views, several detail sub-views, annotate it all, put it together and build myself a pretty comprehensive set of plans. I'd provide a copy for perusal if I could find a way to persuade this damn forum to accept my file....
                                            • 22
                                            • 23
                                            • 3 / 23
