    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 252.8k Views 66 Watching
      dizain
      Hi GOHCH,
      the files are in the folders as specified but the error continues ...
      the file 1001bit_tools.rbs must be in both folders, 1001bit and Plugins folder?
        dizain
        For GOHCH
        My folders...
        • F Offline
          fakircho
          Some questions about the stair components. Will it be possible to have some attribute options
          on a stair so that you can select different handrails for example and also give it some parametric options
          or would one always have to make a new stair if changes are needed ?
            gohch
            @dizain said:
            For GOHCH
            My folders...
            hi dizain,
            i believe it's the path/language:
            please use notepad to edit the 1001bit_path_win_su7.rb file in Sketchup's plugins folder.
            change the path
            $GH1001bit_path="C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit"
            to
            $GH1001bit_path="C:/Programmi/Google/Google SketchUp 7/Plugins/1001bit"
            cheers!
              gohch
              hi fakircho,
              Current tools creates a new set of staircase and doesn't allow for real time editing of parameters.
              As for handrails, you can use the vertical wall tool to create handrails. (the vertical wall tool can allow for selection of custom drawn profile)
              meanwhile, i am working on a handrail tool that can extrude along curve-twist path correctly.
              cheers!
                dizain
                Everything works ok ...
                For the cost of the plugins?
                Thanks Gohch.
                  gohch
                  Thanks Gohch.
                  hi dizain,
                  Don't want to charge anything until i've sorted out the Mac version, and make sure that it is stable.
                  after that we'll have to put a stop to the free license.
                  The current beta test license is valid without time limit for this version of 1001bit tools.
                  Mac users can register for beta test license now and keep it for the Mac version later.
                  (sorry guys, still waiting for may macbook.... no stock, i hope they can deliver soon...)
                  As for retail price of 1001bit... 😐 😐 😐 please let me keep it secret for a little while longer. 😒 😒 😒
                  cheers! 😄
                  • BurkhardB Offline
                    Burkhard
                    Hope with the same license or should I register again?
                    I've had registered earlier but I'm a Mac user.
                    [http://www.ia-plus.de(http://www.ia-plus.de)]
                      gohch
                      hi Burkhard,
                      No need to register again. The activation key for windows and mac will be the same.
                      cheers!
                        gohch
                        hi everyone,
                        The Mac compatible version of 1001bit tools is finally ready for download!
                        (version 1.1.2)
                        http://www.1001bit.com/freedownload.html
                        Following are the updates in this version:
                        1)Works on both Mac and Windows
                        2)Toolbars included
                        3)Inference added to vertical wall tool
                        4)Bug fix on roof tool
                        For those who has the previous version, just unzip into same location and overwrite the files.
                        Cheers and Have fun!
                        • BurkhardB Offline
                          Burkhard
                          Hi Gohch, thanks for the fast update. Have a nice time on Mac.
                          How to install on Mac ? ( The folder contains no 1001bit_loader.rbs just the 1001bit_loader.rb ) You mentioned before that the .rbs should go under Plugins while the .rb go into the 1001bit folder )
                          Burkhard
                          Sorry, I just noted you're faq has been updated, thanks
                          • utilerU Offline
                            utiler
                            Hi Goh Chun Hee,
                            Firstly, pardon my asking but can you tell me your first name? Or is it Goh or Goh Chun? I don’t want to be rude and get it wrong….
                            I have been playing with the 1001bits tools quite a bit and find them fantastic!!! I’m glad I stumbled across them, I guess you are being inundated with requested and comments via the pushpullbar and SCF forums….
                            I have a few questions about a couple of the tools.
                            Selection method…
                            I note that for some functions you need to select the face first then select the function whereas others require the function to be set up first then select the face. This would be much easier if the process was consistent across the board. Eg: select face first or set up function first.
                            Edits and Modify tools
                            I know you have an extend tool for lines but what I would like to see is a tool for lines and or faces to extend to a plane. Eg: say you have a roof of 5 degrees and you want the walls to extend and trim to the underside of the roof plane.
