    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 283.8k Views 66 Watching
    • G
      gohch
      @thomthom said:
      That's the same problem I had with horizontal louvres. vertical works fine oddly enough. Open the Ruby Console and see if you get any messages.
      hi thomthom,
      you're right, there's a bug there. just emailed you the patched hlouvres.rbs file.
      I'll put this in the version 1.1.3 release, hopefully tomorrow or day after.
      cheers!
        ๐Ÿ‘ Excellent!
        • utilerU
          utiler
          Thanks Goh, I'll go try it out..... I assumed 1 row or 1 column would add a mullion or transom to the panel...
          Just Curious...
          • utilerU
            utiler
            I did try that Goh but still the problem is occurring. I will PM you the .skp file and a short .swf file of the process.....
            thanks!!!
            Just Curious...
            • G
              gohch
              hi Andrew,
              really odd, because i have no problem using the panel divider tool on the same face that you seems to have problem with,
              with the same settings.
              utiler-dividepanel.swf
              i'll try a few different configurations and see....
              thanks
              • G
                gohch
                hi everyone, version 1.1.3 is now ready for download.
                Upgrades include:
                1) Slope selected edges tool - converts selected edges to slope along a fixed gradient.
                http://www.1001bit.com/products/slopeedges.shtml
                user can enter:
                • height difference
                • angle (in degrees)
                • gradient (as in 1 to 200)
                • pick end level
                This tool comes with an interactive dialog box that can be used to calculate angles, gradient, or height.
                slope edges dialog box
                This tool can be used to create sloping path/driveway from flat plane.
                example of sloping foot path using slope edges tool
                2) Extrude along path tool - extrude profile along selected path.
                http://www.1001bit.com/products/extrude1.shtml
                This tool solves the twisting problem that occurs when you extrude a profile along a curved and sloping path with SU's standard followme tool.
                Useful for creating handrails for spiral staircases, carpark ramps, cicular ramps etc.
                sloping curved ramp using extrude along path tool
                3) Bug fixes on horizontal and vertical louvres tools.
                User can now enter 0 for louver thickness to create single plane louvres.
                4) Option to show different toolbars separately.
                from menu View >> Toolbars
                Installation
                Just download the file
                http://www.1001bit.com/download/1001bit(1.1.3).zip
                and replace/overwrite the current files in your 1001bit folder.
                The user license that you have for v1.1.x is still valid. If you choose to delete the old folders before installing the new ones,
                Please keep a copy of the 1001bit.key file, which contains your license information.
                As long as you put this file back into the 1001bit folder, your license remains valid.
                Thanks and cheers!
                Goh C H
                • utilerU
                  utiler
                  Way to go, Goh!!!
                  Just Curious...
                    Works like a charm! โ˜€
                    Except Undo to the beginning of the start session Seems block after Extrude profil along a path! ๐Ÿ˜ฎ
                    Soften Edges seems the blockage! And it's repeatable at any times! ๐Ÿ˜‰
                    So Big bug! ๐Ÿ˜„ (V6) (Plug not install in the V7)
                    • G
                      gohch
                      hi Pilou,
                      Thanks, missed that out.
                      Bug fixed -- download the patch from
                      http://www.1001bit.com/download/extrude1_patch(15-Mar-09).zip
                      and overwrite the extrude1.rbs file.
                      Thanks and cheers!
                      Goh C H
                        sepo
                        Fantastic toolset. ๐Ÿ‘
                          Works fine now! ๐Ÿ˜‰
                          • jeff hammondJ
                            i like the new extrude tool much better than fak.rb (well, i think i do.. i haven't done a real world test with it yet:) )
                            http://homepage.mac.com/jeffhammond/.Public/scf/followmes.jpg
                            followmes.skp
                              That's a very nice comparison. I was wondering what their difference would be. I can see there's uses for both the variants.
                                Fak asks to have the face section on the curve path
                                1001 permits to have the face section out of the curve path
                                • utilerU
                                  utiler
                                  fak....? I haven't seen this one....
                                  Who's is it Pilou?
                                  Just Curious...
                                    Follow me and Keep ๐Ÿ˜‰ So FAK ๐Ÿ˜„
                                    • utilerU
                                      utiler
                                      ๐Ÿ‘ Pilou,
                                      Gee, you could be bogged down in extensions nowadays....
                                      Just Curious...
                                        One request related tot he toolbars, could you put them into a submenu in the View->Toolbars menu?
                                        • G
                                          gohch
                                          hi Thomas,
                                          I'm still finding my way around how to better organize the toolbars. Don't really like what i have now because it just fills up the entire pull down menu. I'll work on making something that is more efficient in the next upgrade.
                                            What would be really great was if you had a webdialog which allowed you to add and remove the various buttons. You might wan to look into Organizer. Quite a few plugins support customizing via that.
                                            btw, the slope edge tool; great! And just in time. I just had a rush project today where I had a curved ramp and this tool was a lifesaver. ๐Ÿ‘
                                            • 12
                                            • 13
                                            • 4 / 13
