    [Plugin] Mirror UV Mapping (1.0.3)
    35 Posts 17 Posters 34.0k Views 17 Watching
      Obsolete
      The functionality of this plugin has been merged with UV Toolkit
      The background for this plugin is that I got a large collection of X-Frog trees. When imported into SketchUp the backface texture is messed up.
      BillW was nice enough to provide a code snippet that copied the texture and UV mapping from one side to the other. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13083&st=0&sk=t&sd=a&start=15#p110957
      I just wrapped it up into two function to allow frontface to backface and backface to front face and made it crawl into nested groups/components.
      It's also much faster that I expected. With a test tree of 82K faces and 132K edges it took about 2 minutes with SU6 and about 30 seconds with SU7.
      Update:
      Version 1.0.1
      • Moved functions into module
      • Rearranged the menus
      • Accounted for faces with tree vertices
      Version 1.0.2
      • Fixed some typo in the code
      Version 1.0.3
      • Now transfer plain colour material
      For some reason the script throws an exception on some occasions with faces with tree vertices. I don't understand why. Nor do I see any effect of it in the model. But I've worked around it by adding an exception handler. If anyone can shed some light to why it throws an exception some times I'd be grateful.
      Full Size
      Full Size
      Obsolete
        tomasz
        Thanks Thomas ๐Ÿ˜„ How SU handle several X-frog trees in a model? Does it slow down the whole thing a lot (probably no edges displayed).
        Tomasz
          You want to disable edges and transparency. And maybe even turn off textures. Basically the very last thing you add to the scene before you render.
          Use 3D trees for the foreground and use the billboards for the background..
            bianhai
            Thanks Thomas ๏ผ ๐Ÿ‘
              silver_shadow
              free agent would be sooooooooo happy. โ˜€
              • free agentF Offline
                free agent
                ...and he is ๐Ÿ’š
                http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  davide.skp
                  tom, I test billW code and your too but still some problem...
                  404 Not Found
                  (www.sketchucation.com)
                  I whant to create a library of very light 3d trees made with tree [d] and gile [s]
                  can you help me ....
                    free agent
                    Quote: I've discovered that it doesn't handle faces with less than three points. When importing X-Frog trees the leaf tends to be split in half forming two triangles. So until I've corrected this, make sure you enable Merge Coplanar Faces in the Import Options
                    do you mean four points? u cant get a face with 2 points
                      Ah, you discovered my cunning test to see if anyone actually read this stuff! ...erh.. yea.. that's what I meant. less than four points.
                        free agent
                        ๐Ÿ˜Ž no worries thom just keeping you on ur toes
                          Updated so it transfers plain colour materials as well.
                          • MALAISEM Offline
                            MALAISE
                            Thanks Thomthom
                            MALAISE ๐Ÿ˜„
                            La Connaissance n'a de valeur que partagรฉe
                            • Chris FullmerC Offline
                              Great Thom, very cool!
                              • I Offline
                                ideas_arte
                                YES..! I WANT TO PARTICIPATE, INCLUDES TO ME I have many Xfrog
                                Thank you very much thomthom for plugin,
                                • soloS Offline
                                  Someone mention ex frog?
                                  http://www.ruffordsmallgrants.org/files/rana muerta.jpg
                                    Errrhh... ๐Ÿคข
                                      davide.skp
                                      Ivรกn, for now i'm playng with tree[d] and Hothouse 3d... this one, hothouse, seems very very good!!! ... I try xfrog but ... too expensive ((and complexxx) for me ๐Ÿ˜ž ...
                                      so, TRY HotHouse ...
                                      A) create your plant with hothouse
                                      B) for a light model create some billboard ... from a photo or directly from HotHouse
                                      C) import directly in sk
                                      d) With the WONNDERRFULLL ThoMThom'plugin Mirror the uv map...
                                      very very funny!!!
                                      • I Offline
                                        ideas_arte
                                        very very funny!!!
                                        Thank you very much..! to share this info, ๐Ÿ˜„ I will try to make some little pines ๐Ÿ’š
                                        Take care ๐Ÿ‘
                                          free agent
                                          thomthom have u looked into the texture mirroring to the backfaces of triangles? is it possible?
                                            It doesn't mirror triangles?
