    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 41.1k Views 45 Watching
      kevsterman
      Kev if you have not fixed it already it can be corrected with a Rick Wilson ruby from smustard
      I solved the problem by pasting the warehouse into a new model. Thanks for your advice though πŸ‘
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
      • N Offline
        nomeradona
        here is my another try. this time with additional model from the warehouse
        Adding some more Warehouse stuff
        http://i334.photobucket.com/albums/m421/nomeradona_1234/withabubots.jpg
        Then warehouse models were refined to show details. created some bump textures and added them to the diffuse map. So here is the my render image (no post process). more than 12 minutes with my quad core.
        http://i334.photobucket.com/albums/m421/nomeradona_1234/warehouse_render_nopostcopy.jpg
        Post process image to add grunges.
        my steps using photoshop: 1. created a copy of the image and add filter high pass.. play on the opacity
        2. add a new layer, then use gradient tool of two colors (one light brown and one dark brown) blending mode is overlay
        3. add noise to this gradient map
        4. add mask and use textured map (35%) to removed slightly some grunge effect
        http://i334.photobucket.com/albums/m421/nomeradona_1234/renderwarehouse_Final.jpg
        • marked001M Offline
          marked001
          great job with the bump maps nomeradomna..that container looks great.
          here's my quick 15 minute maxwell setup..think it rendered for like 8 hours or so... didnt really adjust any of the materials, aside from the emitters..
          http://img4.imageshack.us/img4/6987/warehousetest3ox9.jpg
          and via multilight, here is a a daytime version
          http://img165.imageshack.us/img165/9003/frame1uc0.png
          http://www.revision21vis.com
          instagram: revi21on
          • N Offline
            nomeradona
            mark, thnaks for that. i noticed you said your render is about 8 hours, thats really long. Mine was just 12 minutes. Is it becasue of the emitters?..How about the daytime version?
              marked001
              maxwell is slow slow slow... it probably could've been shorter though, but i went out and left it running. the night and day images are created from the same render.. maxwell has a feature where you can adjust the output of each individual emitter, as well as the environment..
              instagram: revi21on
                dtrarch
                How about the fastest render comparison ?
                Killer quick @ 20 secs
                KT Photonmap quick
                edit light/dark in KT
                Global hdr
                  dtrarch
                  KT again
                  Photonmap fine + AA
                  3 min
                  • FletchF Offline
                    Fletch
                    great Dtrarch!
                    here's a thought...
                    when posting render times, number of threads used is important... I have a quad at work, a single at home... not the same game at all...
                    Fletch
                      dtrarch
                      Fletch
                      good idea
                      Cor2 Duo 8400
                      dtr
                        mirjman
                        here's a shot with vue 6... can anyone tell me why I keep getting the grainy look in the bright light render? using ambient occlusion
                          Jon
                          Here's my shot at this... πŸ˜„
                          http://www.shane-fletcher.com/gallery/share/jon/drum3.jpg
                          Jon
                          KT Team member
                          • ely862meE Offline
                            ely862me
                            quick shot vray
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • Alan FraserA Offline
                              Alan Fraser
                              A different slant.
                              3D Figures
                              • DanielD Offline
                                Daniel
                                This has been a lot of fun. Some great renderings have been posted. My thanks to everyone who has made this possible.
                                My avatar is an anachronism.
                                • FletchF Offline
                                  Fletch
                                  amb occ will not give you what you want in this render, mirjman... but check your AA settings.
                                  @jon - πŸ‘ 😎
                                  @Alan - πŸ˜† πŸ‘
                                  Fletch
                                  • brodieB Offline
                                    brodie
                                    Quick Maxwell render. Didn't really do anything special, tweaked the concrete material a bit and ran it for an hour @ 2000x1500
                                    https://dl.getdropbox.com/u/384281/warehouse_sm.jpg
                                    -Brodie
                                      Phil Rader AIA
                                      Here is a straigt-up Sketchup sketchy style.
                                      Sketchy style
                                      I consider sketchup styles as renderings.
                                      http://www.philrader.com
                                        arspi
                                        Podium 1.6, 10min.6sec, internal settings
                                        Amd Athlon 64 Fx-62, Xp3, 1630X928
                                        • daleD Offline
                                          dale
                                          Phil love your style. Is that a Studebaker? πŸ‘
                                            arspi
                                            Deep Exploration, 24bit, 842Ξ§595, Raytracer, 16 sec.
                                            • 6 / 7
