    PDF export bug? Includes example figures
    39 Posts 7 Posters 7.8k Views 7 Watching
    • Chris FullmerC
      You should be able to open it into layout directly. Go to the Vista start button thing and type in layout. It should come up. (or look for it through Program>Google>Sketchup 7> Layout if that is more a familiar route). Then just start it from there and you can open a sketchup file directly from it.
      If you can't find it on your system, then it must not be installed? So perhaps try reinstalling SU.
      Also, thinking about Vista's security "features" it might not let SU open another program. I have not tried it to be sure though.
      • GaieusG
        Or you should be able to just drag the skp file onto the LO icon and it opens automatically.
          midlana42
          Oh no, I have no problem opening LayOut. However, once I'm in it, I can neither view nor load SU files. They simply don't appear in the directory because LO is looking for only .layout files. If I then switch to . file types I can then of course see them, but attempting to load a .skb, I get an expected message box, "Error reading LayOut file".
          This is wierd; It's almost like I have a different version of code than you guys...
          Regarding all the tricks that can be done to make it work, like I said before, I have dozens of drawings to deal with. I just don't have time to babysit a bugged application to make it work. If it was one file, sure, fine, but for all of them? No.
          Please understand I appreciate the help and you guys are just trying to find a way to make it work for me. It's just too much work do do the same on every drawing.
          • GaieusG
            No. You don't "Open" an skp file in LO but "Insert" it from the same, main File menu (just lower). There you can select image files to insert as well. It's like importing in SU.
              midlana42
              I just tried that and while it does open LO, the workspace is blank.
              I also made sure I'm running LO in Admin mode (which can cause trouble if not done) but it made no difference.
              • GaieusG
                It must be some system problem then. The two apps work very fine (and interactively) together, really.
                I'm sorry but I can't really advise on Vista.
                  midlana42
                  Understood, could be. However, it doesn't get Google off the hook since they claim it works with Vista.
                  • GaieusG
                    Yes, in LO. If it's greyed out, there must definitely be some problem. There are lots of folks who use it with Vista though. It's just me who is stopped here.
                      midlana42
                      I don't follow. Is the above when I'm in LO? If so, "File>Insert" is grayed-out.
                        midlana42
                        Okay, my bad, I didn't have a paper sheet in the LO workspace. Now File>Insert is active so I selected it and Inserted the .skb file. It did it but took a long time... anyhow, I then exported it, put it in the manuscript and printed it out. Looks better, though the picture is now about half-size... huh?
                        Well okay, so it is possible to make it work, squeeling like a pig bent over a barrel, but I digress. Thanks for all the help guys.
                        • jeff hammondJ
                          do you have a document open (even if it's only a blank template) when trying file->insert? is the 'save as' option greyed out as well?
                          my 'Insert...' option is greyed out too if i don't have a document open to insert in to..
                          [Edit] nevermind πŸ˜„
                          • GaieusG
                            You can always resize the SU viewport in LO to fit the page or whatever. You can even print to scale and all.
                            As for the quality; did you do any settings?
                              midlana42
                              I left it at medium just to see how it would turn out, and yes, I went back in and resized it successfully. Timewise I should probably leave all figures as PNGs just to get on with things, then when the manuscript is done, bite the bullet and convert all figures into PDFs.
                              Again, thanks a lot guys. It's good to know it can at least be done, warts and all.
                              [edit] Oh, and if anyone's interested, the figure is part of a tube-frame chassis of a sports car. If you ever considered building a car from scratch, check out http://www.midlana.com/
                                @thomthom said:
                                Any chance you can post the two PDFs Jeff? I'd like to poke around at something...
                                sorry for the delay.. i left right after i posted that..
                                here they are. i just exported them with the default settings as a quick test.. i didn't try to match them up size wise but it's interesting that the layout version is 6x the size.. (maybe something to do with layout keeping the background color intact.. probably keeping other things intact as well.?)
                                Thanks.
                                The reason for Layout's PDF being different, also in size, where as I suspected due to that SU exports a PDF with vector lines while Layout exports a PDF with an embedded bitmap image. So if you want vector output, you can't use Layout. Not sure what format LO uses to embed the image, but I don't think it's JPEG, I couldn't see any compression artefacts. Maybe PNG...
                                • GaieusG
                                  It is png (the files you can find in the *.layout file after renaming it to zip - actually, if you uncheck "Background" in the LO tray for the SU model and you don't have sky and ground on, this is a png file with transparent background so it can easily be used for various things).
                                  Also, AFAIK only the Mac can export vector based pdf even from SU, isn't that correct?
                                    Incorrect, at least for SU. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16156&st=0&sk=t&sd=a&start=15#p130313
                                    Not sure about LO. I have a Mac, but not with Pro version.
                                      midlana42
                                      Wait... you're saying the "PDF" from LO is actually a PNG? Comparing the outputs it looks better than PNG, or maybe I'm imagining things.
                                        Yes. It's not vector, it's a bitmap. So it'd be the same as exporting a 2D bitmap and wrapping it in a PDF.
                                        I don't know what it is that looks better. To me it looks the same. Might you not have exported in large enough resolution when you have previously tried PNG?
                                        You're not comparing against a JPEG where you might see the compression artefacts?
                                        • GaieusG
                                          OK, my bad. I haven't had the need yet to export to vector pdf. Thanks anyway.
                                          • AnssiA
                                            Anssi
                                            SU exports only vector PDFs, to get a raster PDF you will have to print using some PDF printer and with "Use High-accuracy HLR" DISabled.
                                            Layout can export either vector or bitmap, and also a hybrid file (with vector lines on top of the bitmap textures and shadows).
                                            Anssi
                                            • 2 / 2
