    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 37.6k Views 61 Watching
      Matt666
      This awesome plugin must contains awesome icons...
      Icon master CadFather!!! This plum job is naturally for you! πŸ˜„
      Frenglish at its best !
      My scripts
      • McGyverM Offline
        McGyver
        Thank you, this ruby looks very interesting... I will try it as soon I possible!!
        [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
        • fredo6F Offline
          @james fraser said:
          Second: how it works on the Mac. I didn't see many people writing about this, so I thought I would let you know. The good news is that generally works fine, the only problem is a couple of UI things. The web dialogs do display, but it fills the bottom half of the window with nothing (presumably stretching the little blankspace border you normally get around things), but you can get around this by resizing the window until you see everything.
          The slightly bigger problem for me is labels. The mouseover description works fine, but the labels under icons are blank (when I turned them on), in the menu there are four blank lines, which work for selecting the tools, but have no names and I do not get anything in the flyout from the context menu (I mean there isn't a flyout, but there should be, the Freescale thing is there, but nothing happens). I don't care about the labels per se, but I use keyboard shortcuts a lot and without a label there is nothing to bind it to (I want to replace S for the normal scale tool πŸ˜„ ).
          to James, Kanonbal and other Mac users.
          Let's take things in order
          1. on the WebDialog UI, could anyone post a screenshot of the half visible dialog box.
          2. For the menus, FreeScale installs by default in Tools > Fredo6 Collection > FreeScale. From there, there are four command menus (i.e. the FreeScale tools), and 6 support menus (About..., support web, documentation, video, Translation and Default Parameters). Which ones do you see, and which ones do you not see ?. A screenshot would help as well.
            Additionally:
          • Do you get text in the status bar?
          • do you see the menus for LibFredo6 Settings (in Windowsmenu)?
          • could you switch to French, and advise if you see the FreeScale menu items?
          1. For the "labels", are you talking about the toolbar icon tooltips, or about the tooltips that appear at the cursor location (there may be a problem on Mac because may I use 2 lines tooltip)?
          Thanks very much for your feedback. As most of the problems mentioned are in functions managed in my Shared Library LibFredo6, I hope that fixing them for FreeScale will help to have a smoother release for my other plugins on Mac.
          • fredo6F Offline
            By the way, could some Mac User open the Ruby console and type the following command.
            FreeScale;;T6[;FSC_FREE_Menu]
            • CadFatherC Offline
              CadFather
              ..more icons coming soon.. as i can πŸ˜„
              • ely862meE Offline
                ely862me
                http://www.messentools.com/images/emoticones/varios/www.MessenTools.com-Varios-big-179.gif
                Manny thanks.....
                Elisei
                Elisei (sketchupper)
                Come and See EliseiDesign
                  CadFather
                  Hi Matt, not the best, but here's a couple to start.. πŸ˜„
                  not much on line lately but i'll be back sometime soon - (got a couple of surprises)
                  Toolbar icons.rar
                    James Fraser
                    Hi Fredo, got some pictures for you.
                    This is what you get with 'Customise Toolbar', so what you would see if they were on the normal toolbar (instead of floating, like they do on the Mac).
                    This is the drop-down from the plugins menu, showing the blank lines (which do work if you click on them and are ticked if you have already selected the tool from the toolbar).
                    The context menu failing to fly out
                    Mouseover works
                    The real problem is the shortcuts
                    The half covered preferences window. The bottom bit scales with the window, always covering half, if you stretch to twice the length you can see everything.
                    I hope that makes things a bit clearer. I did try the Ruby thing as well and it returned Free Scale, which is confusing.
                    I noticed in FreeScale.def that there was the line:
                    T_DEFAULT_ToolbarName = "Freescale"
                    I tried capitalising the S, but it seemed to make no difference.
                    I did change the language to both French and Spanish and the problems appeared to be the same.
