    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 181.7k Views 65 Watching
    • jeff hammondJ Offline
      @xrok1 said:
      if you type an uneven number of segments you will have a vert at the top. ๐Ÿ˜‰
      yeah, and that would work to an extent but then the horizontal is off.. i usually work off of 1/4 circles, get them to the right height, and then divide them into 8"o.c. segments.. it's just easier for me if everything is straight up&down / side-to-side at the beginning of the process.
      • X Offline
        xrok1
        makes sense.
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • Chris FullmerC Offline
          Well I see where its handy, especially if its already a normal part of your workflow. I think what I can implement easy enough is like a shift key that will rotate the faces. Hit the shift key once and it rotates.
          A square could rotate 45 degrees each shift. A circle could rotate whatever degree would be require to shift between a flat edge down or a vertex down. THe custom face could rotate 90 degrees, since a fast way to rotate it 180degrees would be handy, perhaps increments of 90 would be a good place.
          Anyhow, those are thoughts. I'll implement it. I'll even see if I can make the circle work so that it starts with the vertices at the top and bottom from the start. So the shift would take make it have an edge on top bottom. Make sense? Anyhow, I'll work on it. Let me know if you have any thoughts on the ideas and I'll see what I can do. But I'll be taking a break to watch LOST in a few minutes ๐Ÿ˜„
            haha
            i don't know. it's up to you.. i do think it's important to keep it fairly simple instead of using a somewhat obscure reason to bloat it.. maybe some others can chime in and reach a consensus..
            now that i think about it, once i start using this in a drawing, i'll probably prefer using the square instead.. even if i'm drawing an arc.
              and just to jump start that consensus, here's what TIG had to say earlier in the thread.
              @tig said:
              Circle - not so important to get 'square', but if it has few segments it'd be best if a vertex were at the lowest point in Z
              ๐Ÿ™‚
                Well, it turns out that its super simple to implement a modifier key rotation. SO I'll go ahead and do that. I tried shift and it kept rotating when I was trying to orbit and pan with shift key and middle mouse button. Alt was no good, kept opening the menu system and it was annoying to have to keep click back off of the menu.
                I think I'll do the up arrow key. Thats convenient and not in use while my tool is activated.
                In fact, I've pretty much got it implemented and its quite nice. I'll have the update in a little bit.
                  UPDATE! v1.2 Implemented some of the stuff we've been discussing in previous posts.
                  v1.2 Updates:
                  • Changed so that circles default to have their vertices on top and bottom, not edges.
                  • The up arrow key rotates the faces after they have been placed. Squares will rotate 45 degrees. Circles will rotate the angle needed to alternate between having an edge or a vertex on the top. Custom faces rotate in 90 degree increments. Helpful for fixing faces that are oriented 180 off, or that were drawn on the wrong axis.
                  Sorry to everyone who has been downloading every update today....3 installs in one day! Thanks for trying this script.
                    Funny sound video! A new ambiance ๐Ÿ˜‰
                    • free agentF Offline
                      free agent
                      wow thanx this script should be awsome now all i need is the occasion to use it.
                        Chris, thank you very much for plugging away at this (pun intended ๐Ÿ˜„)
                        I just zipped out the attached in about 2 minutes thanks to this plugin. I think I can see some neat applications for this.
                        http://img.photobucket.com/albums/v506/weekender410/horn.jpg
                          dylan
                          Dave that is exactly the sort of thing I thought of using this for when I realized the new features added.
                          Thanks Chris, this is fantastic ๐Ÿ‘
                          http://dmdarchitecture.co.uk/
                            Dylan, I was just experimenting and came up with this thing. It could be a drawer or door pull or something. I could have made the corners a bit more rounded but since I started out not knowing what I was going to draw, this is alright. The section is an ellipse and it is thicker in the middle than at the ends. Between Chris's plugin and the Skin plugin, this was all dead simple and fast work.
                            http://img.photobucket.com/albums/v506/weekender410/handle.jpg
                              Hey, great woork. Its good to see the plugin being used!
                                sweet, the circle is working great now..
                                i'm starting to feel like a pest now but i can't get the rotation to work on my mac.. it doesn't bother me but some other mac users might like the rotate option (and actually, i probably will too once i find myself doing a custom profile).
                                the status bar says this when i'm using the script:
                                Click on a line-end to place a perpendicular square on it. ctrl = Use "Arbitrary Rotation"
                                the ctrl key on a mac (in conjunction with the mouse) triggers a right click.
                                • jim smithJ Offline
                                  jim smith
                                  Great tool Chris - I can see quite a few uses.
                                  I could see this type of script speeding up the process of putting a model together from imported cad elevations. Attached is a WIP showing a model I just started to assemble from autocad parts. My process now is to make faces, rotate and snap together. I wonder if there is any chance that a divided surface might eventually take advantage of this script?site_03-26-09.jpg
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                  • MALAISEM Offline
                                    MALAISE
                                    Hi Chris, really good tool ๐Ÿ˜
                                    Just have a look :
                                    MALAISE
                                    La Connaissance n'a de valeur que partagรฉe
                                      Hmm, interesting I'll look at that cosmetic issue.
                                      Also, is there someone on a Mac who would be able to help me find the right key for the up arrow? You would just install the little ruby attached to this message like a regular ruby. Then run sketchup. Open the ruby console and type:
                                      load 'key_finder.rb'
                                      After you type that, leave the ruby console open. And click back into the Sketchup window. Then press the up arrow. A message will display in the ruby console. Hopefully something like
                                      The Key identifier is: 38
                                      Could you please copy and paste that message back here for me?
                                      Probably just delete the file from your plugins folder afterwards. Thanks
                                      key_finder.rb
                                        The Key idenetifier is: 63232
                                        (that's for the up arrow)
                                        [took me a while to figure out how to open the ruby console ๐Ÿ˜† ]
                                          Excellent, thanks! I'll try to get that worked into the code tonight.
                                          Also, I've thought about trying to make it more compatible with multiple faces. It would not be all that difficult to make it work with multiple flat faces. It would take a little bit more work to get it to work with non-planar faces. But I have a feeling that if I sat down and tried to make it work like that, I would also iron out the bug that makes the custom face tool slightly unpredictable. So maybe it would be good. But multiple planar faces would actually probably be pretty straightforward to implement.
                                          Thanks for the help and suggestions everyone,
                                            Jim
                                            Don't the key constants work? It seems like the most portable solution.
                                            • 11
                                            • 8 / 11
