    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      @daniel s said:
      Fredo, not big problems but something that i find using FreeScale 2.0:
      • Trying to change the deformation before clicking to validate the transformation it makes a unexpected result. I don`t know how to explain this in english so i attach a video showing the problem in the twist and taper tool:
        [attachment=2:1dhudg9p]<!-- ia2 -->twist-taper.wmv<!-- ia2 -->[/attachment:1dhudg9p]
      Thanks for logging this. One thing I may have forgotten to mention is that the script must break the curves when deformed. Then I have tried to reconstruct them after deformation. apparently, it does not always work. Can you try with the same geometry, but enclosed in a group or component?
      I'll try to fix it in the next update
      @daniel s said:
      • In the plugin configuration (Icons visible in the toolbar option) I remove the Make Unique, the box rotation, and the rotation (free) icons. Works well but it leaves the icon separators. I attach a image of this too:
        [attachment=1:1dhudg9p]<!-- ia1 -->icons.jpg<!-- ia1 -->[/attachment:1dhudg9p]
      Thanks also for that. I fixed it and it will go the next update
      @daniel s said:
      • A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
        [attachment=0:1dhudg9p]<!-- ia0 -->Animation_Rotate_Tool.gif<!-- ia0 -->[/attachment:1dhudg9p]
        http://sites.google.com/site/sketchupsage/tweak/rotate
        This option can be added?
      I have to think hard about that. As you notice, the GUI becomes quite complex to manage with all possibilities, Escape, Undos, VCB typing, etc..., and I want to make sure this does not break other things and remain usable. In between, I hope that just hitting Shift to lock the plane will be sufficient.
      Thanks again Daniel for your help. Do not hesitate if you find other problems.
      • fredo6F Offline
        Well it seems on one attachment made the trip. Here is pic 2 error message with only FS Ver 2 installed.
        Ken,
        Please do the following:
        Open the ZIP files you dowloaded, and for each of them in Winzip, do a Select ALL and then extract to the Sketchup Plugins directory. Make sure you answer YES to overwrite existing files. DO NOT RENAMEany folder or file.
        You should have subfolders LIBFREDO6_Dir_31 and FREESCALE_Dir_20, and 2 ruby files LibFredo6.rb and ZLoader__FreeScale.rb. That's all you need.
        PS: the reason why you must not rename anything is that I use a convention with version numbers. LibFredo6.rb has the only purpose to detect the latest version of LibFredo6 library (and 31 > 30). And ZLoader__FreeScale.rb is a one_line ruby which just loads the right version of FreeScale, which is supposed to be in FREESCALE_Dir_20.
        I know this seems more complex than just dropping a single ruby file in the Sketchup plugin folder, but that's also the way I can manage compatibility, configuration, translation, etc....
        • kenK Offline
          ken
          I have done as requested, still have problem, pic 2. I have sent to you a PM with my files.
          Thanks for the help
          Ken
            jmmad
            I cannot reproduce the freeze (see video attached). Is it something always reproducable in your environment?
            Can any other user try to reproduce it?
            [attachment=0:2n2vwxal]<!-- ia0 -->Bench Moder trial.wmv<!-- ia0 -->[/attachment:2n2vwxal]
            I detected that the freez only happens when i have set the planes to a certain position and hit control, then 2 planes apear instead of one and i stretch from the center, but while im stretching the component SU freezes, always.
            Thxs for responding.
            All the rest works like charm
            Get Upa !
              malvin
              How do I download the zip? I have only php file saved.
              Please advice
              • Chris FullmerC Offline
                You should just be able to click on it and it should pop up a windows asking if you want to save or open. What operating system are you on? What browser are you using?
                  malvin
                    malvin
                      malvin
                      I have Windows XP Pro, Internet Explorer 6
                      The window does pop up to save or open but instead of save the zip file.php is saved
                      Please advice
                      Olga
                      • E Offline
                        Ecuadorian
                        Get rid of Internet explorer and get either Firefox or Google Chrome. Both are free and a lot less of a headache.
                        -Miguel Lescano
                        • soloS Offline
                          hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
                          However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
                            malvin
                            Yes, solo, I do not have updates enabled so that might be the reason but I do download stuff now and then and only very seldom I run into this problem when instead of zip I have file.php downloaded. That might be the promlem
                            • X Offline
                              xrok1
                              i noticed a quirk?
                              if i use the SP toolbar to create a cone, i cannot stretch it up or down no matter what. i can however stretch it from the sides?
                              its not too important to me i just thought i'd mention it in case its a bigger thing than i can tell.
                                boilingsnow
                                Thank you very much Fredo!
                                But it seems that the streching tool doesn't work on cylinders.
                                  jmmad
                                  boilingsnow & xrok1
                                  stretch wont affect curves.
                                  to affect it you must explode the curve first.
                                  Get Upa !
                                  • X Offline
                                    xrok1
                                    if i stretch a cone from the point upward, what does that have to do with a curve?
                                    • utilerU Offline
                                      utiler
                                      Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. 😉
                                      Just Curious...
                                        jmmad
                                        You are right
                                        The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
                                        As it wont work with a 3 side piramid in any direction
                                        Get Upa !
                                        • fredo6F Offline
                                          jmmad,
                                          On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
                                          I am not too sure of what it can be, but I rewrite one part of the code differently.
                                          Thanks to advise
                                          to drop into FREESCALE_Dir_20 folder
                                            jmmad
                                            I did what you told me.
                                            But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
                                            Its strange i think this might be a isolated problem not much to worry about.
                                            Thxs for the concern and help
                                            Get Upa !
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 56
                                            • 57
                                            • 13 / 57
