    [Plugin] Archiver.rb - update
    42 Posts 10 Posters 29.4k Views 10 Watching
    • jeff hammondJ Offline
      ok, thanks for helping
      i found the rogue files (they were placed in the same location as the archive folder .. there were 5or6 of them)
      i have to go get my daughter from school right now but i'll do what you're saying when i get back.
        ok, here's the output:
        /Users/jethro/Desktop/archiver_test2/archiver_test2.skp
        archiver_test2
        nil
        archiver_test2[09-04-06_18-57-35].skp
        \Archives
        \Archives\archiver_test2[09-04-06_18-57-35].skp
        Error: #<Errno::ENOENT: No such file or directory - >
        /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:82:in chdir' /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:82:in make'
        /Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:177
        [ps: i put in a request with csaba to break this part of the thread into a new one]
          It's as I thought...
          A Mac needs / in its file paths...
          A PC can have either \ or /, except for 'UI.openpanel' which must have ... [unsure about it for Mac***]
          SUp on PC gives paths etc with \ separators, while PC Ruby can take either: I expect that Mac-Ruby uses / always ?
          I have rewritten things to trap for this.
          It's still working fine on my PC.
          I hope it now works on a Mac... since I don't have a Mac please let me know that File -> Archiver AND ***Open Archive are both working - you might need to make some archives and then reopen the model to get the second Menu option to appear...
          Note I've removed the 'user' suffix option as it was not that useful anyway and difficult to get/trap cross-platform...
          After almost four years a Mac user finally reports a bug with this script !!!
          Hopefully it's now properly cross-platform...
          Archiver.rb
            awesome! it's working fine now.. this is surely going to be one of my most used rubies..
            fwiw, the 'open archive' menu option appears from the get-go and i only have to save an archive in order for the list to appear.. i don't have to save/reopen the model first.
            thanks so much!
              Hooray !
              It will require a little 'management' on your part. If you save every 15 minutes of an eight hour day that's 32 copies of your model !
                @tig said:
                Hooray !
                well, that's generally how it is anyway for me but i'm usually just saving to my desktop and though i try to have some sort of naming system for the files, it always gets screwed up about half way through πŸ˜„.. i'm left doing a major clean-up/figuring out what is what every few days.. when i'm at home working on a model, i can stay a bit more organized but i also use sketchup on the job site where it's a lot more hectic - that's where archiver.rb is going to shine i think.
                this ruby will actually help me keep organized.. especially once OS X supports .skp files (fingers crossed) and i'll be able to go through the archives via cover flow (ability to flip through full sized previews, iTunes style, without actually opening the file)
                • takesh hT Offline
                  takesh h
                  Hi TIG,
                  Another brilliant ruby script from the brilliant mind.
                  I'm going to add this gem to pushpullbar's Ruby Index, so let me clarify a couple of things before I do that.
                  1. Should I have the link few posts above as the "definite" version of archiver.rb for now? Can I request Didier Bur to update your archiver.rb in Ruby Library Depot to the above version? It doesn't look like Didier had time to update the site for quite some time.
                  2. I always thought "_" is more common (less problematic) divider than "-" in file names, is there any specific reason you chose "-" as a default divider?
                  Thanks in advance.
                    jmmad
                    Thxs Tig !
                    Life saver plugin
                    Now i can travel back in time
                    Get Upa !
                      @takesh h said:
                      Hi TIG,
                      Thanks in advance.
                      v1.7 is the best one - link to that. Didier can add v1.7 if he wants to...
                      It's easy to change the separators - edit the file and make sep="_" or whatever text you want that's allowed in filenames. The only advantage is that in the filename "model[yy-mm-dd_hh-mm-ss].skp" the date and time are more easily read separated by the _. You could even use sep="" and get "model[090407_072210].skp"... It's easily adjustable to suit your own whims...
                        Now you tell me it's a Mac !!! That's probably the basis of the problem...
                        It might be best to go to PM or a new thread ?
                        Firstly please do a Finder search to locate the rogue .tmp files and chuck them - they should have been with the model and removed as the archive is copied over...
                        The 'Archives' folder should be in the model's folder. It's made for each model folder. Unless your model is in the root directory it shouldn't be made in there...
                        Here's a version that writes everything to the ruby console... Open the console, run the Archiver and copy paste the several line of output into a message for me so I can see what's up...
                          Jeff
                          EDIT:
                          I've looked into it...
                          Here's an updated version. It failed before probably because another script was setting the 'default directory' to somewhere else: this version now makes sure it's set to be the model's folder (I added line 80)...
                          I've ### out the user name and confirming dialog - it you want them back then edit the file and go to lines 75 and 87 respectively and remove the initial '###' to have them show...
                          If you find a load of "archiver_test[nn-nn-nn_nn-nn-nn_XXX].skp.tmp" files - probably in your Plugins folder - then accept my apologies and throw them away !
                          It now works silently and puts things in the correct places...
                          EDIT: see v1.7 http://www.sketchucation.com/forums/scf/viewtopic.php?p=147035#p147035
                          • takesh hT Offline
                            takesh h
                            Thanks for explanation, that makes whole a lot of sense.
