    [Plugin] Color by Z (Updated August 27th, 2009)
    54 Posts 21 Posters 56.2k Views 21 Watching
    • X
      xrok1
      @daniel s said:
      SU7 has an option called Combine Textures (The Combine Textures menu item combines separate textures on adjacent co-planar faces into a single larger texture. This feature also, optionally, removes edges between co-planar faces to reduce the polygon count for the model as a whole. Context-click on multiple selected parallel faces, with at least one face having a texture, and select Combine Textures to create a texture which is unique to that set of faces.)
      This is a great tool, but it will be more usefull if it`s extended into curved surfaces. This Color by Z or the Tools On Surface are examples of plugins that will be benefit.
      Daniel S
      how can you get to this tool? i can't find it, tried RC menu?
      • Chris FullmerC
        Here's a video on using combine textures.
        [flash=727,635:2s0w7uxd]http://www.chrisfullmer.com/chrisfullmer/forums/combine_textures.swf[/flash:2s0w7uxd]
        • X
          xrok1
          thats sweet. thank you very much for that. coincidentally you just answer a another question, i was trying to figure out how to make a painted wall texture for skindigo, but i couldn't figure out how get SK to UV map surfaces with just white material on it so i could apply displacement. now after watching your vid i figure i can just make unique my material then it should be uv'ed.
          thank you
          • L
            linea
            Good idea Chris, thanks
            • urgenU
              urgen
              ...nice idea Chris! 👍 😄
              --pupil forever...------
              • soloS
                Cool and thanks, this should come in handy.
                http://img13.imageshack.us/img13/6384/colorfulkk4.jpg
                • JClementsJ
                  JClements
                  It never occurred to me to project a gradient color onto a terrain, great idea.
                  However, I do project gradient transparency along with gradient color onto a single surface to make arrow-shaped objects and "swooshes" that indicate direction or motion.
                  Mt Hood gone Active Vulcanic AGAIN 2.skp
                  Gradient Arrow.skp
                  • Chris FullmerC
                    Solo, was that made with the plugin or with the image gradient method?
                    • GaieusG
                      Hi Chris and all,
                      I haven't been able to drop by the Ruby Dept for days so I might be a bit late... Do you know however Didier's "paint_altitude_faces.rb" by any chance? It works kind of similar (only with the gradients of the same colour):
                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_ren_page.htm
                      There's also a demonstration video supplied.
                      All in all, yours is a very cool plugin with this texture gradient! 👍
                      • Chris FullmerC
                        Yeah, I have a tendency to not look around to see if similar scripts exist before starting one (I think there were already about 4 version of a random pushpull script before I wrote mine, for example). Mostly because I'm still just writing these for the experience and they each teach me a new little portion of the Ruby SketchUp API. But I definitely need to watch out for that before I embark on any seriously large and in-depth projects I suppose!
                        So I tried to check his out, and its only painting black faces on my model regardless of what color I select. I suppose it might be a units thing? but I changed my model units to metric with no luck. Also the avi file wouldn't play for me so I couldn't see it in action. I even tried playing it with mPlayer, which generally plays anything you throw at it. But that didn't work. It came out all garbled.
                          Ditto.
                          • GaieusG
                            Okay guys, don't ask me. I just remembered seeing the ruby in the list about two ears ago (never tried). Maybe it has problems with SU 6+? The video plays to me and Didier uses a blue colour for the demo.
                            • C
                              chan
                              This is just great Chris. Thank you so much.
                              I deal with many diffrent urban projects and
                              I clearly see that Skechup with smart programmers like yourself
                              has great potential in evolving into sth not only for visual outcomes but
                              for urban analysis.
                              Color by Z is already a great start isn't it?
                              Could this kind of approach broadens to....
                              **- analyze daytime shadow coverage ratio
                              • density analysis(maybe by comparing # of lines certain area contains)
                              • open view condition by z**
                                and so on and so on...
                              If anyone is interested, I would love to discuss about it(just can't program it ;( ).
                              • Chris FullmerC
                                "analyze daytime shadow coverage ratio"
                                That is one that has been on my mind lately. I just can't figure out how to figure out the percentage calculations because there is no easy way to get that data out of SU I think. So I would essentially have to find get the location data from the model, and evaluate each face myself using the sun angles every 15 minutes or something and run that on each face etc. I'm really not sure how that would go or if its even feasible. It would be cool if it was.
                                  rinaldo
                                  Erro ao carregar o arquivo clf_color_by_z.rb
                                  No such file to load -- progressbar.rb
                                    Download progressbar.rb free from SMustard...
                                      snorky
                                      doesn't work for me.
                                      Error; #<ArgumentError; comparison of Float with nil failed>
                                      (eval);44;in `>'
                                      (eval);44;in `update'
                                      • Chris FullmerC
                                        You need to have progressbar from http://www.smustard.com installed also. Go install the plugin and then see if the plugin works after that,
                                        PS - thanks for posting the error!
                                          snorky
                                          I have it...
                                          sorry for uncompleted quoting, this is right error:
                                          (eval);44;in `>'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb;140;in `colorbyz'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb;138;in `each'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb;138;in `colorbyz'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb;174
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb;174;in `call'
                                          and sorry for my poor enghish
                                          • Chris FullmerC
                                            Try removing component spray from you plugins, then try my script. See if that is the problem.
                                            • 2 / 3
