    Subdivide and Smooth Feature Requests
    extensions
    63 Posts 25 Posters 19.4k Views 25 Watching
    • ely862meE
      ely862me
      i don t know if u can make a chamfer tool..this will be great and save a lot of work(at last for me)
      the only bad thing and decisive is that SU works with triangulation 😐,and because of this is almost impossible to create chamfer
      Elisei (sketchupper)
      Come and See EliseiDesign
      • bazB
        baz
        perhaps 'sketchy bevel' by chris philips would do this for you? It draws chamfers.
        baz
        • ely862meE
          ely862me
          that is good for flat areas ,,on the triangulated areas it s a mess
          this is what i m talking about ..this is a normal meshthis is what i want for chamfer to do :adding one or more lines   to the selected linessds result after chamfersds result without chamfer
          • X
            xrok1
            Another question I have is this:
            Does anyone ever use the 'copy materials' option? It is slow and does not properly interpolate the UV coordinates. I had in mind to fix the UV issue but my preference would be to remove the feature entirely. It will always be slow and I wonder if there is any significant benefit to it. Fixing the UV issue will take a lot of time and I would rather devote time to other features. Any thoughts?
            it would be great if it worked, i think everyone would use it. if for nothing else than selection sets by material.
            • utilerU
              utiler
              Free or nominal Upgrade to those who bought?
              Has this been answered yet......? πŸ˜‰
              Just Curious...
                remus
                Whats so bad about the current SDS that you need a free upgrade to win you over?
                • utilerU
                  utiler
                  Nothing Remus, just wanting to keep up with the latest release....
                  Just Curious...
                  • W
                    Whaat
                    I really don't know the answer to this. It is too early to say. I really hope we can set up a system on Smustard to provide a nominal upgrade price for those who bought. As far as I know, Smustard is still not set up to do this. I know RickW was looking into this and I intend to ask him what the status is.
                    • utilerU
                      utiler
                      Thanks for the update Dale..... πŸ‘
                      Just Curious...
                        remus
                        Sorry for being a bit snappy there andrew, i thought you meant it in 'SDS wasnt worth the cash the first time so we should get a free upgrade' sort of way 😳 Thats obviously not the case.
                        • utilerU
                          utiler
                          Certainly not mate..... I wouldn't have spent hours creating an Australian Steel profiles library to upload if it wasn't worth it!!!!!
                          Just Curious...
                          • B
                            Bobby Cheung
                            Hi, i was wondering how can i add a thickness to a curved object'surface? eg like offsetting it. The reason of asking is let say if i have to creat a mould for a product, and i need to give a thickness to the rapid prototyping machine.
                              remus
                              Have a look at fred06's joint pushpull plugin (you should be able to find it in the ruby forum.) Sounds like it should do what your after.
                              • X
                                xrok1
                                could you not just have ver-3 and ver-3upgrade as two seperate scripts (products) on smustard?
                                  remus
                                  Whats to stop someone just buying the upgrade instead of the full version?
                                  • X
                                    xrok1
                                    make ver.3up dependant on one of the files from ver.2, maybe the icons or something. hell, i'm sure Whaat could figure something out. i know i don't want to pay full price for an upgrade thats for sure.
                                    • C
                                      Click Draw
                                      I'm a bit confused here. What profiles are you able to use in SDS? Are you maybe talking about profile builder?
                                      Jeff
                                      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                      • N
                                        notareal
                                        ely862me did address to most of my requests.
                                        • N
                                          notareal
                                          Don't want to have a unused scrip hanging in the plugins folder. But perhaps installer that looks existing subsmooth, removes it and then installs a new one, would do the trick.
                                          • utilerU
                                            utiler
                                            Jeff
                                            Sorry Jeff, yes, talking about PB... 😳
                                            Just Curious...
                                            • 2 / 4
