    [Plugin] Mirror UV Mapping (1.0.3)
    35 Posts 17 Posters 34.5k Views 17 Watching
      You want to disable edges and transparency. And maybe even turn off textures. Basically the very last thing you add to the scene before you render.
      Use 3D trees for the foreground and use the billboards for the background..
      • B
        bianhai
        Thanks Thomas ๏ผ ๐Ÿ‘
          silver_shadow
          free agent would be sooooooooo happy. โ˜€
          • free agentF
            free agent
            ...and he is ๐Ÿ’š
            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
              davide.skp
              tom, I test billW code and your too but still some problem...
              404 Not Found
              (www.sketchucation.com)
              I whant to create a library of very light 3d trees made with tree [d] and gile [s]
              can you help me ....
              • free agentF
                free agent
                Quote: I've discovered that it doesn't handle faces with less than three points. When importing X-Frog trees the leaf tends to be split in half forming two triangles. So until I've corrected this, make sure you enable Merge Coplanar Faces in the Import Options
                do you mean four points? u cant get a face with 2 points
                  Ah, you discovered my cunning test to see if anyone actually read this stuff! ...erh.. yea.. that's what I meant. less than four points.
                  • free agentF
                    free agent
                    ๐Ÿ˜Ž no worries thom just keeping you on ur toes
                      Updated so it transfers plain colour materials as well.
                      • MALAISEM
                        MALAISE
                        Thanks Thomthom
                        MALAISE ๐Ÿ˜„
                        La Connaissance n'a de valeur que partagรฉe
                        • Chris FullmerC
                          Great Thom, very cool!
                          • I
                            ideas_arte
                            YES..! I WANT TO PARTICIPATE, INCLUDES TO ME I have many Xfrog
                            Thank you very much thomthom for plugin,
                            • soloS
                              Someone mention ex frog?
                              http://www.ruffordsmallgrants.org/files/rana muerta.jpg
                                Errrhh... ๐Ÿคข
                                  davide.skp
                                  Ivรกn, for now i'm playng with tree[d] and Hothouse 3d... this one, hothouse, seems very very good!!! ... I try xfrog but ... too expensive ((and complexxx) for me ๐Ÿ˜ž ...
                                  so, TRY HotHouse ...
                                  A) create your plant with hothouse
                                  B) for a light model create some billboard ... from a photo or directly from HotHouse
                                  C) import directly in sk
                                  d) With the WONNDERRFULLL ThoMThom'plugin Mirror the uv map...
                                  very very funny!!!
                                  • I
                                    ideas_arte
                                    very very funny!!!
                                    Thank you very much..! to share this info, ๐Ÿ˜„ I will try to make some little pines ๐Ÿ’š
                                    Take care ๐Ÿ‘
                                    • free agentF
                                      free agent
                                      thomthom have u looked into the texture mirroring to the backfaces of triangles? is it possible?
                                        It doesn't mirror triangles?
                                        • free agentF
                                          free agent
                                          woah thats wierd, it refuses to mirror on a mesh ive imported, but works fine on a quick separate test... can i send you the problem mesh?
                                            Yea, do so. I'll have a look at it.
