🤑 30% Off | Artisan 2 on sale until April 30th Buy Now
Last GSU Survey - results
28 Posts 12 Posters 9.3k Views
    Error 404 (Not Found)!!1
    (sketchup.google.com)
      Huh!?
      What's 'shadow rendering'? do they mean fix shadow bug?
      The first step to recovery is acceptance.
        museummaker
        Higher poly's doesn't show up at all??
          They never had it as an option on the survey, only options were things that they might be able to fix, High poly support is a taboo topic to the GSU team as they have never mentioned it, aknowledged it or even responded to all the complaints and cries about it.
          SU's shelf life is nearing the end without it, start learning another app now before you find yourself redundant.
            Well,Pete, I hope you had a look at the other survey before posting.
              I just completed it, and it's a start but still 'High poly support' is not an option.
                Well, in my interpretation, if SU supported "new technology" (like 64 bit, multi-threading) and would perform much better at orbiting/panning (framerate things), THAT would be high poly support. Theoretically there's not limit even now - you can just not do anything after a while.
                  Not necessarily, firstly is SU multi core even possible? how will that be achieved?
                  64 bit I'm not sure about but from what I've heard it won't make much of an improvement in performance, however utelising more of the GPU may be interesting but again I cannot imagine how that will be achieved more efficiently than it already is.
                  But here I'm just speculating and would welcome a member of the Google team to put me on the right track...anyone??
                    Now look, I think it's already something that they are communicating about this (and any other issues) in public, with the users/customers. I really doubt that you can get any technical details out of them - especially before any official sign of a new version.
                    You have signed a couple of NDA's with them and exactly know how these things go.
                      tim
                      It's probably possible but potentially very difficult. I could imagine separating out user input events, inferencing, rendering, to separate threads but making it possible and useful to have multiple threads working on each is harder. A quarter of a century ago (eek!) I was working on solid modelling software; it was possible to make a parallel version to ray trace the voxel models (and we did - a 128 processor system) but it turned out that you could write a better algorithm that would run faster on a single cpu given the hardware of the day. Perhaps it's better now. Perhaps it isn't.
                      My understanding is that 64bit here really refers to using the 'proper' 64 bit instruction set in modern intel architectures. Don't forget that the Core 2 Duos etc that we are mostly using these days actually have a reasonable cpu and instruction set hidden away under all that nasty x86 (blech) wrapping. I think they run x86 code (puke) as a sort of spare time hobby, something to do while they do their real work. Which as we all know, is plotting the overthrow of the human race. With the proper instruction set in use you suddenly have a sensible number of registers, for example.
                        Maybe not for SU itself. But for Plugins that runs inside it. For instance, V-Ray would benefor from 64bit SketchUp.
                          OT: How come when I click on "Your Posts", sticky threads I've replied to is always marked as unread. Even though I'm the last to reply?
                            kwistenbiebel
                            I am not a coder so I don't know how to fix the issue, but the bottom line is : Sketchup is slow as a snail.
                            And I am glad I never had to sign an NDA... What's the point signing a contract to keep secrecy about minor features and having to shut up about the things that really matter?....
                            They are doing an effort though to ask about the issue in the current survey .
                            I do wonder why they don't ask all the questions in one single survey and get it over with. At the pace they are doing these seperate surveys, they clearly aren't thinking about starting work on v8 any time soon...Moving on to other apps for some tasks is not a bad idea.
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/2-1.jpg
                            • E Offline
                              Edson
                              i have been wondering if @last first and then google ever expected that SUp would be used the way some of us do, that is, for complex and detailed design work, which amounts, of course, to huge files with very high poly counts. as its creators probably never expected it to be used beyond the sketchy design phase or for more than empty buildings with little detail SUp's performance with high poly models was never an issue. until now.
                              it really bothers me that no matter how well organized my models are (and they really are) there is always a point beyond which navigating between different scenes becomes painful and time consuming.
                              this is the problem, pete: which app? of course there are other apps that would tackle high poly models without any problems but they are not geared to design work. i do not know of any other app that would allow me to work in architecture in a way similar to SUp. i would thank anyone who would suggest some app comparable to SUp so that i could follow your advice.
                              http://www.mahfuz.arq.br
                                I think it's wrong to look at it as an "either-or" situation. Why completely replace SU? Use it for what it's worth. And use other tools to complement it. I have plans to look at Vue for vegetation modelling and rendering where SU tends to crawl to a halt. I'll still model the initial model in SU, but then take it into Vue for detailing.
                                I also have plans for a larger city model. Where each house can be modelled in SU. But I'm considering using another application to store the whole city model as it grows. Not sure which yet.
                                  remus
                                  I think you will find that in most apps, it's just SU reaches the 'frustrating level' faster than a lot of other modellers.
                                  • E Offline
                                    Edson
                                    thomas, you are right. it is a wise way of looking at it. let us know when you find that other application.
                                      I have been working that way recently, using Max to accumulate my scene from SU models.
                                      The problem there is the triangulation and grouping within SU which seems so foriegn in other apps.
                                      I can build identical models in say MOI, Rhino or Hexagon and export to Max and the size is roughly the same, however making the same shape in SU (which is quicker and easier) exports roughly 3 times larger than the other modelers.
                                        Yea, I'm not impressed with SU's importer and exporters. Importers are the worst. Only .3ds (old with many limitations + buggy importer) or DWG (no materials).
                                          I recently did a test, I created a shape in SU using SDS it was 203kb as a .skp, I then exported it using native SU pro .3ds exporter and the size inflated to 341kb, I then opened the .skp in Deep exploration and converted it to .3ds and the size was 246kb. I compared them in Max and could not see any difference, they were identical.
                                          1 / 2
