    Once upon a time... A Puzzle
    95 Posts 15 Posters 5.7k Views 15 Watching
      so no takers on this one?
      Seems I have given the solution in my previous post? ๐Ÿ˜’ ๐Ÿ˜‰
      Reread it carrefully ๐Ÿ˜† And the task to keep fresh research for others ๐Ÿ˜Ž
      SCQTDU next one? ๐Ÿ’š (little hint in my name in my signature)
      • jeff hammondJ Offline
        oh man, you're right..
        • 1n1e1x1t1space1l1i1n1e1
        i fully missed what you were saying there ๐Ÿ˜ณ
          i barely know any french but it appears to work in spanish as well.. uno,dos,tres,quatro,cinco,seis..
          my guess for the next letter would then be 'C' for cero.. if C is wrong then my guess is:
          whatever the first letter is in the translation of 'zero' in french..
            zero is zero...
              @tig said:
              zero is zero...
              haha..
              ok, then my guess is 'Z' ๐Ÿ˜„
                ๐Ÿ‘ ๐Ÿ˜‰
                  remus
                  Try this:
                  1,1,2,3,5,8,13...
                  Whats the next number?
                    seems 21 but in this sort of successions there are often several arguing possibilities ๐Ÿ˜‰
                      Try this:
                      1,1,2,3,5,8,13...
                      What's the next number?
                      Fibonacci ...21,34,55,89,144,233,377,610,987,1597,2584,4181,6765... etc
                      http://en.wikipedia.org/wiki/Fibonacci_number
                        Yes but this one will also valuable ๐Ÿ˜‰
                        1 1 2 3 5 8 13 13 14 15 20 25 25 etc...sure totally arbitrary but apply with an interval repetition ๐Ÿ˜„
                          Outside a room there are three light switches. Each switch is connected to a different light bulb inside the room.
                          Each of the three switches can be either 'ON' or 'OFF'.
                          You are allowed to set each switch the way you want it and then enter the room. you can only do this once.
                          Your task is to then determine which switch controls which bulb. How can you do it?
                          • E Offline
                            Ecuadorian
                            1. I ask someone to stay outside the room and help me.
                            2. I tie a string to one of the switches, then enter the room.
                            3. I call the architect and tell him how bad his design is for having put the switches outside.
                            4. I give up.
                            -Miguel Lescano
                              4. I give up.
                              haha #3 sounds good.
                              1 & 2 are not allowed. (or anything like those)
                              4 - nah - there's a real solution
                              oh, and i should add.. if you fail, something terrible will happen.. let's say nuclear war ๐Ÿ˜„
                                remus
                                Is there a sneaky trick to it, or is there a combination of on/offs that you can set to work it out?
                                • E Offline
                                  Ecuadorian
                                  Ok, I cheated and found the answer online. I can give a hint: The thing you can only do once is enter the room.
                                  And I'll give you a puzzle I've just made up. This one is for the Japanese speakers and Japanese language learners in the forum:
                                  3txq
                                  What is the next character in the sequence?
                                  -Miguel Lescano
                                    no Remus. Nothing sneaky.
                                    [edit] well, maybe.. there isn't a sole combination of on/off's that will tell you the answer.. there's something else to it but that something else is logic based.. not something you're going to be mad about when you realize the solution..
                                    and yeah, you can only enter the room once.. you can do whatever you want prior to going in.
                                    • DanielD Offline
                                      Daniel
                                      Flip the switch, then look in the room through the doorway (without entering it).
                                      My avatar is an anachronism.
                                        nope - the room is light sealed.. no windows etc..
                                        a hint - light bulbs are an important part of the solution.. if the switches were connected to electric fans for instance, you probably couldn't solve it..
                                        • E Offline
                                          Ecuadorian
                                          Yes I could, at least with most ceiling fans ๐Ÿ˜‰
                                          -Miguel Lescano
                                          • E Offline
                                            Ecuadorian
                                            Tomorrow does sheep will be at the same hour and at the same place on the way than today?
                                            You never return to the same time and the same point in space ๐Ÿค“
                                            -Miguel Lescano
                                            • 3 / 5
