    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 52.7k Views 61 Watching
    • EdsonE
      Edson
      james,
      i have had problems with non appearing icons (which nonetheless worked if you clicked on the blank space) with other scripts. in most cases the problem went away with simply moving the script to user/library/application support/google sketchup/sketchup/plugins.
      for some reason 2 plugins folders are created when you install skp on a mac. some scripts work better at the user level plugins folder.
      http://www.mahfuz.arq.br
        James Fraser
        Thanks Edson. I gave that a go, even migrating all my plugins, but that didn't seem to work this time. It did make me think about permissions and ownership, but they all seem fine. I think the rubies only need to be readable, as SU just reads them on startup and presumably then runs things from memory.
        My own scripts work fine, despite having no execute permissions (644, must be something to do with Aquamacs, I will have to check the settings).
        http://www.FormFonts.com
          Matt666
          As always, excellent work, CadFather! Thank you!
          Frenglish at its best !
          My scripts
          • O
            otb designworks
            I couldn't help but notice that James' toolbar has four icons.
            Mine only has two! And not just 2 blank and 2 showing, but only 2.
            The rest of my behaviors match what James has posted.
            I, too, migrated all of my plugins to the user library from the root library with no noticeable change to Freescale.
            Cheers, Chuck
            OTB Designworks is on Youtube
              James Fraser
              Mine originally had two, but I changed it to show all of them down at the bottom of the preferences. You have to scroll down and resize the window in order to see it. I'll use the normal two more, but the target ones will be handy to have around.
              • O
                otb designworks
                Thanks James, I don't know how I missed that!
                Cheers, Chuck
                • W
                  watkins
                  Dear James,
                  Can you be a bit more specific about where the icons are? I'm not too sure what you mean by 'at the bottom of the preferences'.
                  Regards,
                  Bob
                    johnsenior1973
                    @watkins said:
                    Dear James,
                    Regards,
                    Bob
                    Tools > Fredo6 Collection > Freescale > Default Paparameters
                    Scroll down to Icons visible in the toolbar, click on the two that are unchecked.
                    • W
                      watkins
                      Dear Johnsenior,
                      Many thanks,
                      Bob
                      • fredo6F
                        to James and other MAC Users
                        Many thanks for this detailed report.
                        On the menu issue, I really don't know what could be the difference between Mac and Windows. Just in case, I modified the code taking care of that (see attached file).
                        on TAB, I thought the key code on Mac was 9, as in Windows. Could a ruby programmer equipped with a Mac confirm (or not) that this is what is got when getting the key in the onKeyDown and onKeyUp methods (and also to tell if we get the key on both Down and Up events).
                        For the web dialogs, I need to see how I could overcome the problem (SU 7 has also a different behavior on Mac vs. SU6).
                        Thanks again
                        to drop in LIBFREDO6_Dir_30 folder
                          James Fraser
                          That's excellent Fredo, I have all the labels and the shortcuts are bound. I assume it was just splitting that line in declare_command, although I am not sure why that should affect it.
                          Tab seems to highlight different tools, which can then be selected using space. It does something similar with Georeferencing sometimes. I think it is a Mac thing and it is Really Annoying, as space is the default (and most useful) binding for select. I really wish Google would choose the best aspects of the Windows and Mac versions and then make them both the same.
                          But anyway, thank you for all your hard work, I am glad it is now working.
                          • fredo6F
                            James,
                            On the menu, I am glad it's work. I assume you got back the context menu as well. Like you, I don't understand why the Ruby syntax would affect the interpretor differently on Mac and on Windows.
                            On TAB, I am interested to understand more, because I usually use this key to call dialog boxes (this was already the case for JPP, RoundEdge, TOS and BezierSpline). So:
                            • What does it do exactly?
                            • Do you think there would be an alternate key that could be handy to use instead on Mac?
                            By the way, the key F2 and F3 are assigned to toggle the live deformation and the wireframe. Do they work on Mac?
                            More generally, I am interested in other potential problems that could be Mac specific.
                              James Fraser
                              Ok, now I am really confused.
                              Things are fine in the plugins menu and the toolbars, but the context menu is still the same. Also, Tab works fine in JPP, but not in this. That does use the old version of LibTraductor (Dec 2007), although the section on keys appeared to be the same (I only looked briefly, so I might have missed something.
                              F2 and F3 don't seem to do anything, although if selected from the menu (context menu when using the tool works, but not for selecting the tools at the start), it behaves as you would expect. The ASCII code for Tab does seem to be 9, but, interestingly, for F2 and F3 it is 120 and 99, which is the same as for x and c. The hex keyboard codes are 78 and 63 (rather than 7 and 8 for x and c). I don't know if this is the same on the PC or how things work in the rubies, but hopefully that will help you a bit.
                              Here is a picture of the highlight thing, on the line tool at the moment, if I press it again it will move to the rectangle tool. It does that if you Tab with other tools in normal use, so maybe JPP was grabbing the input in another way?tab_highlight.jpg
                                James Fraser
                                Also, About Centre is toggled by Option (Alt) on the Mac, but that is fine as it is consistent with other tools (Ctrl is used to right click, in case you really feel the need to use a single button mouse).
                                • B
                                  Blah11
                                  this will help me out ALOT with this I always wanted to model it, http://tokyobuy.com/images/kampfer.jpg
                                  • fredo6F
                                    to James and Mac users
                                    The 2 attached files should solve the problems of context menu and of TAB (now trapped on Key up).
                                    to drop in FREESCALE_Dir_10
                                    • COSEDIMARCOC
                                      COSEDIMARCO
                                      Thanks Fredo6 for this Plugin.
                                      I've translated it in Italian.
                                      Italian language file
                                      [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                      • fredo6F
                                        Marco,
                                        Thanks very much for this. It will be integrated into the next sub-release.
                                        As you noticed probably, there are remaining strings in English when using FreeScale. They actually belong to LibFredo6, which can also be translated itself into Italian, if you have time.
                                        Again, many thanks
                                        • COSEDIMARCOC
                                          COSEDIMARCO
                                          Done
                                          Italian language file for LibFredo6
                                          • C
                                            crvela
                                            thank you
                                            • 7 / 7
