    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    243 Posts 65 Posters 233.9k Views 65 Watching
      gohch
      hi Fakircho,
      Thanks for the feedback, Yes, I should have the inference added in the next upgrade soon.
      As for the Mac, ordered a Macbook but the earliest they can deliver is 2 weeks later; seems like Apple is pushing out a new model. I'm eagerly waiting for my Macbook to start working on the mac version. 🎉
        gohch
        hi guys,
        i've added some inference to the Vertical Wall tool;
        pressing the down button will cycle through the following inference modes
        1 - lock current direction, next if the cursor is on an edge, projects to intersection point, else project to point nearest to the cursor position on the current direction.
        2 - lock current direction, project to point on the x axis of cursor
        3 - lock current direction, project to point on the y axis of cursor
        4 - release
        upwards button release the lock
        right button - locks in x axis
        left button - locks in y axis
        Note that you can enter exact distance anytime.
        Anyone want to try out please replace the attached vx_wall.rbs file with the one you have. (not sure whether i can attach rbs file here, zipped it just in case)
        cheers!
        updated vx_wall.rbs
          dizain
          Error:
          No such file to load -- C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit/1001bit_loader.rb
          • F Offline
            fakircho
            Thanks for the inference addition to the wall tool.
            I hate to be difficult but can it work the same way as the rest of the Sketchup tools. That is
            when you pint with your mouse it should pick up the red or green axis and then you lock it with the shift key? That would be perfect
              gohch
              @dizain said:
              Error:
              hi dizain,
              can you double check whether you have moved the 1001bit_loader.rb file to the Plugins folder?
              1001bit_loader.rb file should be in 1001bit folder while
              1001bit_tools.rbs file should be in Plugins folder.
              thanks
                Aidus
                Well I rather do all work by myself organized like I want it 😄
                CPU: Intel Core i7 Extreme Edition 965
                RAM: OCZ Gold DDR3 1600MHz 12Gb
                Video: Asus Radeon HD4870 X2 2Gb
                Mobo: Asus P6T Deluxe 1366 Intel X58
                  dizain
                  Hi GOHCH,
                  the files are in the folders as specified but the error continues ...
                  the file 1001bit_tools.rbs must be in both folders, 1001bit and Plugins folder?
                    dizain
                    For GOHCH
                    My folders...
                    • F Offline
                      fakircho
                      Some questions about the stair components. Will it be possible to have some attribute options
                      on a stair so that you can select different handrails for example and also give it some parametric options
                      or would one always have to make a new stair if changes are needed ?
                        gohch
                        @dizain said:
                        For GOHCH
                        My folders...
                        hi dizain,
                        i believe it's the path/language:
                        please use notepad to edit the 1001bit_path_win_su7.rb file in Sketchup's plugins folder.
                        change the path
                        $GH1001bit_path="C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit"
                        to
                        $GH1001bit_path="C:/Programmi/Google/Google SketchUp 7/Plugins/1001bit"
                        cheers!
                          gohch
                          hi fakircho,
                          Current tools creates a new set of staircase and doesn't allow for real time editing of parameters.
                          As for handrails, you can use the vertical wall tool to create handrails. (the vertical wall tool can allow for selection of custom drawn profile)
                          meanwhile, i am working on a handrail tool that can extrude along curve-twist path correctly.
                          cheers!
                            dizain
                            Everything works ok ...
                            For the cost of the plugins?
                            Thanks Gohch.
                              gohch
                              Thanks Gohch.
                              hi dizain,
                              Don't want to charge anything until i've sorted out the Mac version, and make sure that it is stable.
                              after that we'll have to put a stop to the free license.
                              The current beta test license is valid without time limit for this version of 1001bit tools.
                              Mac users can register for beta test license now and keep it for the Mac version later.
                              (sorry guys, still waiting for may macbook.... no stock, i hope they can deliver soon...)
                              As for retail price of 1001bit... 😐 😐 😐 please let me keep it secret for a little while longer. 😒 😒 😒
                              cheers! 😄
                              • BurkhardB Offline
                                Burkhard
                                Hope with the same license or should I register again?
                                I've had registered earlier but I'm a Mac user.
                                http://www.ia-plus.de
                                  gohch
                                  hi Burkhard,
                                  No need to register again. The activation key for windows and mac will be the same.
                                  cheers!
                                    gohch
                                    hi everyone,
                                    The Mac compatible version of 1001bit tools is finally ready for download!
