    Clean energy sources
    43 Posts 13 Posters 2.1k Views 13 Watching
      Double Espresso
      @mike lucey said:
      Time will tell. Just a thought! In order to protect these inventions, patents will have to be granted. This means that FULL data will be available to the public. At this stage the facts will come the light ... excuse the pun.
      Mike
      And that is where it always falls apart...
        Mine πŸ˜‰
        http://forums.polyloop.net/imagehosting/1964632033398621.jpg
        • pbacotP Offline
          Very good DE, on both posts! Also I thought of the palendrome, "Dogma: I am God." speaking of opposites.
          Seriously now (there's no "serious" emoticon) I'd say Tomasz at least has done some homework. For myself I never thought cold-fusion was some kind of scam. I thought it was a bona fide line of scientific research that is found so far to not be feasible under relevant conditions.
            tomasz
            One has to remember that patents applications are usually written in the way to protect the idea of the design and to disclose important details to make it really work.
            @remus said:
            I probably am prejudiced, but i just find it very hard to believe that someone who has found a method for creating free energy has trouble getting his ideas out to the world.
            All it would take is a working sample and he'd be sorted.
            Just stand in a position of a scientist who invents something that produces energy apparently from 'nothing'. If you would mention it to your superior, wouldn't you immediately be treated as a geek. Would you put all your career just to fight all those unconvinced?
            This guy is fighting more than 30!! years to make his invention, confirmed by scientists, to the public.
            http://www.josephnewman.com/
            Almost everyone treats him as a insane man chasing his dreams, but he has made several WORKING prototypes. Scientists has confirmed that his engines display extraordinary properties.
            As SU Forum can hardly keep any discussion serious, there is something way lighter and presented in an easy to digest fashion πŸ˜’
            [flash=425,344:3fdtow7z]http://www.youtube.com/v/gTAqGKt64WM[/flash:3fdtow7z]
            Extremely simple device that amplifies the current, so you can lit a LED using 1.5V DEAD! battery. It is easy to replicate. It is a amplifier similar to Magnacoasters unit.
            Tomasz
            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
              remus
              Cant watch the video, as i'm at college, but with relation to the rest of your post:
              If i was him i would approach the whole issue from a more traditional point of view i.e. presenting the idea as an anomaly in the current theory. Thus he is openeing up the idea for investigation in a more traditional manner without being labelled a crackpot.
              Of course it shouldnt have to be like that, scientists should treat all ideas equally and investigate them all without prejudice. But then they have to discriminate to an extent, there simply isnt enough time to investigate everything. Thus they tend to throw away the ideas that seem particularly lacking.
              Essentailly what i am trying to say is Mr. Kanarev is not doing himself any favours by saying "What everyone else has found is wrong, what i have found is right." (paraphrased)
              • Mike LuceyM Offline
                Mike Lucey
                The Joule Thiefs were good πŸ‘ Is there such a thing as 'hidden' energy around the place that we are discovering? Could this be the answer?
                  tomasz
                  You are right, but if there would be something obvious in front of your eyes, that you have really put your all knowledge to research it and it would give you aways same results, you would come to a conclusion... it does really work! There would be no much space for a compromise. I am right or they are.
                  Joseph Newman teaches, based on his experience and working prototypes, that there is a magnetic field being created in a conductor when a current is going through it (nothing new). The longer the conductor (wire) the longer it takes for an electricity to go through the whole length (obvious thing). The electricity in just a 'catalyst' and it is not a source of magnetic field (something new). The magnetic field comes from particles in a (copper) wire that has aligned their own magnetic filed (something new). When one would open the circuit to stop the electricity doing a whole loop back to a source (battery) then no energy would be lost since the loop has not been yet closed. In such a case a magnetic field has been already created. The collapsing field, due to absence of the current, produces a reversed current (something well known). There would be no big influence on the battery capacity since the current didn't manage to close the loop.
