    [Plugin] Mirror UV Mapping (1.0.3)
    35 Posts 17 Posters 33.9k Views 17 Watching
    • free agentF Offline
      free agent
      ...and he is 💚
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
        davide.skp
        tom, I test billW code and your too but still some problem...
        404 Not Found
        (www.sketchucation.com)
        I whant to create a library of very light 3d trees made with tree [d] and gile [s]
        can you help me ....
          free agent
          Quote: I've discovered that it doesn't handle faces with less than three points. When importing X-Frog trees the leaf tends to be split in half forming two triangles. So until I've corrected this, make sure you enable Merge Coplanar Faces in the Import Options
          do you mean four points? u cant get a face with 2 points
            Ah, you discovered my cunning test to see if anyone actually read this stuff! ...erh.. yea.. that's what I meant. less than four points.
              free agent
              😎 no worries thom just keeping you on ur toes
                Updated so it transfers plain colour materials as well.
                • MALAISEM Offline
                  MALAISE
                  Thanks Thomthom
                  MALAISE 😄
                  • Chris FullmerC Offline
                    Great Thom, very cool!
                    • I Offline
                      ideas_arte
                      YES..! I WANT TO PARTICIPATE, INCLUDES TO ME I have many Xfrog
                      Thank you very much thomthom for plugin,
                      • soloS Offline
                        Someone mention ex frog?
                        http://www.ruffordsmallgrants.org/files/rana muerta.jpg
                          Errrhh... 🤢
                            davide.skp
                            Iván, for now i'm playng with tree[d] and Hothouse 3d... this one, hothouse, seems very very good!!! ... I try xfrog but ... too expensive ((and complexxx) for me 😞 ...
                            so, TRY HotHouse ...
                            A) create your plant with hothouse
                            B) for a light model create some billboard ... from a photo or directly from HotHouse
                            C) import directly in sk
                            d) With the WONNDERRFULLL ThoMThom'plugin Mirror the uv map...
                            very very funny!!!
                            • I Offline
                              ideas_arte
                              very very funny!!!
                              Thank you very much..! to share this info, 😄 I will try to make some little pines 💚
                              Take care 👍
                                free agent
                                thomthom have u looked into the texture mirroring to the backfaces of triangles? is it possible?
                                  It doesn't mirror triangles?
                                    free agent
                                    woah thats wierd, it refuses to mirror on a mesh ive imported, but works fine on a quick separate test... can i send you the problem mesh?
                                      Yea, do so. I'll have a look at it.
                                      • utilerU Offline
                                        utiler
                                        I liked it Pete..... 🤣 🤣
                                        Just Curious...
                                          If you tried to email me anything then it might very well be lost. My host messed about with some files and I lost my email aliases. ...grumble...
                                            araki009
