    [Plugin] Toggle Units
    159 Posts 47 Posters 146.7k Views 47 Watching
    • kenK Offline
      ken
      Hi Matt
      Thanks. As you can see from my avatar, I design in flat steel plate, and 1/8” is close enough for welders.
      Your response was faster service than I had at the restaurant I just returned from. Hope others find this helpful.
      Again much thanks.
      And on a side note, my youngest daughter is trying to be an exchange student to France this summer. She is taking French in HS this year. I know if she gets to go, she will have a great time.
      Again thanks
      Ken
        Matt666
        Sure! πŸ˜„
        Where will she want to go in France?
        Frenglish at its best !
        My scripts
        • kenK Offline
          ken
          Matt
          See will find out in the next two weeks if she is accepted and where exactly where she is going.
          Thanks for asking
          Ken
            Matt666
            I've updated first post with a new tool and new icons by CadFather! Thank you Max!
            Edson or Thomthom, does this version work on Mac?
            My scripts
            • EdsonE Offline
              Edson
              i am afraid only the three added features work. the rest does not (but was working perfectly before). no error in the ruby console.
              http://www.mahfuz.arq.br
                Matt666
                Incredible... That's incredible! Cheer up! We will success...
                My scripts
                • kenK Offline
                  ken
                  Matt
                  Installed and works as advertised. Also, like the additional button.
                  Thank you.
                  Ken
                  • JClementsJ Offline
                    JClements
                    Ahhhh ... changed already. I added a red dot to the original set to show the association between related buttons.
                    CAD father's, as always, are nice icons.
                    John
                      Matt666
                      Sorry JClements... 😳 😳 😳
                      My scripts
                        JClements
                        Hey Matt:
                        Could the new values created when the accuracy buttons are clicked, be displayed somewhere such as in the Task Bar or better yet when the mouse is put over the top of button?
                        John
                        • BurkhardB Offline
                          Burkhard
                          Same happens on my Mac . Just the last three buttons worked as expected. 😞
                          [http://www.ia-plus.de(http://www.ia-plus.de)]
                            matute525
                            Amigo!!! se que no vas a entender esto... pero si lo traduces quizas si...
                            TU ERES MI IDOLO!!!!!!
                            es la herramienta mas util que necesitaba par trabajar... te lo agradezco toda la vida...
                            Matias desde Corrientes, Argentina
                            • chrisglasierC Offline
                              chrisglasier
                              Much better - thanks Matt ...
                              • Bob JamesB Offline
                                Bob James
                                Only the 10th and 11th icon work on my Mac version. Also, as mentioned previously, the buttons stay depressed even when you press a different one.
                                Also, there is not much difference in the gray color between pressed and not pressed for the "Dec" button (when it is in its "not-pressed" condition it is already grayed out, but not quite as much as when it is pressed). See Attachment.
                                When I get it working it will be of significant value since I often work with both decimal inches and feet/inches.
                                !["Dec" not pressed](/uploads/imported_attachments/zvhk_Picture16.png ""Dec" not pressed")
                                • kenK Offline
                                  ken
                                  Is there anyone else that is having trouble with this plugin with Sketchup 7.1.6860. It will change the precision but not the units.
                                  Thanks in advance.
                                  Ken
                                  • CadFatherC Offline
                                    CadFather
                                    try with these: toggle_units.zip
                                    • EdsonE Offline
                                      Edson
                                      max, what problems is this new version supposed to solve? the copy I have installed works fine but for one thing: the buttons stay depressed even when you press a different one. by the way, I am on mac running the latest snow leopard.
                                        CadFather
                                        EDIT: if using SU 7.1, install the 2 files inside the zip (thanks to Jim)
                                        toggle_units.zip
                                        Matt, Thank you for this! πŸ˜„
                                        one question.. how can i assign a keyboard shortcut to one of them? or is it not possible?
                                        also, the units redraw only when i click on the screen or (press the esc key) - is that to do with screen refresh? if so is there any way to make it refresh automatically?
                                          CadFather
                                          unfortunately i have no knowledge of macs so i'm not able to test - on my pc once the 'dec' is enabled the icons stray pressed when selected..
                                          • kenK Offline
                                            ken
                                            @cadfather said:
                                            try with these: [attachment=0:xryojohw]<!-- ia0 -->toggle_units.zip<!-- ia0 -->[/attachment:xryojohw]
                                            CadFather
                                            Somehow I missed this post. So today I tried this post. I now have a toolbar with no icons showing. It seems the icon should now be in another directory. I haven't moved the icons until I know this is what is at fault.
                                            Also, after selecting Fract in the plugin menu, the plugin stop working until I select to top selection.
                                            So was the attachment you had posted, was that for my problem or a MAC issue.
                                            And what happen to Matt666?
                                            Would like some help, I find this a very valuable plugin.
                                            Thanks in advance.
                                            Ken
                                            • 4 / 8