                  I think that in Joule Thief there is this reversed current being trapped and probably small self-induction occurs in the toroid. I have seen a replication of the circuit using bigger toroid and it was able to light a CFL light bulb using two AA batteries (3V in total). It is a 'hardcore' πŸ˜„ material for real enthusiasts and I don't want to do all homework for you! πŸ˜„
                  Tomasz
                    PeterCharles
                    Tomasz
                    The patent must describe the invention in such details as can be understood by a man "skilled in the art". This will mean anyone can make it from the patent, except that they will be prevented from doing so in the countries that have granted the patent.
                      tim
                      Not quite; they would be prevented from making them for profit without permission of the patent holder. Patents do not stop anyone making something patented. They require the maker to have permission from the owner, usually of course granted in exchange for money. Nothing stops someone from getting a patent and allowing cost-free licenses. Or even - so far as I know at the moment - refusing all licenses and thus preventing the thing being made by anyone. Now, if only I could have had a patent on the core of Word, so I could stop it from driving a billion people insane...
                        The universe is teeming with energy: it's just the 'catching it' in a way that you can use it that's difficult.
                        Talk of 'efficiency' and >100% is something of a red-herring. Think of the well tried and proven 'heat-pump'... for every kW of electricity you use to run it you get 3+ kW of heat out of it. That's 300% 'efficiency' if you use that terminology. It's normally called COP = Coefficient Of Performance. Clearly the device has 'produced' considerably more energy than you've put into it. It hasn't made it by magic, it's just moved it from somewhere else and concentrated it - after running it you'll now some ground-water (or other 'source') that's a tiny bit cooler AND a few litres of water in you building that's now a lot hotter. Same energy - but moved and concentrated where you want it.
                        I don't think anyone disagrees that a heat-pump works - after all fridges and air-con use them all the time !
                        Although I can't envisage the exact details, it might be possible to contrive a device that does something similar with forms of energy other that basic 'heat'.
                        Imagine a device that uses electricity from a battery and seems to produce more electricity than the battery uses - 'impossible' the sceptics say, however they are looking at a closed and limited system... What if the device could somehow take a tiny bit of the energy in the earth's magnetic-field (or some other field - solar-wind or whatever you can imagine), that's so little out of so much that it had an imperceptible effect on the whole thing; and that device then somehow moved the potential energy and concentrated it into useful power... After all there are zillions of Watts of energy landing all over the earth from the sun AND the earth's magnetic-field and radioactive core-heat output: we just need to catch it and concentrate it where we want it to be...
                          PeterCharles
                          My understanding from the UK is that profit does not come into it
                          True
                          True, but then why spend all that money on a patent! Just publish it in the public domain
                          Except by the patentee himself
                          Of course you can only enforce a patent if you've got deep pockets. Be prepared for others to, claim prior art, launch an application for revocation, produce it in countries you couldn't afford to patent in, just ignore you and let you sue if they've got money and you haven't, etc, etc
                            tomasz
                            There are some projects being developed on Open Source basis.
                            Plasma ignition or Water Spark Plug:
                            [flash=400,326:ij08cp6f]http://video.google.com/googleplayer.swf?docid=-3048626873937193969[/flash:ij08cp6f]
                              Simon B
                              Some members may not have heard about Roger Shawyer's emdrive:
                              http://www.emdrive.com/
                              This caused quite a kerfuffle in scientific circles when reviewed in New Scientist as it offers a form of reactionless-propulsion but appears break the conservation of momentum rule.
                              According to a link from wikipedia, a team of Chinese reserachers have confirmed the theory and are building a demonstration model.
                              http://en.wikipedia.org/wiki/EmDrive
                                tomasz
                                I have found something new. There is a successful attempt on replicating an effect used in a patented Howard Johnson magnetic motor. The patent No. 4,151,431 was granted in 1979(!).
                                The author, nickname 'Mylow' has posted several videos of his crude prototype. I have attached the most convincing of them.
                                [flash=425,344:219vqq4n]http://www.youtube.com/v/2sCeQ8bwmcE[/flash:219vqq4n]
                                EDIT: It has been debunked. In this video he was using a thin fishing line to rotate the motor. 😞
                                • 3 / 3
