    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 56.6k Views 61 Watching
      Yes! I was thinking just this week that it'd be so nice ot be able to taper scale objects. This is another must have plugin. Thank you very much Fredo.
      • N
        notareal
        Great! Thanks for your effort.
          johnsenior1973
          Solo is going to find his cartoon characters a great deal easier with this. This is clearly another great leap for Sketchup.
          • T
            Teezer
            Wonderful! Great! Excellent! Thank you, thank you, thank you... 🎉 😄
            Real life is just another website, albeit a rather boring one.
            • tbdT
              tbd
              to be able to run on Mac I had to create DEFPARAM_Dir under plugins dir (due permissions restriction the mkdir command in Lib6Core_30 failed)
              nice work Fredo
              http://plugins.ro
              • soloS
                Bravo!!
                http://users.atw.hu/swb/smile/taps.gif
                Just what I need for my character modeling, thanks a ton.
                • W
                  watkins
                  Dear Fredo6,
                  One little known option of the native SU Scale tool is the ability to input final dimensions via the VCB (example: 100mm,100mm,100mm). The scale box is then scaled to those dimensions. Is this something that could be include in your script?
                  Kind regards,
                  Bob
                  • O
                    otb designworks
                    Great script! Thank you thank you!.
                    However, I, as you know, am on a MAC and I am having serious issues with this script.
                    The standard scaling tool works beautifully and as expected. Being able to set the orientation is brilliant!.
                    The taper scale tool, however, isn't working at all.
                    It displays the bounding box and shows the results of all of the tool manipulations, but it never actually changes the object geometry. Picture attached. Hitting return or clicking outside the box erases the bounding box and the cube remains as is.
                    Let me know what I can do to assist diagnosis.
                    Thanks again.
                    Cheers, Chuck
                    OTB Designworks is on Youtube
                      Matt666
                      😲 😲 Awesome !!! Thank you Fredo !
                      Frenglish at its best !
                      My scripts
                      • MALAISEM
                        MALAISE
                        Hi Fredo
                        Incredible enhancement 👍 👍 ☀
                        MERCI
                        MALAISE
                          Daniel S
                          Awesome!!!
                          Thank you Fredo!!!
                          I only have a problem when set the dimension in the dialog box by pressing TAB. It dosen´t accept what I put.. just make a beep 😕
                          I attach a video example of this.
                          Daniel S
                          a video of the problem (.wmv)
                          • fredo6F
                            Daniel S
                            Daniel,
                            Strange. What is the default decimal separator you normally use in your version of Sketchup.
                            Just in case, can you turn the Ruby console on to see if anything is displayed.
                            Can you also type in the Ruby console the following command:
                            Traductor.string_to_length_formula "20"
                            and see what it does.
                            I don't know if any other users has found that problem?
                            I will analyze what it could be in parallel.
                            • fredo6F
                              @watkins said:
                              Dear Fredo6,
                              Kind regards,
                              Bob
                              Bob,
                              Just press TABwhen the scaling handle is highlighted (or use the contextual menu). You should have the Dimension box appearing. For teh time being, I preferred to reserve the VCB to scale values.
                              PS: Daniel S. has found some issues with this dialog box. Maybe you can report if found any.
                              • fredo6F
                                Thanks again.
                                It is clear that there is an error in the execution of the deformation, as shown on your image.
                                The best would be to turn on the Ruby console and see what it says. I don't know if it could be related to Mac.
                                Also can you tell me if your run SU 7 or 6.
                                  roadkill
                                  many thanks dude... that is special!
                                  • O
                                    otb designworks
                                    Hi Fredo!
                                    Here is the Ruby Console result from attempting to taper scale.
                                    I am using SU7, OS 10.5.6.
                                    Cheers, Chuck
                                      Daniel S
                                      Fredo:
                                      When i put in the ruby console
                                      It returns:
                                      nil
                                      When i have open the ruby console and try to use the dialog box don`t report anything.
                                      I have the same problem with the taper.. it dosen´t accept what i put on the dialog box.
                                      I attach a screenshoot of my units.
                                      Daniel S
                                      • T
                                        TeKnoel
                                        this looks great! thanks for your hard work
                                        • EarthMoverE
                                          EarthMover
                                          Holy Sh!t! Just what I was thinking of asking for the other day. I love the taper. Reminds me of the Falloff function in Modo. Thanks Fredo!
                                          Content Creator at Skapeup
                                          • G
                                            gaganraj
                                            phenomenal tool. works perfectly on my windows machine. same issue as kannonbal on my mac.
                                            i'm amazed at how intuitive and simple such a great tool can me made. I absolutely love the little green check mark!! such a great idea. This will make SDS proxies so much easier! thanks!
                                            • 1 / 7
