    Call to Mac users for script portability
    101 Posts 10 Posters 15.8k Views 10 Watching
    • T
      torben.wadlinger
      Hi Fredo6!
      I think your main problem in catching the F-Keys is, that on a Mac the internal keycodes of the F-Keys are not the same as on a PC/Windows.
      Torben
      • jeff hammondJ
        i tried the two new files and nothing changed as far as the dialog box goes.
        with those files, the arrow keys no longer work nor does the shift key for locking protractor orientation but the tab key does. also, no change to the function keys.
        the reset icons do not show up but in the video, you'll see that there is a space designated by a square and it is functional. i can reset the individual default parameters by clicking the square.
        1. If Function Keys are not ideal on Mac, do you have any suggestion of other shortcuts than could be used instead ?
        if those functions (ie- activate slicer, toggle wireframe, etc.) were placed in the menu or a submenu then we could assign our own keys but that pretty much defeats the purpose of what you're trying to do..
        like i said earlier, i can assign the F keys as shortcuts and they work fine. (i tried F4 as the protractor shortcut and it works as expected).. Torben is probably right in that the keycodes are different than with windows.
        if it helps at all, here are the key identifiers for the F keys on macs:
        F1 - 63236
        F2 - 63237
        F3 - 63238
        F4 - 63239
        F5 - 63240
        F6 - 63241
        F7 - 63242
        F8 - 63243
        • fredo6F
          Do you mean that the Arrow keys, Shift and Ctrl were working fine before the new file?
          • jeff hammondJ
            yes, before i replaced the files with the two you posted in this thread, i was able to use the arrow keys to change the protractor's orientation (up-blue, left-green, right-red) or i could get the orientation by putting the protractor on a certain plane and locking its position via the shift key...
            after i replaced the files with the new ones, none of those functions worked..
            i've since changed back to the original files 😄
            • fredo6F
              Jeff,
              Sorry for that.
              Would you mind to try with the attched file.
              Please open the Ruby console, where I trace the keys typed up and down.
              If you can try with the Function key, say F2, F3, then I could figure out what are the code and flags sent by Sketchup.
              I hope I have at least restored the arrows and Shift / CTRL
              PS: on Mac it is appently normal that CTRL maps to Command key, as in native Sketchup
              to drop in LIBFREDO6_Dir_31 subfolder
              • fredo6F
                For Web dialogs, I really don't know what's going on.
                By chance, is there on Mac, like in Windows, a contextual menu where you can do a Refresh and see the source code?
                • takesh hT
                  takesh h
                  I think, with the new "Lib6Traductor_31.rb", arrow keys work, Fkeys that are not assigned shortcuts in SU work, Alt/Option key still works as Ctrl key. I couldn't test Shift key.
                  Below I copied and pasted what was in Ruby console when I typed Fkeys.
                  F2
                  Key Mac 63237 flags = 0 up = false
                  Key Mac 63237 flags = 8388864 up = true
                  F3
                  Key Mac 63238 flags = 8388864 up = true
                  F4
                  Key Mac 63239 flags = 0 up = false
                  Key Mac 63239 flags = 8388864 up = true
                  F5
                  Key Mac 63240 flags = 8388864 up = true
                  • jeff hammondJ
                    Jeff,
                    Sorry for that.
                    the function keys now function! shift works, the arrow keys work.. everything with the keys work
                    • fredo6F
                      Glad to see that this works now.
                      That was an error on the codes for Function keys on MAC.
                      To test Shift, just use any of the tool and toggle SHIFT to either select all connected geometry or just an edge or face. That will show if this works.
                      Attached is the file without the trace
                      • fredo6F
                        For Web Dialogs, I have made a slight change to open the windows in a bigger size, and then try to resize.
                        Do you notice any difference.
                        PS: actually, the test is also to know if I have a problem with SU Web dialogs or with Safari.
                        • jeff hammondJ
                          a little info about macs and F keys... the keys became programmed as volume, brightness, etc. because of the laptops.. there wasn't enough space on the keyboards for these controls so apple took over the F keys for that purpose..
                          on your keyboard, you'll notice a key called fn.. that's basically like a shift key for the function keys.. it allows F4 etc to perform double duty..
                          if you want to use F4 in freescale, you have to push fn/F4 together.. if you push F4 by itself, the dashboard will pop up.. in the system prefs (i mentioned this earlier in the thread), you can flip this around to where the F keys will work as they used to and the assigned functions will only work if you press the fn key as well (ie- fn/F10 for mute)
                          • jeff hammondJ
                            ok, so the window opens up nearly twice the size as it use to but it very quickly goes back to the original size only now it's near the bottom of the screen.. nothing has change other than the location of where it's at on the screen.. it happens so fast that i can't see if the save/reset buttons are appearing or not on the initial opening.
