    You won't believe it.. but it is true :)
    33 Posts 17 Posters 3.2k Views 17 Watching
      Aidus
      Well I see both directions ๐Ÿ‘Š
      CPU: Intel Core i7 Extreme Edition 965
      RAM: OCZ Gold DDR3 1600MHz 12Gb
      Video: Asus Radeon HD4870 X2 2Gb
      Mobo: Asus P6T Deluxe 1366 Intel X58
      • T
        tomasz
        Jeff, thanks for the link.
        The original direction stored in GIF is left (counterclockwise).
        In order to achieve right direction a brain has to be creative.
        I don't think the shadow is a key to switching directions... at least it doesn't work for me.
        Neither tricks with a mouse.
        The figure is asymmetrical..
        A brain has to play the frames in opposite direction...? then... if should always start first spin in a stored - left direction.. but it doesn't!
        Is it just a trick of a mind? I haven't found an explanation on the company website...
          Only Right ๐Ÿ’š
          Edit : Left now ๐Ÿ˜ฎ
          I use the mousewheel updown quickly then release!
          Terrific effect! ๐Ÿ˜ฒ If it's not a fake, our brain is a true liar ๐Ÿ’š
          • MALAISEM
            MALAISE
            You're experiencing how our brain "works" ( As far as It's a part of ourself!) New cognition science branch:
            how to explore conscience and explain magical illusions.... ๐Ÿ‘
            MALAISE
            La Connaissance n'a de valeur que partagรฉe
            • N
              notareal
              Funny, first look do gives me clock wise rotation, but just a brief concentration to the image turns rotation to counter clock wise and the if I turn my concentration to the text the animation starts running with clock wise rotation again. This is a keeper, thanks.
              • F
                FenS
                What lady? I only see a Rorschach-butterfly ๐Ÿ˜„
                Really like this one and the same for me, the direction of spinning changes when I am looking at the lady or when I am reading the text below her.
                Quรฉ sais je? there is still so much to be learned...
                  sintra
                  Hi Tomasz,
                  Really cool post very interesting and addictive.
                  At first i saw it anti clockwise, i looked away then all i see is her going clockwise and its been like that since arghhhhh ๐Ÿ˜† ๐Ÿ˜†
                  • B
                    BTM
                    I can see it either way if I want to. I even tried to see if I could get it to do half turns and reverse, So it looks like it's facing away, then does a half turn and faces you, then another half turn the other direction, and faces you again, as if it had never changed. and it worked. Creepy... ๐Ÿ˜ฒ
                    • AnssiA
                      Anssi
                      This demonstrates our utter failure to see it as a 2D shape. I got this illusion even in the real world when I sat waiting for a plane. On the opposite side of the runway a radar antenna was spinning, silhouetted against the sky. It was quite easy to make it "shift direction".
                      Anssi
                        sorgesu
                        This is wild. I can actually take note of the second she changes direction. There is hiccup. A suspended moment when she seems to pause and then she changes direction.
                        When I first looked at her, she was consistently going counter clockwise. After a while she suddenly changed direction and I couldn't force the counter clockwise again. Until I started reading the text and then she reversed. It seems that when I first looked at her, I was 'analyzing' the situation. Then when I understood the situation, I automatically switched to right brain mode. Once I read, I was back into left brain. If I looked up at her again, she would switch and go clockwise. Wow.
                        Susan Sorger
                        Former Seller Hand Rendered Entourage
                        Former Canadian Authorized Training Centre, SketchUp
                          It's not a default of the "Windows viewer" or a default of the "Navigator viewer"? ๐Ÿ˜‰
                          • pbacotP
                            her posture is for a clockwise direction. Is that part of the visual cues your left brain is using? Dancers commonly lead with their head and outstretched hand.
                            So far I can see the other direction with it upside down but it goes back to clockwise when I turn it at all back towards right side up.
                            EDIT: I had it all wrong. When you see her go either way it looks like the same posture. Once I saw her going counterclockwise, I couldn't go back it seems.
                              Aidus
                              She is not rotating at all. Just wobling from one side to other. It's hard to see but so it is.
                                Another method ๐Ÿ˜„
                                Blink your eyes and turn your head in the wishing turn wanted ๐Ÿ˜‰
                                • T
                                  tomot
                                  I just caught a glimpse, just before she was sliding down the pole.
                                  (I gotta get that checked out soon!)
                                  my plugins
                                  tomot
                                    sorgesu
                                    okay, I checked this out and it is totally debunked here: http://scienceline.org/2007/10/29/ask-hsu-spinning-girl-right-left-brain-hemispheres/
                                    It really has nothing at all to do with left brain/right brain perceptions at all.
                                    Anssi was completely right. It is about forcing a 3D understanding onto something that is 2D.
                                    Susan Sorger
                                    • T
                                      tomasz
                                      They are writing that associating left or right hemisphere of a brain with a certain activities is just a theory, which is not really true, but the fact that some people cannot see it spinning clockwise proves that it has to do something with imagination... just see the image I have prepared for you:
                                      I think that image can help those with 'one direction only' find a way to switch. Why? Take a closer look at each individual frame. I can easily see all those intermediate frames between those when the position of the lady IS certain, as a lady facing me or showing her back ๐Ÿ˜„!
                                      Our imagination decides if we see the front or the back because the silhouette doesn't define it exactly.
                                      Tomasz
                                        sorgesu
                                        so maybe you intended to mirror one of the pictures? They appear the same to me.
                                        Susan Sorger
                                        • jeff hammondJ
                                          me?
                                          they're fully different .. i edited that post to put a big space in between the two gifs so you can look at them one at a time
                                          • jeff hammondJ
                                            i think these modifications can really help those seeing only one direction (via the site susan linked to)
                                            counter clockwise
                                            http://ofb.net/~whuang/imgs/spin/spin-ccw.gif
                                            clockwise
                                            http://ofb.net/~whuang/imgs/spin/spin-cw.gif
