    Applying one material for the whole model
    10 Posts 5 Posters 833 Views 5 Watching
      altap
      Hi!
      how to apply apply one material for a model with componants and groups that have different ones ?
      Do i have to explode each entity and then apply the material?
      thanks
      • Chris FullmerC Offline
        You could open the material browser and delete all materials, then select all and apply your single material that way, if deleteing them all is an option.
        There is probably also a ruby script that could help?
          remus
          Select the brush tool->ctrl-a->click one of the selected bits.
          edit: my method doesnt work for materials applied inside a group/components, as you say chris.
            but if you've directly painted faces within any components, that won't over-ride those materials.
              altap
              hi & thanks both of you !
              i'll try that Chris...Thanks.
                altap
                hi again!
                sorry to ask again, is there any ruby script that could do this automatically ?!
                  You can use this to remove all materials from a model. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17587
                  Once all materials are used you can change the default material colours in the Style window.
                    altap
                    Thanks you very much Thomthom
                      My GlobalMaterialChanger.rb [ http://www.sketchucation.com/forums/scf/viewtopic.php?p=96863#p96863 ]also has the option to specify <<ALL>> materials and then set any material to replace that [including <<DEFAULT>>]. You are asked if it's to 'mine' down into groups and instances too....
                        altap
                        hi!
                        it is really wondeful to see what sketchup community is doing to improve it even with "little" rubies like this one..and for free...A GREEEEEEEEEEEEEEAT THANKS.
