    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 44.3k Views 61 Watching
      No, Fredo,I was wrong. Free scale is not "only" great - it is much more than that.
        Super bestial ! Very tricky! 👍 😎
          kwistenbiebel
          Fantastic fredo!
          Very useful. It will be one of those tools you cannot live without once you used it.
          You guys (the wizard ruby masters) should take over the further development of sketchup as a whole.
          Thank you very much. 👍 👍
            johnsenior1973
            Thank you for another great plugin.
            • W Offline
              watkins
              Dear Fredo6
              I have just tried FreeScale. EXCELLENT!!!
              Thank you for your generosity.
              Kind regards,
              Bob
                Yes! I was thinking just this week that it'd be so nice ot be able to taper scale objects. This is another must have plugin. Thank you very much Fredo.
                • N Offline
                  notareal
                  Great! Thanks for your effort.
                    johnsenior1973
                    Solo is going to find his cartoon characters a great deal easier with this. This is clearly another great leap for Sketchup.
                      Teezer
                      Wonderful! Great! Excellent! Thank you, thank you, thank you... 🎉 😄
                      Real life is just another website, albeit a rather boring one.
                      • tbdT Offline
                        tbd
                        to be able to run on Mac I had to create DEFPARAM_Dir under plugins dir (due permissions restriction the mkdir command in Lib6Core_30 failed)
                        nice work Fredo
                        http://plugins.ro
                        • soloS Offline
                          Bravo!!
                          http://users.atw.hu/swb/smile/taps.gif
                          Just what I need for my character modeling, thanks a ton.
                          • W Offline
                            watkins
                            Dear Fredo6,
                            One little known option of the native SU Scale tool is the ability to input final dimensions via the VCB (example: 100mm,100mm,100mm). The scale box is then scaled to those dimensions. Is this something that could be include in your script?
                            Kind regards,
                            Bob
                            • O Offline
                              otb designworks
                              Great script! Thank you thank you!.
                              However, I, as you know, am on a MAC and I am having serious issues with this script.
                              The standard scaling tool works beautifully and as expected. Being able to set the orientation is brilliant!.
                              The taper scale tool, however, isn't working at all.
                              It displays the bounding box and shows the results of all of the tool manipulations, but it never actually changes the object geometry. Picture attached. Hitting return or clicking outside the box erases the bounding box and the cube remains as is.
                              Let me know what I can do to assist diagnosis.
                              Thanks again.
                              Cheers, Chuck
                              OTB Designworks is on Youtube
                                Matt666
                                😲 😲 Awesome !!! Thank you Fredo !
                                Frenglish at its best !
                                My scripts
                                • MALAISEM Offline
                                  MALAISE
                                  Hi Fredo
                                  Incredible enhancement 👍 👍 ☀
                                  MERCI
                                  MALAISE
                                    Daniel S
                                    Awesome!!!
                                    Thank you Fredo!!!
                                    I only have a problem when set the dimension in the dialog box by pressing TAB. It dosen´t accept what I put.. just make a beep 😕
                                    I attach a video example of this.
                                    Daniel S
                                    a video of the problem (.wmv)
                                    • fredo6F Offline
                                      Daniel S
                                      Daniel,
                                      Strange. What is the default decimal separator you normally use in your version of Sketchup.
                                      Just in case, can you turn the Ruby console on to see if anything is displayed.
                                      Can you also type in the Ruby console the following command:
                                      Traductor.string_to_length_formula "20"
                                      and see what it does.
                                      I don't know if any other users has found that problem?
                                      I will analyze what it could be in parallel.
                                      • fredo6F Offline
                                        @watkins said:
                                        Dear Fredo6,
                                        Kind regards,
                                        Bob
                                        Bob,
                                        Just press TABwhen the scaling handle is highlighted (or use the contextual menu). You should have the Dimension box appearing. For teh time being, I preferred to reserve the VCB to scale values.
                                        PS: Daniel S. has found some issues with this dialog box. Maybe you can report if found any.
                                        • fredo6F Offline
                                          Thanks again.
                                          It is clear that there is an error in the execution of the deformation, as shown on your image.
                                          The best would be to turn on the Ruby console and see what it says. I don't know if it could be related to Mac.
                                          Also can you tell me if your run SU 7 or 6.
                                            roadkill
                                            many thanks dude... that is special!
                                            • 1 / 7
