    [Plugin] Archiver.rb - update
    42 Posts 10 Posters 30.2k Views 10 Watching
      Glad its useful...
      If anyone else has any feedback (even critical !) please let me know...
        Jim
        @tig said:
        Glad its useful...
        What happens if you open an archived model, then use archiver again? Does the date-stamped filename get longer, or does the date-stamp get updated?
        Also, a good option may be to have a "branch" option. Branching would prompt for a new filename and save the model under that name. A branch might be used to experiment with variations in a model, then allow to switch back and forth between branches.
        Personally, I have turned off SketchUp Auto-save and am in the habit of hitting Ctrl-s (save) to save the model. So, maybe it could be tied to the built-in Model > Save through the onSaveModel ModelObserver.
        Just thoughts - I would consider it an essential plugin as it is. Thanks.
          If you open an archive and modify it and then archive it you will get another date-time stamp added to the end of its name, in another Archives folder within the original Archives folder... I'd recommend copying archives rather than using them direct since saving alterations overwrites the earlier version. That way you know which version of the model you are working on but keep the original archive unchanged... You can always open an archive and save_as Model-Option-B etc...
          Your 'branch' option is called 'design options' in Revit... At the moment you will need to save as a number of models and archive each as desired... Your 'Archiver+Option' would archive the current Model.skp make /Archives/Model[yy-mm-dd_hh-mm-ss].skp and then open a save_as dialog with suggested incremented option name - e.g. Model[Option-01].skp - you could always change what's inside the []. Work on that version and make archives etc as usual. Then perhaps you decide that you want to explore another variant... pick 'Archiver+Option' again - it then spots the [] on end of the name and suggests a save_as with an incremented name - e.g. Model[Option-02].skp etc etc... Option-01 to Option-99 would be the typical range...
          I'll see what I can clobber together... watch this space...
            Jim
            Well, as I said these are just ideas from a casual user, and things I don't strictly "need." Maybe some power-users can give more input.
              Here's v1.8
              It now has an extra menu option 'Archive Option'.
              This archives the file and then gives you a 'save_as' dialog -
              with the default new option's file-name entered as "Model[Option-01].skp" ..-02] etc.
              This 'option' 'number' is based on the highest value option found in the model's folder.
              You can overwrite an existing file if desired (you will be warned 1st).
              The current active model-window now opens with the latest option you have just saved.
              If you save a model as an 'option', then to be recognised as such it should have its name in the format "Model[Option-nn].skp" - it must have the surrounding "[..]" and a separating "-" between the number and any text; the string "Option" could be set in the save_as dialog to say something else, BUT since new options always use "[Option-nn]" anyway it's recommended to leave it unchanged.
              Please test and feedback...
              Archiver.rb
                Here's v1.9
                Minor change to 'Archive Option' - the original model is now saved immediately before it is archived and then saved as an Option.
                Usage:
                Pick 'Archiver' to make an archive copy of the current model.
                It saves the model (in its current state) into a sub-folder
                within the model's folder called 'Archives'. It's named with
                a [suffix] - date (yy-mm-dd_hh-mm-ss),
                e.g. Model[09-12-18_12-34-56].skp.
                The separators can be customized from '-' to '' etc,
                just change one line - sep="-" to sep="
                " etc...
                If later on you don't save the main model with those changes
                then that archive copy still has those changes current at the
                time of the archiving.
                If there is an 'Archives' folder then an extra 'File' menu
                item is added - "Open Archives"...
                'Archive Option' is an additional function that saves the model as it
                stands - say 'Model.skp' - then it makes an archive of it - say
                'Model[09-04-16_12-25-05].skp' and then opens a 'save_as' dialog in
                which it will have preset the next available unused Option name - say
                'Model[Option-01].skp' - which you are prompted to save_as: you can
                choose to overwrite an earlier option if desired - if so you are
                warned about overwriting it. The Options are kept in the same folder
                as the original. It is recommended that you do not change the naming
                convention... The model is then saved. The current SketchUp window
                then shows this latest Option.
                Options can be archived in the same way as other models - in the
                example above the archive's name might then be
                'Model[Option-01][09-04-16_12-30-55].skp'...