                            I'll forward the link to Didier Bur. πŸ‘
                            • takesh hT Offline
                              takesh h
                              TIG,
                              It's online now.
                              http://www.pushpullbar.com/forums/ruby-scripts/9467-visual-index-ruby-scripts.html#post146070
                              If there is anything wrong with my review, please don't hesitate to tell me.
                              Thanks a bunch.
                                just reporting back after a week or so of using archiver.
                                this plugin is awesome!
                                thanks again TIG.
                                  Glad its useful...
                                  If anyone else has any feedback (even critical !) please let me know...
                                    Jim
                                    @tig said:
                                    Glad its useful...
                                    What happens if you open an archived model, then use archiver again? Does the date-stamped filename get longer, or does the date-stamp get updated?
                                    Also, a good option may be to have a "branch" option. Branching would prompt for a new filename and save the model under that name. A branch might be used to experiment with variations in a model, then allow to switch back and forth between branches.
                                    Personally, I have turned off SketchUp Auto-save and am in the habit of hitting Ctrl-s (save) to save the model. So, maybe it could be tied to the built-in Model > Save through the onSaveModel ModelObserver.
                                    Just thoughts - I would consider it an essential plugin as it is. Thanks.
                                      If you open an archive and modify it and then archive it you will get another date-time stamp added to the end of its name, in another Archives folder within the original Archives folder... I'd recommend copying archives rather than using them direct since saving alterations overwrites the earlier version. That way you know which version of the model you are working on but keep the original archive unchanged... You can always open an archive and save_as Model-Option-B etc...
                                      Your 'branch' option is called 'design options' in Revit... At the moment you will need to save as a number of models and archive each as desired... Your 'Archiver+Option' would archive the current Model.skp make /Archives/Model[yy-mm-dd_hh-mm-ss].skp and then open a save_as dialog with suggested incremented option name - e.g. Model[Option-01].skp - you could always change what's inside the []. Work on that version and make archives etc as usual. Then perhaps you decide that you want to explore another variant... pick 'Archiver+Option' again - it then spots the [] on end of the name and suggests a save_as with an incremented name - e.g. Model[Option-02].skp etc etc... Option-01 to Option-99 would be the typical range...
                                      I'll see what I can clobber together... watch this space...
                                        Jim
                                        Well, as I said these are just ideas from a casual user, and things I don't strictly "need." Maybe some power-users can give more input.
                                          Here's v1.8
                                          It now has an extra menu option 'Archive Option'.
                                          This archives the file and then gives you a 'save_as' dialog -
                                          with the default new option's file-name entered as "Model[Option-01].skp" ..-02] etc.
                                          This 'option' 'number' is based on the highest value option found in the model's folder.
                                          You can overwrite an existing file if desired (you will be warned 1st).
                                          The current active model-window now opens with the latest option you have just saved.
                                          If you save a model as an 'option', then to be recognised as such it should have its name in the format "Model[Option-nn].skp" - it must have the surrounding "[..]" and a separating "-" between the number and any text; the string "Option" could be set in the save_as dialog to say something else, BUT since new options always use "[Option-nn]" anyway it's recommended to leave it unchanged.
                                          Please test and feedback...
                                          Archiver.rb
                                            Here's v1.9
                                            Minor change to 'Archive Option' - the original model is now saved immediately before it is archived and then saved as an Option.
                                            Usage:
                                            Pick 'Archiver' to make an archive copy of the current model.
                                            It saves the model (in its current state) into a sub-folder
                                            within the model's folder called 'Archives'. It's named with
                                            a [suffix] - date (yy-mm-dd_hh-mm-ss),
                                            e.g. Model[09-12-18_12-34-56].skp.
                                            The separators can be customized from '-' to '' etc,
                                            just change one line - sep="-" to sep="
                                            " etc...
                                            If later on you don't save the main model with those changes
                                            then that archive copy still has those changes current at the
                                            time of the archiving.
                                            If there is an 'Archives' folder then an extra 'File' menu
                                            item is added - "Open Archives"...
                                            'Archive Option' is an additional function that saves the model as it
                                            stands - say 'Model.skp' - then it makes an archive of it - say
                                            'Model[09-04-16_12-25-05].skp' and then opens a 'save_as' dialog in
                                            which it will have preset the next available unused Option name - say
                                            'Model[Option-01].skp' - which you are prompted to save_as: you can
                                            choose to overwrite an earlier option if desired - if so you are
                                            warned about overwriting it. The Options are kept in the same folder
                                            as the original. It is recommended that you do not change the naming
                                            convention... The model is then saved. The current SketchUp window
                                            then shows this latest Option.
                                            Options can be archived in the same way as other models - in the
                                            example above the archive's name might then be
                                            'Model[Option-01][09-04-16_12-30-55].skp'...
                                            If you subsequently use 'Archive Option' on an 'Option' itself it then
                                            names the new Option with the next available free Option name - in
                                            this case it would 'Model[Option-02].skp' and the process repeats...
                                            characters as separators so don't change the Option's
                                            name if you want it to be recognised as one by 'Archive Option'.
                                            Feedback please...
                                            Archiver.rb
                                            • 1 / 3
