    How does this window work? ;)
    42 Posts 14 Posters 5.1k Views 14 Watching
      sepo
      Still very good workarround if you are still designing. Saves a lot of time. 👍
      Thomthom
      "I'm getting pretty close to generating a cutout component on parallel faces to cutout components. Got to find a good way to manage and keep track of them."
      That sounds like very good news.
        @sepo said:
        Thomthom
        Generating the opposite cutouts where easy. Trying to keep track of them all and ensure that all new components placed also cuts double is more work.
          sceyefeye
          you guys are giving me a headache just thinking about this
          could have sworn that Renderplus or one of those tools had a multi-line wall, just trying to think where I imagined I saw it
          what amazes me is that google haven't co-opted a lot of these scripts as "standard" functionality. I sometimes wonder if there is a reluctance to make google too powerful (I know the idea of sketchup is to be simple) but everywhere I turn people are not using it for "simple"
          • GaieusG
            @sceyefeye said:
            ...I sometimes wonder if there is a reluctance to make google too powerful (I know the idea of sketchup is to be simple) but everywhere I turn people are not using it for "simple"
            I wouldn't necessarily like Google to adopt many things. Plugins are for that. The reason is that SU is used by so many people for so many purposes that all these functions cannot be adapted.
            So currently some use this plugin while others use that plugin. This is much better this way IMO. Google should be focussing on improving the core product (as several of the members here keep expressing it) and AFAIK in SU 7 it was already essentially improved since plugins can work MUCH faster now than before.
            • E
              Ecuadorian
              Google SketchUp's development team seem to follow the KISS Principle:
              http://en.wikipedia.org/wiki/KISS_principle
              -Miguel Lescano
                I do like the plugin method of making applications. Look at Firefox. It's the plugin that makes it. That people can adapt it to fit as they like. But it sure would be nice if there where more things exposed in the SU API. For SU8 I'd be satisfied if it was purely a stability and bugfix release for the core engine but with more things exposed to the API. Improving it as a platform, not as application.
                • W
                  wmanning
                  Gai, the double-cut can be done with a single dynamic component. This hole in the wall came from Scott Lininger... It isn't a "proper" window, but is designed to apply a hole in the center of the wall segment. You can scale the wall thicker, thinner, wider, taller and it always cuts properly! It's a good example for a nested dynamic component. (Rendered with IDX Renditioner.)
                  William
                  Hole2.skp
                  • GaieusG
                    Ah yes, William, but if you look at it from this point of view: that whole wall segment is just a "standalone" window component which of course can be scaled 😉
                    You can do the same with the front face of this model and it's not even dynamic!
                    [attachment=0:34ob4oem]<!-- ia0 -->http://WWW.jpg<!-- ia0 -->[/attachment:34ob4oem]
                    WWW.skp
                    Rendered with IDX Renditioner - maybe added too much bumpiness - sorry :)
                    • B
                      BTM
                      Yes, but the difference is that, no matter how you scale it (the dynamic component), the hole will be circular, and the same size.
                      • GaieusG
                        Well, I could surely have made those windows circular in my example - doesn't really matter. They also remain of the same size - or am I missing something here? 😕
                        • Chris FullmerC
                          If you scale your wll to be shorter, your windows get proportionately shorter. You can program the DC window to not do that. You can make it always stay that same size.
                          • GaieusG
                            Ah, you mean scaling it "sideways" in this case? I was only doing it in the direction of the wall thickness in this case (as the original examples were about it as well).
                            • 2 / 3
