    SUpro 7 on OSX 10.5.6 locks up entire UI for all apps
    47 Posts 10 Posters 13.0k Views 10 Watching
    • T
      tim
      Nick, I've been running the Console application to keep an eye on the errors being reported as the system runs. It's quite.... alarming. So many apps reporting failed this, can't do that and the kernel won't do the other.
      The Console has a list on the left that shows all the logs it maintains. The two that seem important here are the 'All Messages' log which has been listing a lot of alloc related messages, and the 'WindowServer.log' (expand the 'LOG FILES' entry by clicking on the triangle) which was showing the backing store type messages.
      On the plus side I just received a message from the google-guys suggesting a full de-install and re-install since they suspect some component was not installed correctly. They suggest :-
      1. Uninstall Google SketchUp Pro 7 by visiting the following Google
        SketchUp Help Center article:
      http://sketchup.google.com/support/bin/answer.py?answer=36209
      1. After uninstalling, we suggest repairing disk permissions:
      a. Restart your computer.
      b. Open a Finder window.
      c. Click "Applications."
      d. Click "Utilities."
      e. Double-click "Disk Utility."
      f. Select your hard drive.
      g. Select the "First Aid" tab.
      h. Click "Repair Disk Permissions."
      i. After the permissions are repaired, exit Disk Utility.
      j. Please repeat steps "a" through "i" once more.
      1. Log in to your computer with a user account that has administrative
        privileges.
      2. Please visit
        http://sketchup.google.com/support/bin/answer.py?answer=115548 and
        download the Google SketchUp Pro 7 install file.
      3. When the download completes, double-click on the install file and
        follow the on-screen instructions.
      4. Please launch Google SketchUp at least once while still logged into the
        administrative user account.
      It certainly seems to have massively reduced the alloc related messages so I'll see how it goes.
      • N
        Nicoloco
        Tim,
        Thanks. Have made a clean installation of Sketchup 7 Pro as per the Google instructions. Had a look in the console and there are still lots (about 4000 in three seconds...) of the following messages.
        09/02/2009 12;11;48 [0x0-0x110110].com.google.sketchuppro7[761] *** set a breakpoint in malloc_error_break to debug
        and
        09/02/2009 12;11;48 [0x0-0x110110].com.google.sketchuppro7[761] SketchUp(761,0xa077d720) malloc; *** error for object 0xa06eb6d8; Non-aligned pointer being freed
        Have turned off 'Fast Feedback' and left 'Hardware Acceleration' on and this has eliminated the crashing (none yet today) without too much of a performance hit. It doesn't seem to have any effect on the error messages.
        Nick
        • T
          tim
          Oh well, nice idea google-guys. I just had a repeat of the exact same crash as before. Let's see what the next suggestion is like!
          • B
            bjanzen
            Tim -
            Those console msgs have been there for a couple of versions, and yes, it'd be nice if someone cleaned them up. Do you get the Apple crash log showing up? If you do, don't send to Apple - send it to us by copying the text in it and sending it to us in an e-mail so we can troubleshoot. I'll poke through this and other things and see if we know anything more. Thanks.
            Barry
            • T
              tim
              Hi Barry -
              no, there is no crash report as such, just the log messages in the windowserver.log and then total UI death. It may be of interest that iTunes keeps on playing, and don't forget that I can log in from one of my other macs and poke around. That might allow some sort of remote debugging experiments? Let me know. My time is my own for a week or so, so I can spend some if it working on this with you if you have tests for me to try.
              It might sound callous but I'm glad someone else with different equipment is having similar crashes. At least that offers some more chance of reproducibility. I used to hate intermittent errors when I was managing s/w development...
              • T
                TriciaS
                A few more questions on this one.
                Nicoloco - are you still not crashing with Fast Feedback off? If so, that is a really important clue. If you turn on Fast Feedback, can you recreate the issue with all models or just certain ones? It sounds like you were thinking it might be model related...
                Tim - does turning off Fast Feedback in Preferences > OpenGL seem to fix your lock up as well?
                Fast Feedback speeds up the drawing actions in your model (vs things like the speed at which you can orbit around) and only kicks in when performance degrades below a certain threshold. So Fast Feedback will only kick in when working on larger models. If you both are only seeing this issue with more complex models when Fast Feedback is enabled, that might be a further clue.
                Also, we are wondering if you see a pattern in how many document windows you have open at the time of the crash. Or whether it seems to happen only with certain actions - e.g. only when adding geometry, or when selecting things etc...
                Sorry for all the questions. We really appreciate your willingness to help us try to get to the bottom of this one.
                Tricia
                • T
                  tim
                  I'll try it and see.
