    SP3x Apr3 version.
    36 Posts 10 Posters 6.7k Views 10 Watching
      Physicsguy1
      Can you use your own sound files?
        CPhillips
        Nope! 😄 That was the problem I discovered soon after I got sound working. I cant possibly include a decent library of sounds, for one thing they are just too big.
        What I am going to do instead is make it possible to embed .WAV files into the Sketchup model. That way you can put whatever sounds (or music) you want in. AND the copyright issue isn't my problem anymore.
          Physicsguy1
          How should i achieve this?
            BTM
            You can't right now. If you want someone else to get the sound file, post it on the forum or somewheres else, and tell them to go get it 😆
              CPhillips
              Thats right. But I'll get the embedded sound working asap.
                phy
                @frediivx said:
                Im not 2 great at scripting, so could you tell me how 2 control the sound, e.g. play a gunshot.wav when joybutton('RB') is pressed? I tried different variations of things like this joybutton('rb'); playsound('gunshot.wav') but can't get it 2 work -- Edit --
                DW i resloved it in the end
                how, i can't get it to work
                Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                  BTM
                  its: playsound("gunshot.wav");100
                  the;100 represents the value of the emitter's strength.
                    Physicsguy1
                    would playsound('gunshot.wav');-(a)*500 work?
                      CPhillips
                      I updated the first post with a link to the Mac version:
                      http://sketchyphysics2.googlecode.com/files/SP3x-Apr5-MacAndWin.zip
                      There are no real changes between this and the last version.
                      Looks like the first thing I am going to focus on is fixing the playsound problems. I have the code that will embed and extract wav files from the model. But I need to do a little UI work. I need embed sound/clear sounds menus.
                      As soon as I got the playsound command working I was disappointed by it. At least on windows it is very very limited. You can only play one sound at a time and not very fast.
                      Can someone with both Mac and Windows tell me if it behaves the same on both?
                        BTM
                        On mac, I can play as many sounds as I want simultaneously, and can have sounds start for every frame. Don't know about windows though. Once I tried making a motor with sound, and even less than every frame it would start another loop.
                          CPhillips
                          AHH HHA!. 🤣 😍 🎉 I achieved something today that I have been trying since SP1. Joints that work without using the JCT. Its something I had working in SPIV but I could never figure out how to do in SP3.
                          [flash=600,400:3fr1gscy]http://www.youtube.com/v/tS56PNcbH9I[/flash:3fr1gscy]
                          Despite the version number in the video it doesnt work with RC1.
                          Next version of SP3x should have it.
                            Physicsguy1
                            Ooooooooooohhhhhhhh that looks great. Will they be able to be emitted? And Can anything that collides with a "joint" connect to it?
                              BTM
                                MrPlanet
                                THANK YOU SO MUCH FOR A ZIP VERSION!!!! 👍 ☀ 😍
                                I reject your reality and substitute my own.
                                  Sgt.A.Johnson
                                  Man thats cool. I want a go but ill never remember code to do it
                                    BTM
                                    2 things: one, Is that when you go back to edit scripts sometimes the spaces will be double, and if that happens to one script several times,it can make it harder to read. Can that be fixed?
                                    also, is there a way to have a OnTouch function work with specific objects?
                                      CPhillips
                                      Not at this time. And yes.
                                        CPhillips
                                        I havent seen that. It might be Mac specific. Can you give me the steps to reproduce it.
                                        Not yet.
                                          KDSDESIGN
                                          i installed it, but when i press play it says im still using alpha...?
                                          Regards,
                                          █Kevin█
                                          (about 20% done)
                                          • W Offline
                                            Wacov
                                            Look in the UI; when you have an object selected, if 'onTouch' and 'onTick' are shown as options near the bottom, then don't worry. If they aren't, you'll have to ask C Phillips what to do next.
                                            If they are there, then don't be concerned about the version display, mine still says RC1.
                                            • 2 / 2
