    Image export size test
    27 Posts 10 Posters 2.7k Views 10 Watching
    • PixeroP Offline
      Pixero
      This thread is for testing what maximum size can be exported with your hardware setup.
      Please specify:
      Processor
      RAM
      Graphic card and memory
      OS
      SketchUp version
      Width and height of your maximum exported image in pixels.
      This is the model I thought we'd use since its from 3d warehouse.
      http://sketchup.google.com/3dwarehouse/details?mid=d218e86bdbc5ab2b972ec726e7a08cca&prevstart=72
      All tests should be with default camera position and anti alias and shadows ON.
      Also be sure you're only running SU while doing the test.
      Edit: jpg highest quality and shadows on in the display shadows menu.
      • PixeroP Offline
        Pixero
        Here's my home result:
        Processor: Intel Core2 duo 3ghz
        RAM: 4gb
        Graphics card: Nvidia Geforce 9800gt 512mb
        OS: Vista 32 bit
        SU version: SketchUp 7 pro
        Maximum exported image: 5650x3206 pixels.
          bubbalove
          Processor: Intel Core2 duo 2.53ghz
          RAM: 2gb
          Graphics card: Nvidia Geforce 8500gt 512mb
          OS: XP 32 bit
          Maximum exported image: 4951x2750 pixels in .png format if that matters...
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
          • Jean LemireJ Offline
            Jean Lemire
            Hi Jan, hi folks.
            Shadows on, no problem.
            Antialiasing on, which one ? The one in OpenGL preference ? on the one in the export option ? I presume that this is the one you are refering to.
            Which file format ? I presume that you want JPG.
            Which position for the JPG compression cursor ? Max. quality or min. file size or in between ?
            Just ideas.
            • PixeroP Offline
              Pixero
              I've edited first post with jpg compression and shadows.
                remus
                Core 2 duo E6750 2.66 Ghz
                4GB
                geforce 7800 (not sure about memory)
                Vista 64 ultimate
                SU 7
                5600x3167
                no AA: 9999x5655
                  Processor: Intel Core2 Quad 9450 3.3ghz (OC)
                  RAM: 8GB
                  Graphics card: Nvidia Geforce 8800GT 512MB
                  OS: Windows7 64bit
                  SU Version: SketchUp 7 pro
                  With AA: 5650x3081 pixels.
                  Without AA: 9500x5180 pixels
                  I found that when SU failed to export I often had to restart SU in order to successfully export again afterwards.
                    That might matter. Compressing the image require exptra calcualtiuons. And different compressions methods might give different results.
                    That would also be interesting to see. If saving to a raw uncompressed bitmap allows you to export larger...
                      Made the topic sticky. Will chime in (and test) when back home.
                      • PixeroP Offline
                        Pixero
                        Thomthom, interesting to see that you with double the amount of RAM and 64bit OS you can export approx the same max size as I can (with AA). One would think it would be much higher.
                          Note that since SU is (only) a 32 bit application, it cannot utilize anything that's beyond it.
                            Since SU is a 32bit application I'm still under the 32bit limitations even though I have a 64bit system... 😞
                            • jeff hammondJ Offline
                              the old workhorse...
                              mac 17"powerbook
                              Processor: 1.33 PowerPC G4
                              RAM: 1gb
                              Graphic card and memory: ATI mobility Radeon 9600 64MB
                              OS: tiger 10.4.11
                              SketchUp version: 6.4.120 p
                              9500 x 7055
                              (in just over 20 minutes πŸ˜† )
                              this pretty much shows the items in the list are irrelevant to image export size... well, except one of the entries πŸ˜‰
                              • DanielD Offline
                                Daniel
                                WORK:
                                Intel Core 2 Duo 2.66 GHz
                                3GB RAM
                                NVIDIA GeForce 8800 GT
                                XP Pro
                                SU Pro 7.0.10247
                                Image size: 5225 x 2878
                                HOME:
                                Intel Core 2 Quad Q6600 2.40 GHz
                                4GB RAM
                                NVIDIA GeForce 8600 GT
                                XP Pro
                                SU Pro 7.0.10247
                                Image size: 5550 x 3083
                                LAPTOP:
                                Intel Core 2 Duo T7500 2.20 GHz
                                4GB RAM
                                NVIDIA GeForce 8600M GT
                                XP Pro
                                SU Pro 7.0.10247
                                Image size: 5000 x 2656
                                My avatar is an anachronism.
                                  weird thing though: lots of different aspect ratios coming out..
                                  what's dictating that?
                                  [edit] nevermind.. it's just using the same aspect ratio as the sketchup window on whoever's computer. if you really wanted to get into it, everyone should be exporting at a certain ratio instead of locking to their window..
                                    macpro quad:
                                    Processor: 2X- 2.66 dual-core intel xeon
                                    RAM: 7GB
                                    Graphic card and memory: geforce7300 GT 256MB
                                    OS: leopard 10.5.6
                                    SketchUp version: 7pro latest
                                    Width and height of your maximum exported image in pixels:
                                    10,000 x 6590
                                    crashed when i tried 12,000
                                    [edit] 14,250 x 9390 with AA off
                                    (28MB)
                                    • PixeroP Offline
                                      Pixero
                                      So as a little first round up it seems that on Windows no one can export higher than 5650 width.
                                      On OSX its almost twice that with 10000 pixels wide.
                                      Has anyone tried increasing virtual memory in Windows to see what effect that has?
                                        remus
                                        From a theoretical point of view, i dont think changing virtual memory would help, as the limit is in sketchup itself i.e. SU is maxing out before it can use all the RAM available to it.
                                          Don't think it's the RAM. It's the maximum single chuck of memory it can address. If you don't have enough RAM it will page it out to the pagefile, but the limit is how much memory (note: not RAM) windows 32bit applications can handle.
                                          • DanielD Offline
                                            Daniel
                                            I know from experience that virtual memory does make a slight difference. In fact, for this excercise, my office computer had VM set at 6,000 mb and the widest image I could get ws 5,000 - I increassed the VM to 200,000 and was able to get a 5,225 wide image.
                                            I'll admit that most of this computer jargon goes over my head, but looking at my own results I have to conclude that it is a combination of the processors and the video card.
