Tools-----Paintbucket?
33 Posts 12 Posters 2.6k Views 12 Watching
  • O Offline
    outwest77
    I have managed to download the component libraries, which was not easy to find these, and not easy to figure out how to get them to work,
    Even on Sketchup Pro 7 though, the Tools Paintbucket, seems to come with an extremely stripped down version from what I was easily able to access with even Sketchup 6 free version.
    Why is this? and how to get the larger archive of choices like I had before
      Had you downloaded the extra textures pack for SU6?
        Or simply just copy (or move) them between the respective folders from SU 6 to SU 7 (provided you still have SU 6 as you are talking about it). They should all work just fine.
          Daniel
          That's what I did - copy all the materials and components from 6 to 7. But I do find it annoying that Google doesn't package all the "extra" material and component packs directly in the program.
          My avatar is an anachronism.
            Its extremely annoying.
              remus
              I suppose its to keep the size of the installer down, i imagine you could easily triple the size of the whole package if you included more components and textures. I agree it is pretty annoying having to move all your components across, though.
              I wonder if it would be possible to have the installer import all your old materials and components in a similar way to shortcuts?
              • O Offline
                outwest77
                I cant find the free sketchuup 6 i was using,
                so i downloaded 6 Pro
                that doesnt help at all
                it has the same stripped down paintbucket as 7 does, so where exactly are you supposed to get this to transfer it to 7?
                  mitcorb
                  Isn't this available on the Google Sketchup Download page as a link called Bonus Packs? Keep drilling down. There's a big fat file of bonus stuff-- I wanna say about 12mB.
                  Here: http://sketchup.google.com/download/bonuspacks.html
                  They say they have moved it to the 3d warehouse, however.
                    Yeah but at the botom, you can follow a link to the SU 6 bonus packs you can download and install (except you will need to change the destination folder) although they are all the component libraries and no materials.
                    • O Offline
                      outwest77
                      So I still have no answer where to get the tools paintbucket surfaces etc
                      they are not in 6, 6 has the same even in the PRO version that 7 does
                      are they in the free version of 6?
                      This really is a big pain, when i reformatted , i used to download the sketchup current free version even, the component library link was there, and it installed in a flash, and the tools..paintbucket was there too
                      now even in the "PRO" Versions, they all suck, the component library has been moved to warehouse...........which is impossible to download or you get about 10 useless components, or a sample...........and the paintbucket is a sucky stripped down version
                      now you would think that the trial versions of the "PRO" Would be loaded with everything from the start, but they suck just as bad as the free versions
                      all in all pathetic
                      • T Online
                        outwest77
                        As I see it you have/had v6 which has lots more materials for the paint-bucket tool ?
                        If so, then you need to copy all of the sub-folders/files in the v6 'Materials' folder into the 'Materials' folder in v7 - for a PC it's typically:
                        C:\Program Files\Google\Google SketchUp 6\Materials
                        and
                        C:\Program Files\Google\Google SketchUp 7\Materials
                        On a Mac the path varies - read the Help Docs...
                        If you don't have these materials where have they gone ?
                        Find them...
                        If they are lost forever then download from the SUp site as recommended in earlier posts...
                        Restart SUp to get additions etc...
                        • O Offline
                          outwest77
                          I have versions 6 and 7
                          version 6 does NOT have lots more for the paintbucket tool
                          it has exactly the same stripped down version of this tool that 7 does, and both these are "pro" versions
                          so where are these tools we are supposed to transfer?
                            remus
                            If you Still have that SU install (the one where you had a large choice of materials) you can move them across as TIG described. Apart from that all i can suggest is to make your own materials until the materials pack is released.
                            • T Online
                              outwest77
                              I give in - I've attached a zip file containing all the freely-available materials you crave for. Extract them into the desired SUp version's Materials-folder/sub-folders... Some might over-write the base set's... Use your judgement.
                              You can easily make your own materials from image files and then save them as libraries for use in other models...*
                              There are lots of other free ready made materials out there too... e.g. here: http://www.sketchucation.com/forums/scf/viewforum.php?f=40
                              Also remember that if you download a component or model [e.g. from 3D-warehouse] you can easily extract its materials into new .skm libraries for reuse in other models - read the manual* - 'Material Browser' - 'Save Library As'... for v6 it's: http://download.sketchup.com/OnlineDoc/gsu6_win/Content/F-Model_Settings_and_Managers/Settings-MatBrowser.htm?Highlight=saved|save|Save|saving|savings|Saving||library|Libraries|libraries|Library||
                              it's much the same method for v7.
                              Happy painting...
                              Materials.zip
                              • O Offline
                                outwest77
                                Thanks TIG, i am trying to insert them into the appropriate folder after i download them..
                                upon looking in the folders, there appears to be only 10 choices in each of the subcategories in the zip file you loaded, example. stone......10 choices
                                this is the same number of choices i have now
                                when i had this before, the stone had like 40 choices
                                where is this archive to download
                                not to say your zip is not appreciated but it appears to be the same choices I have now, the limited 10 choices per category
                                • O Offline
                                  outwest77
                                  You download the "PRO" version of sketchup 7, you expect a fully functional 30 day trial to get you interested to buy the expensive 500 dollar version
                                  what you get is no better than the free version, the Components library is not there, it has a bunch of cheap samples
                                  same with the Pro version of 6
                                  not only that, the paintbucket surfaces are not there, only 10 choices there as opposed to the fully stocked version which has about 40 choices for each surface
                                  Pardon me for saying this , but whoever took over sketchup, has no clue how to market the thing, and taking out the component libraries and saying they moved them to the warehouse was a very dumb move.
                                  All in all I have spent about 2 weeks trying to get the thing working, as I had the old FREE version working, with no luck. and that includes asking on the board for help.
                                    Mack,
                                    The Pro versions have different functionalities than being "pre-packed" with the bonus packs. As was suggested to you in another topic,download the bonus component libraries for SU 6 and install them into SU 7. Did you do that?
                                    Note that these libraries are made to be a different downlo0ad because otherwise the installer could easily become at least double the size. What would be the reason? I for one prefer the existing way as I mostly don't need those components anyway (I am not n architect and even if I were, I would definitely not build US traffic signs into my model).
                                    BTW the pro trial version is not a working version for 30 (idle) days but for 8 working hours.
                                      Did you delete them all?
                                      • O Offline
                                        outwest77
                                        They might have more functionality, the pro versions but what good are they without the component libraries"
                                        Yes i downloaded the component library after you or someone else gave them to me and I somehow managed to get them somewhat working, in 7, but the interface is not user friendly, and it is difficult to navigate
                                        i still never got the paintbucket to have the full choices, despite a few days of trying to find it and someone sending me the zip file, which was not much help
                                        • O Offline
                                          outwest77
                                          i did not purposely delete them, i reformatted and wiped the hard drive and that lost all the old installs
                                          truly sad you have to go through so much pain in the butt just to get the components and surfaces nowadays, even with the pro versions
                                          1 / 2
