    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 265.5k Views 66 Watching
      gohch
      hi everyone,
      Sharing something that is unique to Vista; which might explain some setting up issues and ruby issues on Vista;
      In part of Vista's security control; sometimes Vista automatically creates a new separate 'mirror' folder in the following location:
      "C:\Users*username*\AppData\Local*VirtualStore*\Program Files\Google\Google SketchUp 7\Plugins\1001bit"
      because of this, you now have 2 sets of 1001bit folder; one in the above while the other in
      "C:\Program Files\Google\Google SketchUp 7\Plugins\1001bit"
      The folder in the VirtualStore takes precedence over the one in c:\Program Files....
      If windows find a duplicate file in VirtualStore and the other location, it runs the one in VirtualStore and ignore the other copy.
      This explains why sometimes when you've editted something in the plugin folder but nothings seems to change.
      There are 2 ways to work around this
      1. Find this VirtualStore and work directly in it.
      2. Remove the 1001bit folder or any file inside the VirtualStore that is a duplicate of the file you want to modify or replace. For example, if you've editted the 1001bit_path_win_su7.rb file, you should have only one copy of this file. I suggest remove the duplicate copy in the VirtualStore.
      Anyone having problem setting up in Vista, please double check this folder. Any issues feel free to write to me. Thanks
        gohch
        Note for installation on Vista 64bit (and on XP 64 too I guess):
        Modify the path in 1001bit_path_win_su7.rb to
        $GH1001bit_path="C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/1001bit" in order to get the path to work, otherwise the ruby looks in the 64bit program files path (with 64bit OS, the 32bit programs are placed in the "program files (x86)" folder).
        Thanks for the good work!
        Ryo
        hi, above is another feedback on installation for windows 64bit, from a registered beta tester, Ryo
        Thanks Ryo
        • utilerU Offline
          utiler
          GOHCH, I am experiencing Bugsplats when I 'Ctrl Copy and divide' in SU. Not sure it if there is a bug with yor offset or array tools that are effecting the standard SU functions.....
          Also, I have noticed a slight delay with my screen graphics; when I pushpull it is most noticed.... Not sure if you or others using this toolset are experiencing this.
          Just Curious...
            gohch
            hi Andrew, does that happens in new model? or is it something that is accumulative?
            Does it occur if you exit Sketchup and start Sketchup again?
            Is anybody experiencing similar problem?
            • utilerU Offline
              utiler
              thanks GOHCH, only experienced it in a new model...
              Have closed the file and opened it and still occurs. I purged the file and is only about 3Mb...
              Just Curious...
              • F Offline
                fakircho
                Thank you for the great plugins. They have this ArchiCAD feel to them, love it. I am glad to see someone
                focusing on architectural tools and doing it well.
                Have been playing around with it on Windows and all looks quite promising. One thing i have
                noticed is that when you use the build wall tool you can not follow the axis. Ideally you should be able to inference
                the normal way and use shift to lock on one axis or another. Same goes for the other plugins.
                Waiting for the working MAC version and the Tool bar πŸ˜„
                  gohch
                  hi Fakircho,
                  Thanks for the feedback, Yes, I should have the inference added in the next upgrade soon.
                  As for the Mac, ordered a Macbook but the earliest they can deliver is 2 weeks later; seems like Apple is pushing out a new model. I'm eagerly waiting for my Macbook to start working on the mac version. πŸŽ‰
                    gohch
                    hi guys,
                    i've added some inference to the Vertical Wall tool;
                    pressing the down button will cycle through the following inference modes
                    1 - lock current direction, next if the cursor is on an edge, projects to intersection point, else project to point nearest to the cursor position on the current direction.
                    2 - lock current direction, project to point on the x axis of cursor
                    3 - lock current direction, project to point on the y axis of cursor
                    4 - release
                    upwards button release the lock
                    right button - locks in x axis
                    left button - locks in y axis
                    Note that you can enter exact distance anytime.
                    Anyone want to try out please replace the attached vx_wall.rbs file with the one you have. (not sure whether i can attach rbs file here, zipped it just in case)
                    cheers!
                    updated vx_wall.rbs
                      dizain
                      Error:
                      No such file to load -- C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit/1001bit_loader.rb
                      • F Offline
                        fakircho
                        Thanks for the inference addition to the wall tool.
                        I hate to be difficult but can it work the same way as the rest of the Sketchup tools. That is
                        when you pint with your mouse it should pick up the red or green axis and then you lock it with the shift key? That would be perfect
                          gohch
                          @dizain said:
                          Error:
                          hi dizain,
                          can you double check whether you have moved the 1001bit_loader.rb file to the Plugins folder?
                          1001bit_loader.rb file should be in 1001bit folder while
                          1001bit_tools.rbs file should be in Plugins folder.
                          thanks
                            Aidus
                            Well I rather do all work by myself organized like I want it πŸ˜„
                            CPU: Intel Core i7 Extreme Edition 965
                            RAM: OCZ Gold DDR3 1600MHz 12Gb
                            Video: Asus Radeon HD4870 X2 2Gb
                            Mobo: Asus P6T Deluxe 1366 Intel X58
                              dizain
                              Hi GOHCH,
                              the files are in the folders as specified but the error continues ...
                              the file 1001bit_tools.rbs must be in both folders, 1001bit and Plugins folder?
                                dizain
                                For GOHCH
                                My folders...
                                • F Offline
                                  fakircho
                                  Some questions about the stair components. Will it be possible to have some attribute options
                                  on a stair so that you can select different handrails for example and also give it some parametric options
                                  or would one always have to make a new stair if changes are needed ?
                                    gohch
                                    @dizain said:
                                    For GOHCH
                                    My folders...
                                    hi dizain,
                                    i believe it's the path/language:
                                    please use notepad to edit the 1001bit_path_win_su7.rb file in Sketchup's plugins folder.
                                    change the path
                                    $GH1001bit_path="C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit"
                                    to
                                    $GH1001bit_path="C:/Programmi/Google/Google SketchUp 7/Plugins/1001bit"
                                    cheers!
                                      gohch
                                      hi fakircho,
                                      Current tools creates a new set of staircase and doesn't allow for real time editing of parameters.
                                      As for handrails, you can use the vertical wall tool to create handrails. (the vertical wall tool can allow for selection of custom drawn profile)
                                      meanwhile, i am working on a handrail tool that can extrude along curve-twist path correctly.
                                      cheers!
                                        dizain
                                        Everything works ok ...
                                        For the cost of the plugins?
                                        Thanks Gohch.
                                          gohch
                                          Thanks Gohch.
                                          hi dizain,
                                          Don't want to charge anything until i've sorted out the Mac version, and make sure that it is stable.
                                          after that we'll have to put a stop to the free license.
                                          The current beta test license is valid without time limit for this version of 1001bit tools.
                                          Mac users can register for beta test license now and keep it for the Mac version later.
                                          (sorry guys, still waiting for may macbook.... no stock, i hope they can deliver soon...)
                                          As for retail price of 1001bit... 😐 😐 😐 please let me keep it secret for a little while longer. πŸ˜’ πŸ˜’ πŸ˜’
                                          cheers! πŸ˜„
                                          • BurkhardB Offline
                                            Burkhard
                                            Hope with the same license or should I register again?
                                            I've had registered earlier but I'm a Mac user.
                                            http://www.ia-plus.de
                                            • 12
                                            • 13
                                            • 3 / 13