                If you subsequently use 'Archive Option' on an 'Option' itself it then
                names the new Option with the next available free Option name - in
                this case it would 'Model[Option-02].skp' and the process repeats...
                characters as separators so don't change the Option's
                name if you want it to be recognised as one by 'Archive Option'.
                Feedback please...
                Archiver.rb
                • jeff hammondJ
                  i'm not sure if i'm using 1.9 properly but here's what i'm getting...
                  it works the same as 1.7 in that if i select file->archiver, a archive will be created in a new folder inside the main model's folder.. file->open archives will allow me to search through/open files in the archive folder..
                  everything is fine there..
                  now,
                  if i select file->archive option it works exactly the same as when i use file->archiver except i now have a .tmp (ex- 1239979595.tmp) file saved in the main model's folder. no dialogs or options etc..
                    Sounds like a Mac problem [again]. Works fine on PC. Please run it with the Ruby Console open and report the error you get. The .tmp file is made so that the original and newly named copy can swap over - that's failing...
                    • jeff hammondJ
                      here's the error message:
                      Error: #<Errno::ENOENT: No such file or directory - \Users\jethro\Desktop\ARCHIVER_TEST>
                      /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in open' /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in entries'
                      /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in `option'
                      /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:255
                      that is after i have a model folder (ARCHIVER_TEST) with a couple of archives saved (they are in a folder created by the ruby called 'Archives' which resides inside the main folder.
                      it's looking like \ vs. / again?
                        It was \ versus / ! I suspected it - I have made an error in one step in the sub-routine for 'option'. I have just redone all of the path bits to ensure PC/Mac compatibility...
                        Here's v2.0 - it works OK on my PC AND should now work on your Mac too...
                        Sorry for the problem - I don't have access to a Mac to test this, so please report back...
                        For the latest version please see the PluginStore http://sketchucation.com/pluginstore?pln=Archiver
                        • jeff hammondJ
                          ok, that fixed it..
                          i only had a quick look at it as i'm about to leave for the day but it looks like there will only be one archives folder created now and i can view all the files related to the main folder via 'Open Archives'.
                          is that correct? if so, i like it!
                          i'll be able to check it out more thoroughly tonight but it's looking like a nice improvement.
                          thanks
                          • ToboboT
                            Tobobo
                            Thanks TIG
                            Toby
                            Philippians 4:13
                            • K
                              kaas
                              Could it be this plugin could use an update for V2014? If I use the Archiver option in the file menu - the current file gets renamed to some 10 digit name.tmp and no copy is made to the Archiver sub-directory. Windows7 X64
                                Archiver is one of a few scripts that doesn't work in v2014, because they completely changed how model.save works... It IS on my list of things to fix...
                                • K
                                  kaas
                                  Great TIG. Much appreciated.
                                    Version 2.1 is now available in the PluginStore - it is now made v2014 compatible...
                                      Version v2.2 is now available in the PluginStore:
                                      It has some minor coding tweaks for cross-version compatibilities.
                                      • H
                                        highco
                                        Hi Tig,
                                        Archiver is creating temp files in the directory where the *.skp model is.
                                        The "Archive" folder is created, but there is nothing in there.
                                        Changing the *.tmp extension to *.skp allows me to open the file ok.
                                        Using Win XP 64 Bit Pro and Sketchup 8
                                        Is that the way it is suppose to happen?
                                        Regards
                                        Terry
                                          It's supposed to use the tmp file as stepping stone, then rename files so you end up where you started, but with a saved 'snapshot' skp too...
                                          Anything unusual about the path where your SKP is, or its name etc ?
                                          Works OK for me...
                                          • H
                                            highco
                                            TIG,
                                            Have tried it in basic directory in C:\ and the same happens.
                                            Thought it may have been something to do with using DropBox, but that is not the case.
                                            *.TMP files are created, but nothing in the archives folder.
                                            See attached,
                                            Regards
                                            Terry
                                            PS Is there any way of debugging the Ruby script from my end, if that can be of any assistance,
                                            Regards
                                            T
                                            • 2 / 3
