    Apples ( play whit UV ruby
    34 Posts 14 Posters 4.8k Views 14 Watching
    • MALAISEM Offline
      MALAISE
      Thank you Majid for sharing your know-how. Very close to reality theses apples. How long did you work on such a drawing ? It's near perfect ๐Ÿ‘ ๐Ÿ‘
      MALAISE
      La Connaissance n'a de valeur que partagรฉe
      • majidM Offline
        majid
        MALAISE
        sorry for so late answer ... First i take a foto using my cellphone and about 2 days later i started the modeling and texturing .. it tooke me about half day , and 2 or 3 hours for rendering ( to finde a true material setting + lights - also i made a HDRI file as background_).
        cheerss majid
        • romboutR Offline
          rombout
          @majid said:
          hi all ,i did a try whit uv ruby to texture these apples ,what a usefull ruby , hope to be improved soon . cheers
          http://i34.tinypic.com/2rnhmz7.jpg
          http://i37.tinypic.com/9zqbk3.jpg
          http://i33.tinypic.com/xel6vc.jpg
          cheers majid
          wow this is great. i also understand the mapping in photoshop.... but how did you map it correct in SU, im missing that part
          • Z Offline
            zumo
            well done these are the most realistic thing I have seen on sketch up to date!
            • FrederikF Offline
              Frederik
              You should take a closer look at the [Plugin] UVTools v0.1 thread... ๐Ÿ˜‰
              Cheers
              Kim Frederik
              • romboutR Offline
                rombout
                oke... but how do you apply it to a mesh. cause the top and the side of the apple is at a different place. how do you place it on your mesh
                • romboutR Offline
                  rombout
                  i understand the wrapping but how does the "top" of the apple wrap at the the top of the mesh. If you open the map in PS you'll see a image skin in width and the top of the apple somewhere at the left
                  • majidM Offline
                    majid
                    It is all about good texturing . I've made a mini tutorial and shared it at previos page . it's name is "MIZ2" . please take a closer look at it. i guess it'd help you
                    • romboutR Offline
                      rombout
                      oke oke oke...
                      you dont get it.... atleast i dont get it... i understand everytihing about making a map and so... but if you have your mesh and you apply your map. How do you get the top of the apple at the correct place and the side at the side. You need to apply a map to the mesh unwrap this with a different application and than put your mapping to that unwrapped image. but this is not written in the tut
                      • majidM Offline
                        majid
                        UVTool v1.0 is very simlpe . it doesnt unwrap , but simply it adds 2 new commands to your right-click menu that lets you to have "spherical" or "cilinderical" mapping to your mesh, it desn't undersyand which mesh you have selected, but remaps it as a sphere or a cilinder. it desnt separate mesh parts
                        • romboutR Offline
                          rombout
                          oke i think i need to explain it better. you had your apple mesh how did the map got applied so perfect to the apple.
                          cause if copy the apple delete the map and remap it within SU. Than how do you place the map perfect around the apple so the top is at the top and the bottom at the bottom. I understand the plugin. I want to know how apply the image perfect to your mesh.
                            Jackson
                            Rombout,
                            Make a vertical grouped plane next to the apple which is exactly the same height (a simple method is to pushpull a grouped box so that it is fits around the apple, then move it to one side). Import your image, scale it to the same height as the plane, explode it and then apply the map using UVTool. The same principle applies for applying an exact sized texture to any geometry.
                            Jackson
                            • romboutR Offline
                              rombout
                              @jackson said:
                              Rombout,
                              great jackson,
                              thank you very much. that was what i meant. I thought i saw a different map of the apple in here. where it has a separate top and bottom view. This mapping trick is real handy. ๐Ÿ˜
                              • FrederikF Offline
                                Frederik
                                Rombout,
                                If you had only taken some time to read some of the postings made in the [Plugin] UVTools v0.1 thread, I'm sure you would have figured things out... ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                • romboutR Offline
                                  rombout
                                  hahahaha.. sorry! my BAD, just a graphic designer in a hurry ๐Ÿ˜‰
                                    Jackson
                                    rombout,
                                    It works for the apple just the same as it does for a sphere. Sadly I tested the cylindrical UV wrap and it doesn't work for bananas! ๐Ÿ˜ž ๐Ÿ˜†
                                    Jackson
                                    • romboutR Offline
                                      rombout
                                      me again,
                                      is there a way to get this text mapped nice around this object. Ive tried to tilted the text. making it in a circle. I thought i needed to tilt the text a bit so it matches the angel of the border. That didnt worked out properly
                                      • majidM Offline
                                        majid
                                        dear rombout, you have projected the texture, but if you install uvtool you can do a right-click over the same material and the adjust is as cilynderical textureing. maybe then you need to adjust material size using material editor.
                                        • romboutR Offline
                                          rombout
                                          wow what a work... and this is just a simple text. after a lot of trial error i could adjust the so it fits nice. now i need to copy it over around the circel. I was a lot of scaling done in Illustrator
                                          How can i close gaps in a small model? i made this at a bigger scale a reduced it than. But the gaps keep coming back
                                          • romboutR Offline
                                            rombout
                                            oke me again... another mapping issue, did tried all the tricks but i cant seem to get it right. started to learn blender to learn some UVmapping
                                            • 2 / 2
