    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 32.5k Views 36 Watching
    • marleusM Offline
      marleus
      Finally got it ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
      Thanks, its a great helper.....
      Markus Sillander
      Vantaa, Finland
      I'm on FormFonts now
      http://www.formfonts.com
        Jorgensen
        I often use the knife tool - but it crashes SU 7 very often. Is this a known issue ?
        Jorgensen
          remus
          Yes, i think the knife tool is known to be quite buggy.
          You might want to try out whaats zorro2 script instead, does the same thing but has a number of improvements.
            Grant Hall
            Hello,
            I found this forum after experiencing a problem with the Subdivide & Smooth ruby.
            The icons will not display in the toolbar. The toolbar is there but it only shows blank squares. If I hover over the blank squares, I get the proper description and the script preforms properly.
            Attached is a screenshot of my plugin folder. (Mac OS X 10.5.6 - Sketchup Pro 7.0.8656)
            Thank you,
            Grant
            (I should add that it works fine on my laptop - Mac OS X 10.4.11 - Sketchup Pro 6.4.120)
            • O Offline
              otb designworks
              This is a known, and solved issue.
              Check out this thread
              Cheers, Chuck
              OTB Designworks is on Youtube
                Grant Hall
                Thank you kannonbal! That fixed it.
                • O Offline
                  otb designworks
                  perfect!
                  Cheers, Chuck
                    cruelcomedy
                    I love this plug in!
                    http://richarddoble.com/robot_experiment_organic.jpg
                    the other thread where I posted some stuff: http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=16894&st=0&sk=t&sd=a
                    http://www.richarddoble.com/
                    • W Offline
                      Whaat
                      Hey cruel,
                      Your work is jawdropping! ๐Ÿ˜ฎ Thanks for sharing. Glad you like the plugin. Any ideas for future versions?
                        liam887
                        Nice work! I cant wait for SDS2 I wont have to do my organics in other apps!!! ๐Ÿ˜„ ๐Ÿ˜„
                        Edit:
                        Yikes didnt mean to bump such an old thread I got linked through a post and commented without looking at the dates!
                        VISIT MY ONLINE GALLERY
                        • 6 / 6