                  I very rarely have more than 2 document windows open - so rarely I can't remember doing it. I do tend to have most of the tool windows open (layers, outliner, styles, components etc) most of the time. I can't discern any pattern of actions involved.
                  My model is not particularly complex
                  30,000 edges
                  13,000 faces
                  622 component instances
                  2 groups
                  3 images
                  235 component definitions
                  10 layers
                  47 materials
                  1 style
                  everything else 0
                  Don't worry about asking questions; I'll only get worried when you d
                  30,000 edges
                  13,000 faces
                  2 groups
                  3 images
                  10 layers
                  47 materials
                  1 style
                  everything else 0
                  Don't worry about asking questions; I'll only get worried when you don't....
                  • T
                    tim
                    Sigh. No improvement at all. Exactly the same errors logged, exactly the same lock-up.
                    • B
                      bjanzen
                      Nicoloco & Tim -
                      1. In Finder, type Command-Shift-g and type ~/Library/Logs/CrashReporter/ This directory contains all the crashes on your machine. You can send us a typical SketchUp crash.
                      Tim, yours messages point to WindowServer unable to create swap space. Is your hard drive nearly full, or are you running a lot of screens in Spaces? You posted that WindowServer threw errors - is WindowServer still running? If you remote'd in, do a "ps aux | grep Window" command is WindowServer there? You can also run "top", type "o" (to sort on) then "cpu" to sort on cpu usage. WindowServer will always be near the top. If it didn't crash, what's the memory usage (my machine, just typical usage, is 130 MB real memory, 500 MB virtual memory). If this is crashing or messed up, we can contact Apple and work with them to find out what's going on.
                      1. Please do or continue to send data (crash logs, system profiles, etc..) to
                      http://sketchup.google.com/support/bin/request.py
                      I'm still of the belief that your situations are unique - we have lots of users in 10.5.6 with zero problems, so we'll try to determine what's going on for you.
                      b
                      • T
                        tim
                        There is just a single crash report - and that relates to a SU 6 crash that happened while I was trying to see if 6 had the same problem. It seems that SU itself is not actually crashing in any form that leaves a report.
                        I have 150Gb free space on my 300Gb disk. I don't run Spaces at all (nor dashboard for that matter). I do have a secondary 20" display on the 24" iMac. Typically I have the tool windows on that surface.
                        Next time the system locks up I'll take a look with ps and report
                        Thanks for looking into this!
                        • B
                          bjanzen
                          OK, scouring the net, iMac's have had reports of overheating on gaming & OpenGL apps. I've replaced a personal one myself. At this point, I'd try 3 things:
                          1. Getting a menu bar temperature meter, maybe something like http://islayer.com/apps/istatmenus/
                          2. Unplug the second monitor for a day and see if you crash.
                          3. Stop playing World of Warcraft every coffee break ๐Ÿ˜„. OK, maybe just 1 and 2; this one's important.
                          Barry
                          • GaieusG
                            ๐Ÿ˜ฎ I didn't know WoW was release for the Mac!
                            I'll change platforms immediately!
                            (Barry, can you arrange a shift from the Windows license to the Mac for me?)
                            • T
                              tim
                              Been using one ever since my first iMac had this problem and got replaced within a couple of days of buying it. No apparent temp issues with this unit.
                              1. Unplug the second monitor for a day and see if you crash.
                              Owwww, Mum.... no, don't make me do that. It's not fair. Yuck. OK, I'll try it. The things I do to help people out, I dunno....
                              1. Stop playing World of Warcraft every coffee break ๐Ÿ˜„. OK, maybe just 1 and 2; this one's important.
                              Never played it. Why would I downgrade to simulated violence when I can just - well, never mind, you don't need to know about my day job?
                              Today's little test result - I turned off hardware acceleration (Oh my goodness.... it....... is...... so....... sloooooooowwww) and the crash is exactly the same. The same address is being reported as not freeable (0xa063a6d8) and the windowlog has the same complaint about destination buffer to small for y index (3852). And I clean forgot to log in from the other machine to look at the process list. Rats.
                              • T
                                tim
                                OK, same error with the external display disconnected. Exactly the same errors etc.
                                This time I remembered to log in from the macbook and this is what it said:-
                                Diziet;~ tim$ ps aux | grep Wind
                                _windowserver    94   0.0 44.8  2605312 1878828   ??  Us    4;56PM   7;33.79 /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer -daemon
                                and
                                Diziet;~ tim$ ps aux | grep Sk
                                tim        739   0.0  0.0    86524   1204   ??  Ss    5;45PM   0;01.28 /Applications/Google SketchUp 7/SketchUp.app/Contents/Resources/SketchUpDaemon 14639
                                tim        738   0.0  8.4  2485168 351256   ??  S     5;45PM   5;36.58 /Applications/Google SketchUp 7/SketchUp.app/Contents/MacOS/SketchUp -psn_0_241723
                                A note I don't think I've mentioned previously - the mouse cursor is still responsive to the mouse, so some part of the graphics system is still running ok and it can't really be something like the GPU overheating.