                            also, i'm not sure if you have this going straight to safari or not but earlier, i tried setting my default browser to firefox and everything stayed the same...
                            earlier you asked "By chance, is there on Mac, like in Windows, a contextual menu where you can do a Refresh and see the source code?"
                            i don't really know my way around that stuff but it does exist. i pretty much keep it on the GUI side of things.. i wouldn't be much help with code
                            [EDIT]-oh wait, you said 'code' and i started getting scared 😄.. if you mean is there a way to view the source code for a page in safari then yeah, it's easy.. right-click/view source
                            • fredo6F
                              Jeff and Takeshi,
                              If you can right-click in the dialog box, then could you select the menu "Refresh" if there is one.
                              Attached is an updated file to avoid the resizing, so that you can possibly check whether the whole content of the dialog box is displayed or not. Keep the previous Lib6Config_31.rb (which open the box with a big size).
                              I am still wondering why SU does not show the full content, unless there is another problem, but with Safari.
                              Thanks again
                              PS: SU uses Safari, regardless of the setting of your preferred browser on your MAC. So changing to Firefox would have no influence.
                              to drop into LIBFREDO6_Dir_31
                              • jeff hammondJ
                                here's a screenshot of the dialog using the latest file.
                                http://homepage.mac.com/jeffhammond/.Public/scf/freescaleweb.jpg
                                that's exactly how it opens up and it's the best version yet.. the entire red outlined box is now visible but i still have to stretch the window to get to the save/reset buttons.
                                as far as i'm concerned, everything is totally fine as is but i can understand the confusion by a mac user that is just installing freescale.. regardless, all of the tools work perfectly and that's my main concern.
                                as far as safari's context menu, these are my options with a normal web page:
                                http://homepage.mac.com/jeffhammond/.Public/scf/safaricontext.jpg
                                with the freescale dialog, i only have one option which it 'reload'.. if i click on that, everything stays the same.
                                • C
                                  caronte01
                                  Several plugins on the mac, including yours, won´t remember the state of it´s toolbars (opened or closed), between sessions. Someone at google told me that this can be fixed by including something similar to this:
                                  Show toolbar if it was open when we shutdown.
                                  state = toolbar.get_last_state
                                  if (state == TB_VISIBLE)
                                    toolbar.restore
                                  Santiago
                                  • fredo6F
                                    Santiago,
                                    Do you mean that this is specific to the Mac platform?
                                    On Windows, just calling toolbar.show is sufficient to take into account the previous state when Sketchup is closed.
                                    Anyway it's easy to fix, based on your example.
                                    Thanks for the tip
                                    Fred
                                    • jeff hammondJ
                                      that would be great to find out a way i could turn the toolbars on and off and have their status remembered.. the only toolbars i have that will do this are the ones that come with SU (sandbox, dynamic components, etc.).. two of the rubies containing toolbars that i have (skin.rb and kerkythea exporter) will not appear upon launch of sketchup and the rest of them will not 'hide' upon launch -- regardless of how they are set up prior to closing the app..
                                      speaking of dynamic components fredo, have you by any chance looked at the code for it (or is it even possible?).. that has a web dialog and there are no problems with it on macs.
                                      • fredo6F
                                        I made a small modification to follow the advice from Santiago (attached file). This problem may be specific to the Mac, because, on Windows, toolbars are well 'remembered'.
                                        Thanks for this good idea. Difficult to tell however, because it is done differently (mostly in Javascript for the displays). Also their ruby code is encrypted and I suspect my problem precisely lies in the way the dialog box is configured from Ruby.
                                        • fredo6F
                                          For the display of Web dialog boxes
                                          Sorry to bother again, I made a slight modif to shift the content down, because it seems that on Mac the top of the HTML content starts under the title bar.
                                          Maybe the attached file will correct this.
                                          to drop into LIBFREDO6_Dir_31 subfolder
                                          • T
                                            Tasman
                                            Thanks for all this work you are doing on the Mac versions.
                                            I have just tried your last update which should remember the last position of the toolbars on Quit. Tools on Surface and Free Scale work OK but BZ_Toolbar, Round Edge and Null Transform still have the problem of returning to there previously displayed position.
                                            Tasman
                                            • 1 / 6
