    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    243 Posts 65 Posters 228.1k Views 65 Watching
      @utiler said:
      Goh,
      Having a problem with Dividing panels..... [see attached]
      Each time I set my parameters then select the face, the panel is placed at the axis origin. What am I doing wrong!!!
      Cheers
      That's the same problem I had with horizontal louvres. vertical works fine oddly enough. Open the Ruby Console and see if you get any messages.
        gohch
        @utiler said:
        Goh,
        Cheers
        hi utiler,
        The panel divider is meant for dividing a face into a few segments;
        1 row and 1 column will be the minimum.
        1 row and 0 column doesn't really make sense, hence the failure.
        I'll put in checking mechanisms in the dialog boxes in future so that undesired entry are either corrected or highlighted to the user.
        cheers!
          gohch
          hi thomthom,
          you're right, there's a bug there. just emailed you the patched hlouvres.rbs file.
          I'll put this in the version 1.1.3 release, hopefully tomorrow or day after.
          cheers!
            ๐Ÿ‘ Excellent!
            • utilerU Offline
              utiler
              Thanks Goh, I'll go try it out..... I assumed 1 row or 1 column would add a mullion or transom to the panel...
              Just Curious...
              • utilerU Offline
                utiler
                I did try that Goh but still the problem is occurring. I will PM you the .skp file and a short .swf file of the process.....
                thanks!!!
                Just Curious...
                  gohch
                  hi Andrew,
                  really odd, because i have no problem using the panel divider tool on the same face that you seems to have problem with,
                  with the same settings.
                  utiler-dividepanel.swf
                  i'll try a few different configurations and see....
                  thanks
                    gohch
                    hi everyone, version 1.1.3 is now ready for download.
                    Upgrades include:
                    1) Slope selected edges tool - converts selected edges to slope along a fixed gradient.
                    http://www.1001bit.com/products/slopeedges.shtml
                    user can enter:
                    • height difference
                    • angle (in degrees)
                    • gradient (as in 1 to 200)
                    • pick end level
                    This tool comes with an interactive dialog box that can be used to calculate angles, gradient, or height.
                    slope edges dialog box
                    This tool can be used to create sloping path/driveway from flat plane.
                    example of sloping foot path using slope edges tool
                    2) Extrude along path tool - extrude profile along selected path.
                    http://www.1001bit.com/products/extrude1.shtml
                    This tool solves the twisting problem that occurs when you extrude a profile along a curved and sloping path with SU's standard followme tool.
                    Useful for creating handrails for spiral staircases, carpark ramps, cicular ramps etc.
                    sloping curved ramp using extrude along path tool
                    3) Bug fixes on horizontal and vertical louvres tools.
                    User can now enter 0 for louver thickness to create single plane louvres.
                    4) Option to show different toolbars separately.
                    from menu View >> Toolbars
                    Installation
                    Just download the file
                    http://www.1001bit.com/download/1001bit(1.1.3).zip
                    and replace/overwrite the current files in your 1001bit folder.
                    The user license that you have for v1.1.x is still valid. If you choose to delete the old folders before installing the new ones,
                    Please keep a copy of the 1001bit.key file, which contains your license information.
                    As long as you put this file back into the 1001bit folder, your license remains valid.
                    Thanks and cheers!
                    Goh C H
                    • utilerU Offline
                      utiler
                      Way to go, Goh!!!
                      Just Curious...
                        Works like a charm! โ˜€
                        Except Undo to the beginning of the start session Seems block after Extrude profil along a path! ๐Ÿ˜ฎ
                        Soften Edges seems the blockage! And it's repeatable at any times! ๐Ÿ˜‰
                        So Big bug! ๐Ÿ˜„ (V6) (Plug not install in the V7)
                          gohch
                          hi Pilou,
                          Thanks, missed that out.
                          Bug fixed -- download the patch from
                          http://www.1001bit.com/download/extrude1_patch(15-Mar-09).zip
                          and overwrite the extrude1.rbs file.
                          Thanks and cheers!
                          Goh C H
                            sepo
                            Fantastic toolset. ๐Ÿ‘
                              Works fine now! ๐Ÿ˜‰
                              • jeff hammondJ Offline
                                i like the new extrude tool much better than fak.rb (well, i think i do.. i haven't done a real world test with it yet:) )
                                http://homepage.mac.com/jeffhammond/.Public/scf/followmes.jpg
                                followmes.skp
                                  That's a very nice comparison. I was wondering what their difference would be. I can see there's uses for both the variants.
                                    Fak asks to have the face section on the curve path
                                    1001 permits to have the face section out of the curve path
                                    • utilerU Offline
                                      utiler
                                      fak....? I haven't seen this one....
                                      Who's is it Pilou?
                                      Just Curious...
                                        Follow me and Keep ๐Ÿ˜‰ So FAK ๐Ÿ˜„
                                        • utilerU Offline
                                          utiler
                                          ๐Ÿ‘ Pilou,
                                          Gee, you could be bogged down in extensions nowadays....
                                          Just Curious...
                                            One request related tot he toolbars, could you put them into a submenu in the View->Toolbars menu?
                                            • 12
                                            • 13
                                            • 7 / 13