                                • C
                                  Christopher Love
                                  Tim,
                                  Just getting this up to the top of the list again. I too have started experiencing UI freezes, its not isolated. Only occurs whilst using SU. Very annoying. Sounds like I have a similar setup. Running an external monitor off the latest MacBook Pro. Just wondering wether or not some of the ruby scripts that I use could be causing the problem. Smustards dashed lines runs like a dog on V7, dont know that I could live without it.
                                  Console log error message attached
                                  (1000)
                                  13/02/09 5:15:30 PM SketchUp[442] _NSShapePlainWindow: error setting window shape (1000)
                                  13/02/09 5:15:30 PM SketchUp[442] _NXPlaceWindow: error setting window shape (1000)
                                  Seriously considering going back to V6
                                  Any suggestions greatfully recieved
                                  Regards
                                  • T
                                    tim
                                    @christopher love said:
                                    Tim,
                                    Hmm, it's probably not any (non-standard) rubys at fault since I'm currently running a totally vanilla SUP7 install to avoid any possible conflicts.
                                    Can it really be true that my WindowServer is trying to use 44% of all memory? (see the ps aux output in my previous message? That must imply a truly staggering memory leak or abuse somewhere.
                                    • T
                                      tim
                                      OK, I thought I'd try running with the Activity Monitor open to see what happened to WindowServer memory usage.
                                      Wow, what a surprise. It starts at 75Mb (75 fricken megabytes! What the blazes is using 75 damn megabytes? I used to run an OS, Smalltalk, a DTP, a programming editor etc in 4 megabytes! The World Has Gone Mad!)
                                      Start SU - jump to 93Mb (eek!) and within 10 minutes of moderate use where I added a single component - basically a pointy stick - to the house model, the RSIZE number had climbed to a staggering 450Mb. Now that my friends is a memory leak. Someone call in the Army Corp. of Engineers with bulldozers to plug that levee.
                                      Added point - I have 4Gb in my iMac. This might possibly be relevant because of the distinct possibility that some code somewhere is treating a pointer as an integer and falling foul of the top bit of the address and going all wobbly. Not that I have ever made such a mistake. No sir, no way. Never.
                                      • T
                                        tim
                                        OK, more news of strange memory growth bugs -
                                        Amongst many tests I decided to try importing the house model into a new file; this because on a whim I tried a new, empty, file just because. To my immense surprise, the new file with the old model imported did not result in rapid memory usage growth. To make life more fun, I got three kernel protection failure crashes. Oh joy.
                                        I ran the hardware diagnostics and got the all clear from them. I retried the 'new' file and it seemed ok. I even tired the original file and.... no memory explosion. I had not added any new software, updated any software or done anything that I could even faintly imagine having any effect on this issue.
                                        I am now officially baffled.
                                        • B
                                          bjanzen
                                          I would call AppleCare (1-800-APL-CARE), or proceed to Apple's Genius Bar with machine in tow at:
                                          701 West Georgia Street
                                          Vancouver, British Columbia V7Y 1G5
                                          (778) 373-1800
                                          I still feel that you have a funky machine. As I've mentioned before, I have one of these at home, and on ANY application, this thing would lock up and crash at random times. I took it back to my local Apple store twice when I thought I could reproduce it at the Genius Bar and failed, and on the third time they knew I was going to return it for good and buy a new one, so they just straight-up exchanged it. Zero problems since.
                                          Kernel panics often indicate bad hw. If this were a specific SketchUp problem on this machine with this graphic card, we'd have some real numbers to reflect that.
                                          • T
                                            tim
                                            (778) 373-1800
                                            It's not impossible, of course. I'm not very likely to be able to visit the apple store in vancouver any time soon though; Vancouver Island (in particular the mid-isle area where I live) is a long way from Vancouver. Timewise it's a bit like suggesting to a Londoner that they take their machine to Paris! I can actually see the sun glinting off the skyscrapers in Van on occasion but getting there involves a 2hr drive, a 2hr ferry, another hour plus drive and then, shudder, navigating around Van. And then back...
                                            As I mentioned above the problem has gone away, at least for now. I still see very frequent complaints about a failure of deallocaton, always the same address, but the memory usage in WindowServer does not rapidly balloon any more. Really, really, weird.
                                            • 2 / 3