                    Also, Tab doesn't work, but I can right-click for the dimensions box. I am not too bothered about that, but I thought you might want to know anyway. It might just be bound to something else on the Mac, I will let you know if I find it.
                    Thanks again for a great plugin, it is now my default scale tool πŸ˜„
                    http://www.FormFonts.com
                      James Fraser
                      Oops. Sorry, I forgot to mention that all the instructions show up fine in the status bar. I think everything works fine, apart from the bits in the screen caps.
                      • EdsonE Offline
                        Edson
                        james,
                        i have had problems with non appearing icons (which nonetheless worked if you clicked on the blank space) with other scripts. in most cases the problem went away with simply moving the script to user/library/application support/google sketchup/sketchup/plugins.
                        for some reason 2 plugins folders are created when you install skp on a mac. some scripts work better at the user level plugins folder.
                        http://www.mahfuz.arq.br
                          James Fraser
                          Thanks Edson. I gave that a go, even migrating all my plugins, but that didn't seem to work this time. It did make me think about permissions and ownership, but they all seem fine. I think the rubies only need to be readable, as SU just reads them on startup and presumably then runs things from memory.
                          My own scripts work fine, despite having no execute permissions (644, must be something to do with Aquamacs, I will have to check the settings).
                            Matt666
                            As always, excellent work, CadFather! Thank you!
                            My scripts
                            • O Offline
                              otb designworks
                              I couldn't help but notice that James' toolbar has four icons.
                              Mine only has two! And not just 2 blank and 2 showing, but only 2.
                              The rest of my behaviors match what James has posted.
                              I, too, migrated all of my plugins to the user library from the root library with no noticeable change to Freescale.
                              Cheers, Chuck
                              OTB Designworks is on Youtube
                                James Fraser
                                Mine originally had two, but I changed it to show all of them down at the bottom of the preferences. You have to scroll down and resize the window in order to see it. I'll use the normal two more, but the target ones will be handy to have around.
                                • O Offline
                                  otb designworks
                                  Thanks James, I don't know how I missed that!
                                  Cheers, Chuck
                                  • W Offline
                                    watkins
                                    Dear James,
                                    Can you be a bit more specific about where the icons are? I'm not too sure what you mean by 'at the bottom of the preferences'.
                                    Regards,
                                    Bob
                                      johnsenior1973
                                      @watkins said:
                                      Dear James,
                                      Regards,
                                      Bob
                                      Tools > Fredo6 Collection > Freescale > Default Paparameters
                                      Scroll down to Icons visible in the toolbar, click on the two that are unchecked.
                                      • W Offline
                                        watkins
                                        Dear Johnsenior,
                                        Many thanks,
                                        Bob
                                        • fredo6F Offline
                                          to James and other MAC Users
                                          Many thanks for this detailed report.
                                          On the menu issue, I really don't know what could be the difference between Mac and Windows. Just in case, I modified the code taking care of that (see attached file).
                                          on TAB, I thought the key code on Mac was 9, as in Windows. Could a ruby programmer equipped with a Mac confirm (or not) that this is what is got when getting the key in the onKeyDown and onKeyUp methods (and also to tell if we get the key on both Down and Up events).
                                          For the web dialogs, I need to see how I could overcome the problem (SU 7 has also a different behavior on Mac vs. SU6).
                                          Thanks again
                                          to drop in LIBFREDO6_Dir_30 folder
                                            James Fraser
                                            That's excellent Fredo, I have all the labels and the shortcuts are bound. I assume it was just splitting that line in declare_command, although I am not sure why that should affect it.
                                            Tab seems to highlight different tools, which can then be selected using space. It does something similar with Georeferencing sometimes. I think it is a Mac thing and it is Really Annoying, as space is the default (and most useful) binding for select. I really wish Google would choose the best aspects of the Windows and Mac versions and then make them both the same.
                                            But anyway, thank you for all your hard work, I am glad it is now working.
                                            • 6 / 7
