    Profile Builder plugin- Problem- Help?
    26 Posts 7 Posters 3.6k Views 7 Watching
    • W
      Whaat
      @plot-paris said:
      Cecil, I would suggest you uninstall the update of Internet Explorer 8 Beta.
      I just tried it, and it worked - ProfileBuilder's preview shows the profiles again!
      of course that is only a temporary solution (for we don't want to keep an old version of IE simply because of this compatibility issue). but for the time being. thus you can at least use this marvelous plugin and don't have to refund it.
      Yes, I suggest you do the same, Stuart. For Internet browsing, most people recommend using Firefox anyway (which I have heard is more secure). I tried downloading IE8 and had the same issue as you. I could not get it to work by modifying security settings so it seems like it is a compatibilty issue with IE8 or the javascript library that I use to draw the profile preview. I have tried to contact the creator of the javascript library and am waiting for a reply.
      Let's hope this gets resolved while IE8 is still in beta.
        What library is it Dale?
        I was thinking; for future versions, using SVG files for the profiles? (XML based) Then people can open the profiles in other applications and you can use the .svg itself as a preview in the webdialog. Also, using .svg might make it easier to display thumbnails of profiles in Explorer/Finder?
          Cursed! I thought IE7 had added .svg support. But no... 😞 it needs a plugin for that.
          How annoying. I had plans for making plugins using .svg graphics...
            Stuart Parkinson
            Well ive just uninstalled IE8, and yes the profile has appeared! thank god! and thank you all for your help!
            I would of liked to have tried to add the tagg to my webdialog before I uninstalled, but I dont know how to 😳 If you could give me step by step instructions I will reinstall IE8 and give it a go because some webpages require IE8 to view (why I upgraded in the first place)
            thanks again!
              I'm running Windows 7 at the moment, which means IE8, and I will have a look at this to see if I can make some sense out of it.
              • W
                Whaat
                You have GOT to be kidding. A website requires a beta version of a web browser to be viewed?? πŸ˜• Only a Microsoft website would be that stupid. πŸ˜’
                • GaieusG
                  That's a clear proof of some corporations merely ignoring web standard. I wonder how big the traffic of such a website will be. I even somply exit any website (without bothering to launch in any version of IE) which doesn't run on other browsers. Such a website simply cannot be professional (supposdly even as far as content goes) enough to be worth visiting. πŸ˜•
                    dtrarch
                    Dale & All
                    I get a profile but no origin (red dot) ref.
                    Back to IE 6 and thank you Microsoft for the "New and Improved"
                    Dave
                    • W
                      Whaat
                      I just downloaded the latest Windows Update (for Vista) which also includes Internet Explorer 8 RC1. The issue seems to be now resolved! Profile previews work perfect for me. Can anyone else confirm?
                      • plot-parisP
                        plot-paris
                        ProfileBuilder under Windows 7 Beta with Internet Explorer 8 Beta works fine... πŸ‘
                          In regards to the preview in PB, what about using Flash to draw it? That's supported on all platforms.
                          And if you make the whole dialog in flash, then you don't have to worry about how different browers render it.
                          • 2 / 2
