    Glass Challenge (all render engines)
    148 Posts 47 Posters 40.4k Views 47 Watching
    • K
      kwistenbiebel
      caustics for sure ๐Ÿ˜„
      • FrederikF
        Frederik
        Let me give you caustic... ๐Ÿ˜„
        Cheers
        Kim Frederik
        • EarthMoverE
          EarthMover
          Another try with Vray for Max. Modeling done by me as well. Thanks Ande for the tutorial...it was really helpful.
          Content Creator at Skapeup
          • brodieB
            brodie
            Here's another Maxwell rendering. Nothing special going on, this is simply the default glass material and water (default, meaning made through the Wizard via studio).
            • brodieB
              brodie
              A lot of these renderings have been really great. I think for the next thread it would be interesting if there were more of a benchmark. Ideally, a real photograph along with the setup (light & camera positions as well as information like wattage, type of light, camera settings, etc.). It would be interesting, after having seen all of these examples, to get a better idea of accuracy as well.
              -Brodie
              • EarthMoverE
                EarthMover
                I like the looseness of the challenge....it leaves a lot for interpretation. I do see your point about comparing apples to apples though.
                I think a good one for the next challenge would be - Candle. I would be a good opportunity to see how render engines handle SSS in the wax and lighting tricks for the flame.
                • soloS
                  Good idea.
                  • majidM
                    majid
                    so sorry for long time ... i re rendered last scene
                    • soloS
                      Majid, that looks a little screwed up ๐Ÿ˜‰
                        That looks really nice. The colours of the liquid looks really nice.
                        • C
                          cadmunkey
                          I think this is the best one yet, get a bit more light in to create heavier caustics and end this thread cos we have a winner! ๐Ÿ‘
                          • brodieB
                            brodie
                            majid,
                            Very nice. I like the bubbles and water droplets you added to this one. The glass looks a bit too green in this one, but other than that, good job.
                              dpimpc
                              Others may be flashier, but I don't think any come close to the realism of this. Its simple and pure, very convincing. Easily the best imo.
                              'Architecture is the art of how to waste space...'
                              • EarthMoverE
                                EarthMover
                                My favorite is Stefan I think. That one that Andeciuala (sp?) did with the condensation on the glass is beyond amazing too.
                                  MrPlanet
                                  My first ever render, its a bit noisy, but i like it--Indigo
                                  I reject your reality and substitute my own.
                                  • soloS
                                    Shreeyam, great first render ๐Ÿ‘
                                    • massimoM
                                      massimo Moderator
                                      This is my try with Kerkythea. I'm totally new to rendering. It's a young Barbera del Monferrato...
                                      • brodieB
                                        brodie
                                        Modelhead, thanks. It is indeed stock materials. Well, not really stock but Maxwell has a wizard for setting up materials (glass, satin, glass, car paint, plastic, candle wax, etc.). I just ran through the wizard and kept all the default settings.
                                        I had tried some of the materials that people have created and posted to Maxwell's website but those are sort of hit or miss sometimes and didn't seem quite right. I've found that Maxwell has gone to great lengths to be as physically accurate as possible in their setups. If you've never used it before it's a bit daunting at first because you have so much control over things like how much ozone & water are in the atmosphere, the reflectance of the earth, sun temperature, camera diaghram size, etc. But I've found that the defaults on all those things tend to give the best results so there's rarely a need to tweak some of the more complicated adjustments. In the end I've found it to be a rather easy tool to use.
                                        The renderings take longer than a biased rendering engine (which is the usual complaint I hear from people) but I've found the learning curve and perhaps material settings take less time (at least for me). I can render overnight while I'm sleeping, but I can't create perfect materials.
                                        -Brodie
                                          Dantheman
                                          A SU user in train land... to see my work go here
                                          • majidM
                                            majid
                                            nice render ...for the first times
                                            • 7 / 8
