    Soft Shadows
    extensions
    43 Posts 6 Posters 13.1k Views 6 Watching
    • B
      BTM
      In my post I was mostly talking about style watermarks, and I don't quite get what you mean...
      Anyways, here's the file, containing the style, and another style I made (not as good, but good concept. I should improve it...). They both use sketchy edges from one of the sketchy style in the style competition winners folder.
      a bunch of google components in a simple scene... styles in model, and also found in components/materials/styles part of SCF.
      • Al HartA
        Al Hart
        BTM - Here is a Sketchy Shadows example using your texture (I rotated it for repeats) for the shadow mask.
        This could be done better with a little more effort, but I wanted to give you and others an idea of how you can use your own textures to define the Sketchy Shadows.
        Al Hart
        IRender nXt from Render Plus
        • Al HartA
          Al Hart
          Thanks for sending the model. You did have masking turned on for the watermark. It didn't quite work the way I thought it did (I thought it applied the watermark to only the model and not the background when masking was on. But that is not what masking does.)
          Al Hart
          • B
            BTM
            Nice! šŸ˜„
            I tried making a tillable version of the texture using gimp.
            Didn't know how big it should be, so it's pretty massive.
            ...and another possible one.
            doesn't work too well as a style watermark, maybe as a shadow one though. Who knows.
            • B
              BTM
              that's because I added sky and ground, I thought it looked better šŸ˜‰
              Oh, and sorry, I have a habit of editing my posts after I post them 😳
              • Al HartA
                Al Hart
                Here are the Sketchy Shadows with you tileable mask.
                Thanks for the help with this. Hopefully we will get the Beta Test version of NprTools out soon so that you and others can try this yourself.
                Al Hart
                • Al HartA
                  Al Hart
                  BTM - If you get a chance send me two tileable sketches for Criss Cross (a separate for image for left to right, and for right to left). I am working on a concept where I will use the only the first image for the light parts of the shadows, and combine both images for the dark parts of the shadows. It would be great if I could have some good images to use for this.
                  The first image will go from light to dark in the 1st 1/2 of shadow intensity, and then the first image will stay dark as the second image goes from light to dark as the shadow intensity goes from 50% to 100%. (If that makes any sense. If not, send me the images and I can show you)
                  Al Hart
                  • Al HartA
                    Al Hart
                    Your images are awfully similar - but that may be all right (You would be a better judge of that then me)
                    Don't worry about quality - we can improve that after we see if the idea works.
                    (I am planning to offer you a free copy of NprTools in exchange for 6 to 10 images which I can include in it. Not a great deal for you because I don't think we will charge much for NprTools. I have already offered free copies to everyone who has helped with it - and that just about equal the number of people who might be interested in it when it is done.)
                    I suspect that the individual lines may be too thick. You should paste the two images on top of each other to make sure you are happy the effect the cross hatch will have.
                    (This isn't quite right - because I simple pasted them together rather than blending them together.)
                    Here is a sample from another web site.
                    http://i.ehow.com/images/GlobalPhoto/Articles/2097625/Crosshatching6robertsloan2_Full.jpg
                    I don't really like their result, but it reminds me that I may want too allow 3 or 4 layers instead of just 2.
                    I am trying to achieve an effect something like this.
                    Al Hart
                    • B
                      BTM
                      Ah, don't worry, I think I know what you mean. šŸ˜„
                      First set just made Tile-able with GIMP, second was edited to match up better in the texture.
                      _First set:
                      _Edited set:
                      All images were done with a 6B pencil.
                      The tiled images aren't that big, so they might not look too good. I can redo them in a few minutes though.
                      • B
                        BTM
                        Hmm... My post was a bit messed up. you were right about them being similar, I just flipped them vertically, and the latter (better) 2 images are messed up, and are showing the same one šŸ˜•
                        i'll try to make some thinner lines (more detailed too). Might get them up soon, or have to wait 'till tomorrow.
                        • Al HartA
                          Al Hart
                          And you need to stop editing your posts after I have already started my reply.
                          Al Hart
                          • Al HartA
                            Al Hart
                            Thanks - I'll give them a try - but it may take a day or two...
                            Al Hart
                            • B
                              BTM
                              😳 , again.
                              ... Newer cross-hatching textures
                              Oh, and i don't know how well these will work, but I made tile-able thinner lines.
                              1st
                              2nd
                              3rd
                              4th
                              This is slt3 turned on it's side, which could be the 5th layer if you wanted to go that far.
                              Don't pay attention to the file names, they aren't in any order at all šŸ˜‰
                              This is what sketchup looks like if they're all set as tiled masks at once, with black background and white fog.
                              • B
                                BTM
                                ... Tomorrow I'll probably make another set, more of a straight-thin-pencil style though.
                                • Al HartA
                                  Al Hart
                                  Thanks for the pattern, BTM. I got the criss-cross shadows to work - the first pattern is used for the lighter parts of the shadow, and the second pattern is brought in for the darker parts (and overlayed over the first pattern).
                                  Also, I made these shadows red (someone had requested colored shadows, so I added a shadow color button) (I can't see that they are red. (Someone just told me that this model didn't look very good. Pay attention to the technology of the shadows, not the model or the final result. If someone has a small model which would be better for these examples, sent it to me.)
                                  Al Hart
                                  • Chris FullmerC
                                    I like it a lot on the house shadow that is cast on the ground. Any chance of seeing it with a regular grey shadow instead of the red? Its really looking great Al!
                                    • Al HartA
                                      Al Hart
                                      Good to hear from you again - this whole "soft shadow" think came from your idea of taking several (64 or so) images moving the sun around, and combining them to get softer shadows. As a result you will get a free copy of NprTools when it is delivered.
                                      Send me a model you would like to see some soft shadows on, and I will run it through as a test case.
                                      Al Hart
                                      • Chris FullmerC
                                        Oh I've been eagerly watching this thread Al. I think the soft shadows are coming along very well. I genereally prefer them with no hatching, but the criss-cross pattern on the last one is actually quite nice I think. I think it has to do with the density of the strokes. They are closer and tighter in that example than they have been in some of the others. I like that best.
                                        Anyhow, its coming along really well. I'll find a model and PM it to you. Keep it up!
                                        • Al HartA
                                          Al Hart
                                          Thanks,
                                          I'd like to try another model.
                                          I'm getting tired of looking at this one.
                                          There are a lot of settings here for density, color, transparency, pattern, blurring, etc. which you will be able to use when I get the Beta out.
                                          Al Hart
                                          • B
                                            BTM
                                            Soft shadows could probably be good for indoor scenes (windows). Maybe you should make some indoor scenes, as well as outdoors.
                                            With your input, this post could be even better šŸ’—
                                            • 1 / 3
