    Once upon a time... A Puzzle
    95 Posts 15 Posters 8.8k Views 15 Watching
      seems 21 but in this sort of successions there are often several arguing possibilities 😉
        Try this:
        1,1,2,3,5,8,13...
        What's the next number?
        Fibonacci ...21,34,55,89,144,233,377,610,987,1597,2584,4181,6765... etc
        http://en.wikipedia.org/wiki/Fibonacci_number
          Yes but this one will also valuable 😉
          1 1 2 3 5 8 13 13 14 15 20 25 25 etc...sure totally arbitrary but apply with an interval repetition 😄
          • jeff hammondJ
            Outside a room there are three light switches. Each switch is connected to a different light bulb inside the room.
            Each of the three switches can be either 'ON' or 'OFF'.
            You are allowed to set each switch the way you want it and then enter the room. you can only do this once.
            Your task is to then determine which switch controls which bulb. How can you do it?
            • E
              Ecuadorian
              1. I ask someone to stay outside the room and help me.
              2. I tie a string to one of the switches, then enter the room.
              3. I call the architect and tell him how bad his design is for having put the switches outside.
              4. I give up.
              -Miguel Lescano
              • jeff hammondJ
                4. I give up.
                haha #3 sounds good.
                1 & 2 are not allowed. (or anything like those)
                4 - nah - there's a real solution
                oh, and i should add.. if you fail, something terrible will happen.. let's say nuclear war 😄
                  remus
                  Is there a sneaky trick to it, or is there a combination of on/offs that you can set to work it out?
                  • E
                    Ecuadorian
                    Ok, I cheated and found the answer online. I can give a hint: The thing you can only do once is enter the room.
                    And I'll give you a puzzle I've just made up. This one is for the Japanese speakers and Japanese language learners in the forum:
                    3txq
                    What is the next character in the sequence?
                    -Miguel Lescano
                    • jeff hammondJ
                      no Remus. Nothing sneaky.
                      [edit] well, maybe.. there isn't a sole combination of on/off's that will tell you the answer.. there's something else to it but that something else is logic based.. not something you're going to be mad about when you realize the solution..
                      and yeah, you can only enter the room once.. you can do whatever you want prior to going in.
                      • DanielD
                        Daniel
                        Flip the switch, then look in the room through the doorway (without entering it).
                        My avatar is an anachronism.
                        • jeff hammondJ
                          nope - the room is light sealed.. no windows etc..
                          a hint - light bulbs are an important part of the solution.. if the switches were connected to electric fans for instance, you probably couldn't solve it..
                          • E
                            Ecuadorian
                            Yes I could, at least with most ceiling fans 😉
                            -Miguel Lescano
                            • E
                              Ecuadorian
                              Tomorrow does sheep will be at the same hour and at the same place on the way than today?
                              You never return to the same time and the same point in space 🤓
                              -Miguel Lescano
                              • jeff hammondJ
                                oh yeah.. i guess you could figure it out with fans..
                                i was going to use electric clocks as an example you couldn't do it with but that too would actually work.. an electric Digital clock (meaning - the display turns off instantaneously when the power is shut off) on the other hand - i don't think that would be possible.
                                • jeff hammondJ
                                  ok, so i thought of a way you could do it with a digital clock as well..(and probably is the easiest of all)
                                  i'll just go ahead and give the answer.. for ease of explanation, let's label the switches 1, 2, & 3:
                                  • set switch 1 & 2 to the 'ON' position
                                  • wait a minute or two
                                  • turn off switch 2 and enter the room
                                  • the light that is on is controlled by switch 1... the light that is off and warm is switch 2... the light that is off and cold is switch 3
                                  and i'm stumped on frenchy's last question
                                    Read more the question 😉
                                    • T
                                      Teezer
                                      Once upon a time, I got into a session with a couple of programmers who were trying to find a non obvious way to hide information in a binary format. This is one of the things we came up with.
                                      The following sequence is valid under this scheme:
                                      1 = 1
                                      2 = 110
                                      3 = 111
                                      4 = 100
                                      5 = 101
                                      6 = 11010
                                      7 = 11011
                                      8 = 11000
                                      9 = 11001
                                      10 = 11110
                                      Can you see why?
                                      Real life is just another website, albeit a rather boring one.
                                        Jim
                                        There's window in the wall and you can see the lights inside?
                                        • david_hD
                                          david_h
                                          Model it in Podium. 💚
                                          • E
                                            Ecuadorian
                                            1 = 1
                                            2 = 110
                                            3 = 111
                                            4 = 100
                                            5 = 101
                                            6 = 11010
                                            7 = 11011
                                            8 = 11000
                                            9 = 11001
                                            10 = 11110
                                            Can you see why?
                                            Ok, wait, I've solved the first 5 digits. It seems that you have to subtract and then add the relative values of the digits. I'm not a coder, so I might be way off... 😳
                                            2 = 4 - 2 + 0
                                            3 = 4 - 2 + 1
                                            4 = 4 - 0 + 0
                                            5 = 4 - 0 + 1
                                            -Miguel Lescano
                                            • 4 / 5
