    You won't believe it.. but it is true :)
    33 Posts 17 Posters 3.2k Views 17 Watching
    • T
      tomasz
      Jeff, thanks for the link.
      The original direction stored in GIF is left (counterclockwise).
      In order to achieve right direction a brain has to be creative.
      I don't think the shadow is a key to switching directions... at least it doesn't work for me.
      Neither tricks with a mouse.
      The figure is asymmetrical..
      A brain has to play the frames in opposite direction...? then... if should always start first spin in a stored - left direction.. but it doesn't!
      Is it just a trick of a mind? I haven't found an explanation on the company website...
        Only Right ๐Ÿ’š
        Edit : Left now ๐Ÿ˜ฎ
        I use the mousewheel updown quickly then release!
        Terrific effect! ๐Ÿ˜ฒ If it's not a fake, our brain is a true liar ๐Ÿ’š
        • MALAISEM
          MALAISE
          You're experiencing how our brain "works" ( As far as It's a part of ourself!) New cognition science branch:
          how to explore conscience and explain magical illusions.... ๐Ÿ‘
          MALAISE
          La Connaissance n'a de valeur que partagรฉe
          • N
            notareal
            Funny, first look do gives me clock wise rotation, but just a brief concentration to the image turns rotation to counter clock wise and the if I turn my concentration to the text the animation starts running with clock wise rotation again. This is a keeper, thanks.
            • F
              FenS
              What lady? I only see a Rorschach-butterfly ๐Ÿ˜„
              Really like this one and the same for me, the direction of spinning changes when I am looking at the lady or when I am reading the text below her.
              Quรฉ sais je? there is still so much to be learned...
                sintra
                Hi Tomasz,
                Really cool post very interesting and addictive.
                At first i saw it anti clockwise, i looked away then all i see is her going clockwise and its been like that since arghhhhh ๐Ÿ˜† ๐Ÿ˜†
                • B
                  BTM
                  I can see it either way if I want to. I even tried to see if I could get it to do half turns and reverse, So it looks like it's facing away, then does a half turn and faces you, then another half turn the other direction, and faces you again, as if it had never changed. and it worked. Creepy... ๐Ÿ˜ฒ
                  • AnssiA
                    Anssi
                    This demonstrates our utter failure to see it as a 2D shape. I got this illusion even in the real world when I sat waiting for a plane. On the opposite side of the runway a radar antenna was spinning, silhouetted against the sky. It was quite easy to make it "shift direction".
                    Anssi
                      sorgesu
                      This is wild. I can actually take note of the second she changes direction. There is hiccup. A suspended moment when she seems to pause and then she changes direction.
                      When I first looked at her, she was consistently going counter clockwise. After a while she suddenly changed direction and I couldn't force the counter clockwise again. Until I started reading the text and then she reversed. It seems that when I first looked at her, I was 'analyzing' the situation. Then when I understood the situation, I automatically switched to right brain mode. Once I read, I was back into left brain. If I looked up at her again, she would switch and go clockwise. Wow.
                      Susan Sorger
                      Former Seller Hand Rendered Entourage
                      Former Canadian Authorized Training Centre, SketchUp
                        It's not a default of the "Windows viewer" or a default of the "Navigator viewer"? ๐Ÿ˜‰
                        • pbacotP
                          her posture is for a clockwise direction. Is that part of the visual cues your left brain is using? Dancers commonly lead with their head and outstretched hand.
                          So far I can see the other direction with it upside down but it goes back to clockwise when I turn it at all back towards right side up.
                          EDIT: I had it all wrong. When you see her go either way it looks like the same posture. Once I saw her going counterclockwise, I couldn't go back it seems.
                            Aidus
                            She is not rotating at all. Just wobling from one side to other. It's hard to see but so it is.
                            CPU: Intel Core i7 Extreme Edition 965
                            RAM: OCZ Gold DDR3 1600MHz 12Gb
                            Video: Asus Radeon HD4870 X2 2Gb
                            Mobo: Asus P6T Deluxe 1366 Intel X58
                              Another method ๐Ÿ˜„
                              Blink your eyes and turn your head in the wishing turn wanted ๐Ÿ˜‰
                              • T
                                tomot
                                I just caught a glimpse, just before she was sliding down the pole.
                                (I gotta get that checked out soon!)
                                my plugins
                                tomot
                                  sorgesu
                                  okay, I checked this out and it is totally debunked here: http://scienceline.org/2007/10/29/ask-hsu-spinning-girl-right-left-brain-hemispheres/
                                  It really has nothing at all to do with left brain/right brain perceptions at all.
                                  Anssi was completely right. It is about forcing a 3D understanding onto something that is 2D.
                                  Susan Sorger
                                  • T
                                    tomasz
                                    They are writing that associating left or right hemisphere of a brain with a certain activities is just a theory, which is not really true, but the fact that some people cannot see it spinning clockwise proves that it has to do something with imagination... just see the image I have prepared for you:
                                    I think that image can help those with 'one direction only' find a way to switch. Why? Take a closer look at each individual frame. I can easily see all those intermediate frames between those when the position of the lady IS certain, as a lady facing me or showing her back ๐Ÿ˜„!
                                    Our imagination decides if we see the front or the back because the silhouette doesn't define it exactly.
                                    Tomasz
                                      sorgesu
                                      so maybe you intended to mirror one of the pictures? They appear the same to me.
                                      Susan Sorger
                                      • jeff hammondJ
                                        me?
                                        they're fully different .. i edited that post to put a big space in between the two gifs so you can look at them one at a time
                                        • jeff hammondJ
                                          i think these modifications can really help those seeing only one direction (via the site susan linked to)
                                          counter clockwise
                                          http://ofb.net/~whuang/imgs/spin/spin-ccw.gif
                                          clockwise
                                          http://ofb.net/~whuang/imgs/spin/spin-cw.gif
                                            sorgesu
                                            Works for me now, though the first one is apt to change direction for a moment.
                                            I was looking to see the differences in the direction of the rings in the background and or the darkness. I honestly cannot see the difference. What am I missing?
                                            PS> "me?" ????
                                            Susan Sorger
