    Birds eye views and massing
    16 Posts 7 Posters 4.4k Views 7 Watching
    • soloS Offline
      White Oak.
      http://img17.imageshack.us/img17/390/whiteoakyt6.gif
        Me personally could use these kind of trees big time. I don't really use top view ones (like landscape architects) that you mentioned in another post but some like the4se would definitely be great.
        As for the species... Quirte "simple", (Middle-)European ones like oak (including big, fat, old oaks for some Robin Hood series πŸ˜‰ ), birch, horse (ches)nut, maybe plane, ash, elm, some kind of semi-Mediterranean things similar to junipers, and pines... Nothing really special, I guess.
        • EdsonE Offline
          Edson
          pete,
          in all projects i do there is always at least one bird's eye view. if it consists of more than one building then a larger number of bird's eye views are needed. so your plan for a group of trees that could be used effectively for that is very, very handy.
          could you include some tall and thin tree like a cypress, especially the italian variation?
          cheers.
          p.s.: the first pack is great.
          http://www.mahfuz.arq.br
          • Paul RussamP Offline
            Paul Russam
            Hi Solo, Nice trees!
            This is link to a Picasa album: http://tinyurl.com/aplypq
            The images in here are typically how I use trees.
            From our point of view getting a tree specifically right is not that important, just as long as it looks like a tree and looks like it would grow naturally in western europe.
            Hope this helps.
            Paul Russam
            English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
            • soloS Offline
              Paul that's exactly what I intend with these trees. I threw together a few trees from my next collection and massed them with an old scene that I used Vue to add trees as SU would crash otherwise. I am now able to add the trees as needed and easily navigate the scene with shadows on.
              This is straight SU output with soft focus/bloom added in post edit.
              http://img17.imageshack.us/img17/5020/complexrv9.jpg
                Paul Russam
                I'd buy that for a dollar! (or more)
                How do they look low level?
                In my images I've got the tree materials semi-transparent so that I can still see the buildings behind, how would your trees look semi-trans?
                Paul Russam
                • soloS Offline
                  Paul, I did a quick test, opacity at 75% on second image.
                  http://img7.imageshack.us/img7/9836/treetest1jb9.jpg
                  http://img17.imageshack.us/img17/971/treetest2nz8.jpg
                    Paul Russam
                    You have a sale Mr Solo!
                    I assume that they are scaleable like all SU objects, I've found that by scaling some trees in only one direction (Up or Out) I can produce other tree types that look relativly convincing.
                    Paul Russam
                      Paul Russam
                      As a quick note:
                      This is how I set about placing trees on a large site, bearing in mind that I'm not actually trying to create a planting plan, I'm just trying to enhance the model.
                      Take my 5,6,7 unique tree components and scale them to the size I want.
                      In plan view:
                      Make 2 or 3 copies and scale each set up or down a metre or so to get some variety in height.
                      Make 6 or 7 copies of the lot
                      Select half of them, rotate them through a random angle and place the copies over the top of the other half'
                      Keep doing the copy/select half/rotate until I have a load of them all jumbled up.
                      Randomly select trees from the pile and place them over the model in groups of 3 or more, along roads etc etc.
                      Use Drop.rb to drop them on to the surface.
                      Select them all and move them down a further 100mm to cover any occurrence of the flat bottomed trunk appearing over sloping ground.
                      Paul Russam
                      • Chris FullmerC Offline
                        I agree Solo, these are very useful for what I need too. And the general species listed are exactly what I'm looking for too. I don't use too much tropical foliage, but european and mediterranean are big time on my list. And like Paul, I generally don't need anything that looks exactly like a species, but just an approximation is good enough for me.
                        And Paul, sounds like you should check out randor.rb. It does all minor rotates and scaling for you. I generally like it pretty good.
                          Or Didier's Component Spray tool as it has a "click one to place one" option as well and you can pre-define random rotation, scale and (AFAIK) even tilt (is it tilt? like leaning sideways a bit).
