    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 182.0k Views 79 Watching
      gata
      Wikii,
      I got mixed results by reversing the face. Sometimes the reversal worked, sometimes not.
      People who want FAK to model nice looking roads in a landscape would have some intersecting paths.
      I mistakenly selected two faces for the plugin to extrude at the same time. FAK made 2 groups. One good, and one looks strange.
      FAK .03 test 2.skp
      • W Offline
        wikii
        v0.04 updated.
          you pass from rbs to rb 😉
          So I can put your crazy plug in the Tools menu! Thx! ☀
          Seems there is yet a lilbug 😉
          if I incline & rotate the curve to the ground that works 😉
          lilbugs.skp
          • E Offline
            Ecuadorian
            It's because the profile itself is kept vertical!
            -Miguel Lescano
              yes auto intersect 😄
              • W Offline
                wikii
                there can‘t has vertical segment in the path.
                for the reason? you think it.
                  gata
                  Wikii,
                  All attempts to extrude a profile - from several locations and profile face orientations - on the figure 8 path worked very well.
                  The way reversing the profile face only changes the orientation of the extruded faces is very nice. People making tunnels, or are otherwise are more interested in the inside of the extrusion will like this feature. It's a keeper.
                  FAK did not like quite like extruding unless the face was at the end of the selected path. The shape was fine, but the group moved to a new location.
                  And when I ran the script on the entire path, at least one face did not close near the path intersection area.
                    davecoopstl
                    Take a look at this model of a basic roller coaster track.
                    I drew three circles as the profile: one for the main beam, and two for the coaster rails.
                    Look at the top of the hill, how the rails cross paths and switch to the opposite sides of the main beam.
                    Is this expected behavior? Am I doing something wrong? Is there a way to keep this from happening?
                    Hope someone can help.
                    Dave/
                    Here's a simple roller coaster track, but the profile is 'reversing' at the top of the hill!
                    • H Offline
                      hebrides
                      Unloaded your rar into SU7 plugins....nothing!. Not surprising, I find that 2 out of 3 free rubies just don't work on first try.
                      I wish the ruby community would buy themselves installer software and use it when there are other files or folder dependancies.
                        Click Draw
                        Which rubies are these???
                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                          sorgesu
                          I was just getting ready to start up dating the manual for my advance classes, in which there is the spiral stair exercise. I thought I would check here to see the progress on this ruby and was so pleasantly surprised to see that it has arrived. Thank you so much for this. Really really appreciated.
                          Susan Sorger
                          Former Seller Hand Rendered Entourage
                          Former Canadian Authorized Training Centre, SketchUp
                          • E Offline
                            Ecuadorian
                            Thank you, Wikii!
                            -Miguel Lescano
                            • X Offline
                              xrok1
                              which part did you use followmeandkeep for?
                                gata
                                Dave, you need to add a contruction point at the end of the path. Select all faces, path and point and run script. There are at least 2 scripts which which let you add a construction point - AddVertex+.rb and add_construction_point.rb.
                                And to model a loop-de-loop, you need to do the loop part separate. Make a helix from one of the helix scripts. Rotate a copy of your rail faces 90° and position it at the end of the helix path. Don't forget to add a construction point. Then rotate the new extrusion to the correct orientation.
                                hebrides, rar is a zip file used in many parts of the world. The stuff you want is inside. Get 7-zip.
                                Wikii, a progress bar would be a nice addition. For now I can tell the script is running by how my cursor looks and a slight flicker in a menu bar.
                                • E Offline
                                  Ecuadorian
                                  I used it to make the wall, with the profile you see in red.
                                  I then "pathcopied" a component and used booltools to make the battlements.
                                  -Miguel Lescano
                                  • X Offline
                                    xrok1
                                    ahhh... yes, it was the cutouts i was wondering about.
                                    thanks
                                      Seems miss the "little holes" 😉
                                      • E Offline
                                        Ecuadorian
                                        Yup... I was lazy 😉 I'll try it with "little holes" tomorrow.
                                        -Miguel Lescano
                                          Slimdog
                                          Hello all. I am new to the forum and have been reading back through the old posts and learning a lot. I have only been on sketchup for a few months but have a couple of years on AutoCad.
                                          I have been trying to get the follow me and keep plugin to work but cant figure it out. I have installed a few plugins before with no problem. I just down load the rb. file and chuck it in the plugin folder. The thing I dont get is that in the very first post by Wikii there is a skp. file and a rar. file. I have down loaded them both. With the FAK.skp file I follow the words saying to highlight all and then run the plugin except there is no follow me in my plugins menu.
                                          Not sure what to do next. Is there an rb. file some where in the skp. file?
                                          -S
                                          ps I am on a mac
                                            Slimdog
                                            Thanks for posting rb. file Pilou. I tried it and works great. Thanks also to Wikii.
                                            -S
                                            • 11
                                            • 12
                                            • 6 / 12
