    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 651.9k Views 135 Watching
    • jeff hammondJ
      @paulside said:
      Come on, Own up, how many of us have tried to orbit a jpg ! 🤣
      i try to orbit everything on my computer after a long SU session.. web pages etc...
      it's like jumping on a trampoline for a while.. once you get back on solid ground, it takes a few minutes to readjust..
      • N
        NewOne
        @ecuadorian said:
        And I often find myself trying to "mirror" things with Ctrl+M, as in ArchiCAD, only to remember that I should have clicked on the mirror button of the SCF Powerbar instead.
        What mirror button are you talking about? ❓ 😄 I olny use for mirroring Mirror_31.rb plugin. Is there something else? (and this one sometime crashes sketchup, i could not figure when yet)
        • E
          Ecuadorian
          404 Not Found
          (www.sketchucation.com)
          -Miguel Lescano
          • ely862meE
            ely862me
            i did find myself zoom ing out or orbit on a recorded desktop video taken while working in sketchup
            a big d*oh when i discovered the scale tool(at the beginning i made a house and i tried to insert some components and my house was too small ..i abandoned the project 😆)
            another one when i discovered the smooth operation
            another when i discovered the components(working just at one half of a car)
            and the biggest when i discovered the render engines...
            They are lot more wich i don t remember now!
            Elisei (sketchupper)
            Come and See EliseiDesign
            • GaieusG
              @thomthom said:
              Ever tried to undo a wrong stroke with the pen..? 😳
              Or with a girlfriend? 😒
              • Chris FullmerC
                @daniel said:
                My second moment was embarrassing. I gave a short seminar to the local community design center on using sketchup, and I was explaining how SU will not cast shadows below the point of origin (default ground plane), and open a model to illustrate it, only to discover that SU had apparently fixed that (with version 7?).
                Version 6 also let you cast shadows below the ground plane. At least the copy I'm running does?
                • Chris FullmerC
                  Also. . .. we need a little smilie that says "D'UH! and D'OH!"
                  Well, its not a smily on the forum, but Jim did make a plugin:
                  Error 404 (Not Found)!!1
                  (sketchuptips.blogspot.com)
                  EDIT: Oops, Paul already beat me to this last page....
                  • E
                    Ecuadorian
                    Still happens to me a lot... I press Ctrl+Z in the middle of an operation and end up losing some work done.
                    EDIT: Now I understand what thomthom was talking about... a REAL pen. A big Duh! for me.
                    -Miguel Lescano
                    • X
                      xrok1
                      Not being able to orbit in JPGS only illustrates their limitions. If we were an advanced society at all we would be able to this. 💚
                      and why do image files need to be rectangular?? it would eliminate the need for transparency if images could be irregular shapes, maybe even having holes in them. ☀
                        museummaker
                        Trying to orbit jpegs is just too funny. I do it all time.
                        I liken it to a nautical term "sea legs" if your on a boat too long you get used to moving with the rock of the ship and when you come aground you feel funy and walk like you had too much to drink. Trying to compensate for something that is not there.
                        When you try and orbit do you turn your head to the side and hope for it to work?
                        • RayOchoaR
                          RayOchoa
                          🤣 I never need an UNDO button 😆 😲
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • GaieusG
                            At YOUR age I didn't need any either. 😒
                            • broomstickB
                              broomstick
                              I don't understand this.. Can't you just apply an image to a face, and the edit that face?
                                  Same here. Though, you do have the setting in the Shadows Window "On ground" which makes SU cast a shadow on the origin plane. But shadows still appear below. Could be a graphic card driver issue.
                                    Duhduh by missing to read the Documentation 😒
                                    • GaieusG
                                      Well, then I am now kind of confused. I definitely remember a certain issue when the modeller put the model (partly) under the ground plane and it was a long topic until we solved the problem that the shadows weren't cat properly.
                                      If I have a look now, it's easy:
                                      • turn off shadows on ground
                                      • make a big,horizontal face below
                                      • turn on shadows on faces
                                        Now why didn't this work back then? To tell the truth, I'm not experienced in this issue because I regularly build my structures above the ground level...
                                        I can't tell for sure either. I usually keep above ground as well. And I started using SU during version 6.4, so perhaps it was an issue earlier...
                                        • daleD
                                          dale
                                          My biggest Duh's always come when switching between Acad or Vectorworks to SketchUp (either direction) but mostly I am constantly looking for the tape measure in the cad programs.
                                          Another Duh is finding that by holding the spacebar down you can control the zoom in so you don't zip past the object your zooming to.
                                          However I do find myself in situations where I am trying to zoom into the back side of something I'm modeling trying to peer over it on the computer, as if I was looking over a fence.
                                            Duhduh line 💚
                                            As a line can't be directly a component 😒
                                            • 34
                                            • 35
                                            • 4 / 35