                                    (version 1.1.2)
                                    http://www.1001bit.com/freedownload.html
                                    Following are the updates in this version:
                                    1)Works on both Mac and Windows
                                    2)Toolbars included
                                    3)Inference added to vertical wall tool
                                    4)Bug fix on roof tool
                                    For those who has the previous version, just unzip into same location and overwrite the files.
                                    Cheers and Have fun!
                                    • BurkhardB Offline
                                      Burkhard
                                      Hi Gohch, thanks for the fast update. Have a nice time on Mac.
                                      How to install on Mac ? ( The folder contains no 1001bit_loader.rbs just the 1001bit_loader.rb ) You mentioned before that the .rbs should go under Plugins while the .rb go into the 1001bit folder )
                                      Burkhard
                                      Sorry, I just noted you're faq has been updated, thanks
                                      • utilerU Offline
                                        utiler
                                        Hi Goh Chun Hee,
                                        Firstly, pardon my asking but can you tell me your first name? Or is it Goh or Goh Chun? I don’t want to be rude and get it wrong….
                                        I have been playing with the 1001bits tools quite a bit and find them fantastic!!! I’m glad I stumbled across them, I guess you are being inundated with requested and comments via the pushpullbar and SCF forums….
                                        I have a few questions about a couple of the tools.
                                        Selection method…
                                        I note that for some functions you need to select the face first then select the function whereas others require the function to be set up first then select the face. This would be much easier if the process was consistent across the board. Eg: select face first or set up function first.
                                        Edits and Modify tools
                                        I know you have an extend tool for lines but what I would like to see is a tool for lines and or faces to extend to a plane. Eg: say you have a roof of 5 degrees and you want the walls to extend and trim to the underside of the roof plane.
                                        • Select faces and or edges of the top of wall
                                        • Select face to extend to [whether in the group or not]
                                        • Walls extend and clean up to the cut plane…..
                                        Horizontal / Vertical Louvres
                                        I think these need to have the option of a ‘zero’ thickness as the window and door functions do. This allows for painting a translucent material to a plane rather than having to paint both front and back…
                                        Roof
                                        I love this tool!!!! However, have you thought about creating a setup tool to create the selection face to define the roof? I know there is a ‘roof.rb’ tool created by TIG http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=3470 which creates the whole roof profile. All you would need is to write a script that asks for
                                        • Roof pitch
                                        • Overhang length[vertical or sloping fascia]
                                        • Skillion, Gable or hip roof
                                        Also, give the option in the dialogue box to toggle on or off rafters or purlins. This would make the tool more flexible for use with structural steel buildings…..
                                        And another idea; I note that the screens and grills tool allows for a profile to be selected. This would be fantastic to integrate into the rafters or purlins tool for such members as ‘I’ beams, ‘C’ and ‘Z’ purlins…. In the case of purlins, the ultimate would be for a line profile to be selected as they are generally 1.2mm thick and it makes not sense to create additional faces than needed.
                                        BTW, as for the version, can you advise what version is current? I have 1.1.0 registered to utiler. [Windows]
                                        Thanks again, I look forward to hearing from you soon….
                                        Just Curious...
                                          gohch
                                          hi Andrew,
                                          Thanks for the detailed suggestions.
                                          Most ppl call me Goh (which is actually family name) i'm perfectly happy to be called by that, easier to remember.
                                          version 1.1.2 works both for Windows and Mac. in fact. i'll be putting up version 1.1.3 in the weekend (after i've finished with some minor touchups)
                                          version 1.1.3 will include an extrude tool, which will extrude selected face profile through curved and sloping path(edges).
                                          SU's standard followme has the problem of twisting the profile along the way,
                                          this extrude tool will fix that.
                                          Meant for extruding handrails for spiral staircases and curved car park ramps.
                                          also the louvres in v1.1.3 will have the option of 0 thickness, single face louvres.
                                          there's also a newly added slope edges tool which is creates or modify selected edges to a fixed gradient.
                                          I hope to put it up for download by Sunday.
                                          The activation keys for version 1.1.0 is still valid (will remain valid for all version 1.1.x).
                                          cheers!
                                          Goh C H
                                          • utilerU Offline
                                            utiler
                                            Goh,
                                            Having a problem with Dividing panels..... [see attached]
                                            Each time I set my parameters then select the face, the panel is placed at the axis origin. What am I doing wrong!!!
                                            Cheers
                                            1001bit-divingPanel-issue.swf
                                            Just Curious...
                                            • 12
                                            • 13
                                            • 4 / 13