                            • Select faces and or edges of the top of wall
                            • Select face to extend to [whether in the group or not]
                            • Walls extend and clean up to the cut plane…..
                            Horizontal / Vertical Louvres
                            I think these need to have the option of a ‘zero’ thickness as the window and door functions do. This allows for painting a translucent material to a plane rather than having to paint both front and back…
                            Roof
                            I love this tool!!!! However, have you thought about creating a setup tool to create the selection face to define the roof? I know there is a ‘roof.rb’ tool created by TIG http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=3470 which creates the whole roof profile. All you would need is to write a script that asks for
                            • Roof pitch
                            • Overhang length[vertical or sloping fascia]
                            • Skillion, Gable or hip roof
                            Also, give the option in the dialogue box to toggle on or off rafters or purlins. This would make the tool more flexible for use with structural steel buildings…..
                            And another idea; I note that the screens and grills tool allows for a profile to be selected. This would be fantastic to integrate into the rafters or purlins tool for such members as ‘I’ beams, ‘C’ and ‘Z’ purlins…. In the case of purlins, the ultimate would be for a line profile to be selected as they are generally 1.2mm thick and it makes not sense to create additional faces than needed.
                            BTW, as for the version, can you advise what version is current? I have 1.1.0 registered to utiler. [Windows]
                            Thanks again, I look forward to hearing from you soon….
                            Just Curious...
                              gohch
                              hi Andrew,
                              Thanks for the detailed suggestions.
                              Most ppl call me Goh (which is actually family name) i'm perfectly happy to be called by that, easier to remember.
                              version 1.1.2 works both for Windows and Mac. in fact. i'll be putting up version 1.1.3 in the weekend (after i've finished with some minor touchups)
                              version 1.1.3 will include an extrude tool, which will extrude selected face profile through curved and sloping path(edges).
                              SU's standard followme has the problem of twisting the profile along the way,
                              this extrude tool will fix that.
                              Meant for extruding handrails for spiral staircases and curved car park ramps.
                              also the louvres in v1.1.3 will have the option of 0 thickness, single face louvres.
                              there's also a newly added slope edges tool which is creates or modify selected edges to a fixed gradient.
                              I hope to put it up for download by Sunday.
                              The activation keys for version 1.1.0 is still valid (will remain valid for all version 1.1.x).
                              cheers!
                              Goh C H
                              • utilerU Offline
                                utiler
                                Goh,
                                Having a problem with Dividing panels..... [see attached]
                                Each time I set my parameters then select the face, the panel is placed at the axis origin. What am I doing wrong!!!
                                Cheers
                                1001bit-divingPanel-issue.swf
                                Just Curious...
                                  gohch
                                  @utiler said:
                                  Goh,
                                  Cheers
                                  hi utiler,
                                  can you send me the skp file? (if the file is big, just a skp file containing the problematic face will do.)
                                  Thanks & cheers!
                                    @utiler said:
                                    Goh,
                                    Cheers
                                    That's the same problem I had with horizontal louvres. vertical works fine oddly enough. Open the Ruby Console and see if you get any messages.
                                      gohch
                                      @utiler said:
                                      Goh,
                                      Cheers
                                      hi utiler,
                                      The panel divider is meant for dividing a face into a few segments;
                                      1 row and 1 column will be the minimum.
                                      1 row and 0 column doesn't really make sense, hence the failure.
                                      I'll put in checking mechanisms in the dialog boxes in future so that undesired entry are either corrected or highlighted to the user.
                                      cheers!
                                        gohch
                                        hi thomthom,
                                        you're right, there's a bug there. just emailed you the patched hlouvres.rbs file.
                                        I'll put this in the version 1.1.3 release, hopefully tomorrow or day after.
                                        cheers!
                                          👍 Excellent!
                                          • utilerU Offline
                                            utiler
                                            Thanks Goh, I'll go try it out..... I assumed 1 row or 1 column would add a mullion or transom to the panel...
                                            Just Curious...
                                            • 12
                                            • 13
                                            • 3 / 13
